Not happy with TSB Spring swap....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chilic82, Jul 31, 2009.
  1. Jul 31, 2009 at 8:06 PM
    chilic82
    chilic82 [OP] Well-Known Member
    TX
    07 DC PreRunner SR5
    What would be the easiest thing to do?Can I just remove one of the springs? I don't like the ride now and wish it were back to factory suspension.Would it help to replace the rear shocks with some that are more forgiving? What's a guy to do?
  2. Jul 31, 2009 at 8:11 PM
    grdnrxr
    grdnrxr Well-Known Member
    Back in Hawaii
    TRD Sport Prerunner
    Is it harder or softer or?
  3. Jul 31, 2009 at 8:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Swap with someone who has the non TSB springs.
  4. Jul 31, 2009 at 8:16 PM
    chilic82
    TX
    07 DC PreRunner SR5
    What about the Bilstein struts up front? They lift the front from what I understand. I might have to get some factory springs from the wrecking yard.
  5. Jul 31, 2009 at 8:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The shocks dont give you any lift....
  6. Jul 31, 2009 at 8:16 PM
    chilic82
    TX
    07 DC PreRunner SR5
    It's a quite stiffer ride.
  7. Jul 31, 2009 at 8:18 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i'm sure u can find someone in the area that either is not eligible for the TSB or would rather get the springs from u than deal w/ the stealer. post up in the B/S/T section for a trade
  8. Jul 31, 2009 at 8:19 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    ^yep it is. Dumping my trd bilsteins for the 5100's was a great move. A much more balanced ride than the overly stiff bil's
  9. Jul 31, 2009 at 8:21 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    Why did you get the TSB done? Do you haul large loads or did you just want them because you could get them?
    If you haul, you will want them. If you got them "just because", trade up with someone who is unable to get the work completed. It's harsh because they gave you a stiffer set of leaf springs in the back. New struts won't do anything for you.
  10. Jul 31, 2009 at 8:32 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    IMO, a stiffer ride is a good trade off for not hitting the bump stops on mildly bumpy roads with only two people in the truck. That's dangerous as hell.
  11. Jul 31, 2009 at 8:34 PM
    chilic82
    TX
    07 DC PreRunner SR5
    Yea, I was thinking of just swapping the rear leafs. I think most of the stiffness is from the rear. I may leave the front Bilsteins and just replace the rear leafs with some from the wrecking yard(if I can't find someone to trade me). I don't haul much, but mine was bottoming out with my inlaws in the truck with me and my wife. I just couldn't believe that the Tacoma couldn't handle 4 adults without any cargo at all. All 4 of us together weigh less than 900 lbs. But, they don't ride with me much and if they do it mostly bottoms out on rough roads or speed bumps. I can deal with it for that long.
  12. Jul 31, 2009 at 8:39 PM
    Veccster
    Veccster bass turds
    Eric
    2020 Pro
    In-laws are such a pain in the ass!
    I don't haul mine anymore :D
  13. Jul 31, 2009 at 9:54 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    Give it a little time before you trade it- it may settle a bit and become a lil softer
  14. Jul 31, 2009 at 11:13 PM
    chilic82
    TX
    07 DC PreRunner SR5
    So, can I just remove a spring? And if so which one?
  15. Aug 1, 2009 at 1:09 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I've had mine for about 8 months and they are still stiff and the rear end is still high.
    Also the OP went from the stock shocks to the Bilsteins and I may be mistaken, but aren't those also stiffer? Seems like it to me after I had it done.
    Have to checked with the dealer and see what they would do about changing them back out for the 3 leaf pack?
  16. Aug 1, 2009 at 1:15 AM
    chilic82
    TX
    07 DC PreRunner SR5
    They said that once they do the swap Toyota won't pay to put it back and that Toyota recall's all the warranty parts back.
  17. Aug 1, 2009 at 2:08 AM
    FoxySandChick
    Kristin
    Henderson, NV
    Yes, the dealer has to ship the old parts back to Toyota to get paid for it, but the dealer might have the 3 leaf packs in stock which you could then purchase from them and either have them, some place else or yourself install. So yes you'd end up paying to put it back to stock.
    Not likely you will get someone to trade, because you would have to remove them with nothing to put in place till you received them and same for the other person. But however you replace the 4 pack, you can probably get a little $$ for it from someone who doesn't qualify.
    If you still don't like the ride with the Bilstein shocks, you might be able to buy the stockers from someone with an sr5 then sell the bilsteins. But none of the parts are worth much to people, so you will still be out $$.
    Or just deal with it, the TSB warned the ride would be stiff.
  18. Aug 1, 2009 at 2:43 AM
    chilic82
    TX
    07 DC PreRunner SR5
    Yea I know, but alot of people on here said that they loved the way theirs rode or couldn't tell much difference. I'm going to see if I can find someone to trade and if not maybe someone who replaced their stock leaf packs will sell them.
  19. Aug 1, 2009 at 3:09 AM
    FoxySandChick
    Kristin
    Henderson, NV
    Good luck, thats probably your best bet. :thumbsup:
    I'm curious though too, if it is possible to just remove a leaf?
    Where is Chris4x4 when you need him ;).
  20. Aug 1, 2009 at 5:53 AM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    Just drive to Ohio and swap them out for mine... :)
    (person out of warranty who doesn't like the 3-leaf springs and has a plain ol' SR5)
