Not payin' $300 for recovery boards, nope. So what's left?
Discussion in 'Recovery' started by tonykarter, Mar 20, 2023.
  1. Mar 20, 2023 at 7:35 AM
    tonykarter
    tonykarter [OP] Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    I'm pretty sure some ramps recover better than others. What has been you experience with less expensive recovery boards? Whose should I buy, with an obvious eye towards cost? THANKS!
    Sdswingr and KRUD like this.
  2. Mar 20, 2023 at 7:36 AM
    surfishjoe
    surfishjoe Well-Known Member
    Joe
    Margate, NJ
    2004 Double cab TRD
    Bump- curious as well.
    tonykarter[OP] likes this.
  3. Mar 20, 2023 at 7:38 AM
    2Shoes
    2Shoes Well-Known Member
    2021 TRD Off-Road
    Everyone I know who has used the lower cost ones, end up damaging them, and having to replace them each time they get used, then they buy the $300+ ones, and they are useful multiple times, without being damaged. There is something to say for buying quality things.
  4. Mar 20, 2023 at 7:38 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Im not saying dont buy them, if you're on a budget you're on a budget. Nothing wrong with that.
    But, Ive never seen 'cheap' or off-brand boards last.
  5. Mar 20, 2023 at 7:49 AM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    This is the best comparison I have found but is a little dated. There may be more/different products on the market now but you can see what cheap gets you in the Aussie Outback.
  6. Mar 20, 2023 at 8:03 AM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Everybody knows those $300 boards will last, but I remember getting stuck in the snow once a few years back and a set of $50 boards saved my butt. That being said if you’re out in the middle of nowhere quite often and either don’t want to buy or can’t afford to buy the more expensive ones at the very least buy a couple of sets of the cheap ones.
    Jaredius, tonykarter[OP] and SR-71A like this.
  7. Mar 20, 2023 at 8:11 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Don't skimp on tires and recovery gear.
    Jaredius, wi_taco and MonkeyChief like this.
  8. Mar 20, 2023 at 8:14 AM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    If you put together a decent recovery kit, you will have multiple options.
    I LOVE to spend money on fancy tools, equipment, etc. BUT, I'll likely never use a set of traction boards, but I do have a cheap $90 Amazon set (they came in a nice bag actually which I like).
    More than likely they are going to be used for someone else, on a beach trip, so I don't have to pull out winch line or a recovery strap.
    I carry a spare recovery receiver shackle as well, with a d-ring and a hitch pin in it. I've got multiple options on my truck but someone else might not.
  9. Mar 20, 2023 at 10:26 AM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
  10. Mar 20, 2023 at 10:29 AM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I've got sub-$100 boards. Used them several times (5 give or take) in winter and summer and they've worked and they're not broken so take that fwiw. Most guys I wheel with also have the cheap ones and it's the same story. They'll definitely get you at least once, which may be all you need.
    If you just want them for the outside of the vehicle, maxtrax certainly do look better
    tonykarter[OP] and jackn7 like this.
  11. Mar 20, 2023 at 10:32 AM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    80 Dollar ones from Amazon. Just don't let them see the sun. They melt.
  12. Mar 20, 2023 at 10:39 AM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    I bought a set of the cheap ones, got about 6 uses out of each one before they were so badly broken I had to pitch them. One of them cracked in the first use just doing a snow recovery.
    For me, I figured it's better to just buy the MaxTrax set once than having to buy a new set of cheap boards every 12-18 months. Plus the MaxTrax mounting hardware is way nicer than anything the cheap boards come with.
    I would say if you plan on using them regularly buy MaxTrax, otherwise plan on buying cheap ones every 5-10 uses.
    tonykarter[OP], jackn7 and Shellshock like this.
  13. Mar 20, 2023 at 10:39 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I got me cheap set; cost about $60 5-6 years ago. Got me a set of ‘mini’ size a few months ago. They are the same width but half the length. I think they were $45. I loan them to my daughter when she goes to the snow. They fit better in her RAV4. I offroad mostly in the dez so they should last a while. I can see them damaging easier if you use them in rocky terrain.
  14. Mar 20, 2023 at 10:42 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    These ones are decent for the price. As others have already stated, you get what you pay for, but for some light duty use in sand and snow, these will do the trick.
    https://www.amazon.com/dp/B00AV2HON...0&sr=1-2-9e67e56a-6f64-441f-a281-df67fc737124
    Now, if you're going to be regularly using them, building bridges with them, etc, then it it worth it to buy some maxtrax.
    ColoradoTJ, tonykarter[OP] and SR-71A like this.
  15. Mar 20, 2023 at 6:31 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Interesting video. Nice to have a bridge that works once, but I hope the ones I bought (not technically tested but I can interpolate) last a little longer than once. Live and learn (in this case maybe NOT "learn from the mistakes of others", but ...).
    2" lifts, full skidplates, 33" tires, exhaust redirect, RTT ... I will start with vehicle protection and live with my TRED GT.
    Either that or I go where Wily E. Coyote goes several times in each cartoon ...
  16. Mar 20, 2023 at 7:23 PM
    tonykarter
    Snuff Gully, Texas
    Lots of good info there. Thanks you guys. I'm not going to be doing much hardcore offroading, but I want to be ready. Good options here to consider!
  17. Mar 20, 2023 at 7:30 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Buy a pack of shingles.
  18. Mar 20, 2023 at 7:48 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    It's not even about hardcore offroading; I've used traction boards in a taco bell drive thru
    gudujarlson likes this.
  19. Mar 20, 2023 at 8:44 PM
    RichochetRabbit
    Having read a couple of threads about traction boards it seems to me that "best" is a balance of budget, chance you will use them even once.
    Also, after you read the remainder of this post, feel free to hate me, but ...
    But an overriding thought I had reading too many (my humble opinion) statements of "never used them, hope they work when I do need them and that I know enough to use them". Which is probably a very poor way to approach "recovery gear".
    People who use hi-rise jacks tell you and show you how dangerous they can be, but you must try using it to really understand. Understanding how a bottle jack can sink in the mud is not a substitute for experiencing that situation. And just hoping that both you (knowledge) and the board (quality) are ready for sand or mud or snow could make your recovery gear useless.
    A lesson for me, today, now ... go out to a controlled place where 2WD is close to if not actually enough but 4WD will get me out if the board/winch/etc do not. Then see if I can get out without the 4WD. I can only advise those without the experience to gain that experience.
    redwoods and Dirty Harry like this.
  20. Mar 21, 2023 at 1:38 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I personally wouldn’t cart around any sort of traction boards unless I knew I was going to use them. That said, I have the tred pros, have used them countless times over the past 2-3 years, and they still look brand new disregarding the dried mud on them. But, wow, they have gone up in price.
