Not just another oil change question!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MusicOn, Nov 15, 2008.
  1. Nov 15, 2008 at 4:17 AM
    MusicOn
    MusicOn [OP] Member
    Virginia
    09 4WD TRD Sport
    TRD Cat Back
    Hi everyone!
    I studied the previous posts in depth and feel like I am ready to tackle my first oil change for my 2009 4.0 Taco (special thanks to Chris 4X4 for the excellent tutorial) .
    However, 2 questions for the experts:
    1. In the online tech manual (the one online is for the 2006 but the 1GR-FE engine is the same I believe) they say in step 1a of "drain engine oil" to "remove the engine under cover seal no. 3." Any idea what this is?
    2. Everyone says to install a new drain plug gasket. How important is this? Since it's Saturday, and the Toyota parts shop is closed until Monday, is this something that can be obtained from Advance Auto Parts? Are drain plugs a standard size?
    Thanks for your help! :)
  2. Nov 15, 2008 at 4:30 AM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    Not sure what they are trying to get at with your first question. What Chris showed in that tutorial is about all you'll need to know/do.
    But IMO, you definately won't need a new drain plug gasket everytime you do an oil change. It's one of those things that if you have your truck long enough, you'll eventually need to change it. I wouldn't sweat it.
  3. Nov 15, 2008 at 4:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Seems that many people have re used the existing gasket with good results. :)
  4. Nov 15, 2008 at 4:45 AM
    Joe B
    Joe B Well-Known Member
    I use a Fumoto oil drain valve.
    Great item.No gaskets to worry about and easy drain and no wrenching.
    Open and drain by lifting locking arm and move to right with your fingertip.
    Been using the Fumoto oil drain valves on many vehicles for years.
    Not for use off road,though.The valve sticks out about an inch.Probably ok because there's a crossmember close toward front but I would stay with the plug.
    I don't go off road so it's fine for me.
  5. Nov 15, 2008 at 5:03 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    Sold my truck Jan '13... Still hang around.
    +1
    Re-using it once or twice really shouldn't be a problem. Swing by the dealership sometime and pick a few up (the were $1/ea when I got one) and just keep them in the glove box for next time.
    I put one of these on my wife's Passat at her last oil change, and I'm putting one on my truck later today when I do the 25k mile oil change. I don't off-road either, so I'm not worried about it getting knocked off. I'm looking forward to the easy oil changes from here on out.
  6. Nov 15, 2008 at 5:14 AM
    Joe B
    It a great item.
    No tools needed for an oil change now for me.
    I use a piece of sand paper to loosen and tighten the oil filter by hand.Although the first change was a bitch.The factory had that oil filter on so tight,it was a bear getting it off.
    I have a piece of 5/16 hose that attached to the oil filter drainshelf all the time.I plastic tied the hose to some wires on the way down and just tuck it under the skid plate when not in use.
    Easiest and fastest oil change on earth.:D
    No tools.Just a oil change bucket,funnel and a piece of sandpaper.
    Easy and I still change the oil and filter only once a year with Amsoil products but I only do 8-9K miles a year.
  7. Nov 15, 2008 at 5:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have a friend that LOVED that little valve. No mess oil changes, etc.....right until a rock knocked it off on a trail, and he lost all of his oil. :( If you do ANY off roading, I would reconsider that valve. After all, turning a bolt/drain plug isnt that time consumeing. :)
  8. Nov 15, 2008 at 6:04 AM
    Joe B
    Mentioned in my post.:)
    "Not recommended for off road use"
  9. Nov 15, 2008 at 6:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    why yes it is. Sorry. :eek:
  10. Nov 15, 2008 at 7:57 AM
    MusicOn
    MusicOn [OP] Member
    Virginia
    09 4WD TRD Sport
    TRD Cat Back
    Thanks everyone! Just got back armed with 5 qts of Mobil-1 + filter - good to know the plug gasket isn't a big deal.
    Cheers!:cool:
  11. Nov 15, 2008 at 8:26 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Where can I get one of these bad boys?
  12. Nov 15, 2008 at 8:39 AM
    Joe B
  13. Nov 15, 2008 at 9:01 AM
    grivera
    Hanover, MD
    Thanks!
  14. Nov 15, 2008 at 9:13 AM
    grivera
    Hanover, MD
    JoeB, is yours the style without the nipple? If so, how did you get the hose to stay put?
  15. Nov 15, 2008 at 9:21 AM
    Joe B
    No nipple.
    Don't get the nipple.It's not needed and the valve is longer with the nipple.
    I don't use a hose on the valve.Just open and drain.
    I use a hose on the oil filter plate assembly.That's the hose I talked about.
  16. Nov 15, 2008 at 9:32 AM
    grivera
    Hanover, MD
    cool thanks. I'm gonna buy one for the Taco.
    I wonder if one of these would be too low for my 06 Camry. I can't recall how low the pan/plug sits and my wife has it at work right now.
  17. Nov 15, 2008 at 3:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2.
  18. Nov 15, 2008 at 7:48 PM
    news8000
    news8000 Active Member
    Southeast Manitoba, Canada
    06 Tacoma 4X4 Access Cab Stock
    ON STOCK UNIT: Rear Leaf TSB, Leer Cap w/ Windoors, Michelin LTX M/S on ION 133s, K&N Filter, Cruise, Python Command Start/Alarm, Toyota Class 5 Hitch, Metra IPod Adapter
    I buy toyota oil filters from the toyota dealership (at a cost close to any others I've looked at), and they supply a new drain plug gasket in the box with each new filter. The filter gaskets even come "pre-lubed" :thumbsup:
    N
  19. Nov 16, 2008 at 1:48 PM
    MusicOn
    MusicOn [OP] Member
    Virginia
    09 4WD TRD Sport
    TRD Cat Back
    What's 0.5 qts between friends? :)
    Also, I managed to find the filter gaskets at Napa (they have metal and rubberized metal ones) for about $0.70.
  20. Nov 17, 2008 at 7:35 AM
    lakeside
    lakeside Member
    Ottawa, Canada
    Tacoma
    I had a look at the site (http://www.quickoildrainvalve.com/) and didn't see a P/N for a 2009 Tacoma with a 2.7li engine. I sent an email to the company but does anyone know which drain valve fits the '09?:confused:
