not happy with lift
Discussion in 'Suspension' started by jr114, Nov 20, 2009.
  1. Nov 20, 2009 at 8:26 AM
    jr114
    jr114 [OP] Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    so after having my truck lifted..procomp extended strut kit..for about a year it doesnt look liftedto me at all. ive been looking at the rcd drop bracket kit and debating between that and spindles of some sort with a new shock. any recommendation as to which setup to go with?? by the way my truck is 2wd prerunner so im pretty sure that i can use the spindle from tc/camburg..least i think so. this lift is mainly for looks mainly drive it around town. only time i take it offroad are on surf and snowboard trips
  2. Nov 20, 2009 at 8:27 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Do the spindle.
  3. Nov 20, 2009 at 8:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2.
  4. Nov 20, 2009 at 9:30 AM
    jr114
    Jon
    SoCal
    Truck
    k any shock recommendations to go with that?
  5. Nov 20, 2009 at 9:51 AM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    5100's
  6. Nov 21, 2009 at 3:04 PM
    jr114
    Jon
    SoCal
    Truck
    well ive been looking around for a while on here and have had so many different ideas. but i think ive made up my mind. ive seen alot of trucks with various 3" lifts and just running a beefy ass tire and i kinda like that. so i think imma go with camburg coilovers and maybe their ball joint ucas..dont really wanna spend like 700 on ucas if im not really gonna be running the truck off road that much. anyone know how the ride will be with the camburgs as opposed to stock???
  7. Nov 21, 2009 at 5:30 PM
    bajamoon
    STEVE
    Whittier
    much better than stock. you can buy sway a way coilovers as they make them for camburg. cut out the middle man. you don't have to get the uca's but it depends on how much you want to lift with the coilovers.
  8. Nov 21, 2009 at 5:50 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
  9. Nov 21, 2009 at 10:46 PM
    bajamoon
    STEVE
    Whittier
    he didn't buy anything yet
  10. Nov 21, 2009 at 11:38 PM
    jr114
    Jon
    SoCal
    Truck
    the thing is i need new ucas already. im running the procomp 3" kit with 285/70/17's so no matter what i need to match the height i have now to prevent rubbing but also fix my alignment.but now a new problem..looking around gives me too many bad ideas.haha i saw that cst makes a coilover that will give 3.5" of lift. might look some more into these and use those instead of the saw or camburgs with a new uca.
  11. Nov 21, 2009 at 11:44 PM
    jr114
    Jon
    SoCal
    Truck
  12. Nov 22, 2009 at 7:53 AM
    bajamoon
    STEVE
    Whittier
    never heard of cst, and for 1099 for coilovers, too high. i got my sway a way 2.5 for 650. check off road engineering, they have a good selection and the guys are great down there
  13. Nov 22, 2009 at 8:36 AM
    imsikotic
    imsikotic If u cant stand behind our troops. Stand in front
    Randy
    Temecula, Ca
    06 TRD Sport DesertRunner
    4" Camburg Race Spindles and Icon 2.5" ext travel Coilovers in the front for about 5"of lift and for the rear All-Pro 3" leaf pack and Fox 2.0 Resi's converted to piggyback and custom valved by DownSouth Motorsports. 17x9" KMC XD Addicts w/ 4.5 inch Backspacing and -12 Offset. Wrangler Duratracs 285/70/17. K&N CAI, Exhaust, Carriage Works Billet Grill, Custom Bed bar with ProComp fog lights,DirtKing Fabrication front bumper w/ 3 HID converted Hellas, Demello rear PreRunner bumper, Tinted windows, Full System w/ 2 10s, Garmin 265WT, ClearHLM. Theres more I just cant think of it right now.
    Spindles FTW!!!! Thats a 4" lift right there and if you wanna go higher than that you could get some Adj. Coilovers and get about a 6" lift up front. Good luck on what ever you choose.
  14. Nov 25, 2009 at 4:04 PM
    jr114
    Jon
    SoCal
    Truck
    well i just talked to the guys from sway away and procomp. figured out why the pro comp lift is so stiff. the tech guy said that the spring rate is 718!! no wonder it rides so stiff. and after talking to the sway away guys im stoked and should be ordering a set of their 2.5 coilovers soon. and i learned something that im sure all of you guys already know. i thought that you had to adjust the coilovers to show 3" in order to achieve 3" of lift. the sway away guys said that all i would have to do is adjst them so that roughly 2.5" inches are showing on the coilover and that would in turn relate to a 3" lift.
