not running right
Discussion in '1st Gen. Tacomas (1995-2004)' started by ethanfoy, Apr 20, 2012.
  1. Apr 20, 2012 at 9:39 PM
    ethanfoy
    ethanfoy [OP] Well-Known Member
    ethan
    Little Rock AFB
    99 toyota tacoma xcab 4x4
    Well my 99 tacoma isn't running right. First,when taking off right after start up I will take off and it will kindof sputter in second and third gear. Second it gets worse gas mileage than normal. Could it be the maf or do you think it could be spark plugs I don't know when the last time they was changed.
  2. Apr 20, 2012 at 9:42 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    Could be the MAF. And might as well go ahead and change the plugs anyway. i just changed mine. they were only 3 bucks a piece from toyota
  3. Apr 20, 2012 at 10:03 PM
    ethanfoy
    ethan
    Little Rock AFB
    Yeh that's what I was thinking I'm going to get me some cleaner and plugs while I'm in town hopefully that helps. I don't like spending 100 dollars a week on gas.
  4. Apr 20, 2012 at 10:07 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    silly question, is the CEL on?
    For drivability its a good start to check out the basics: plugs, MAF, emission components. Truck came in this morning with a P0420, catalyst below threshold....drove like absolute garbage. Sputtered, felt like it didnt want to stay running and was a DOG!
    Hope that helps at all.
  5. Apr 20, 2012 at 10:11 PM
    ethanfoy
    ethan
    Little Rock AFB
    Its mainly when its not warmed up but during the winter when it was 20 degrees it ran better, and not to sound stupid but what is CEL
  6. Apr 20, 2012 at 10:16 PM
    08pretaco
    az
    check engine light.
    so your saying your having a hard time driving in low gears when its not warmed up and your gas mileage is bad?
    well winter blend gas will get worse mileage regardless of anything. my truck has hard time driving if i dont let it sit for a bit to warm up (which I dont). might just be a common cold start drive right away type of thing. see what happens with your gas mileage as you start using summer blend gas
  7. Apr 20, 2012 at 10:26 PM
    ethanfoy
    ethan
    Little Rock AFB
    Well heck I didn't think of Cel being check engine light Haha but its never done this before.
  8. Apr 20, 2012 at 10:40 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Well if the CEL isnt on im guessin its probably either the plugs or the MAF. Not sure if the CEL comes on if the MAF is dirty or not. Let us know OP if it gets any better once you replace/clean those
  9. Apr 20, 2012 at 10:53 PM
    ethanfoy
    ethan
    Little Rock AFB
    Is there anything I need to do while I'm doing all this. Thanks for yalls help.
  10. Apr 20, 2012 at 11:05 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Well ive never cleaned my maf sensor so im not too sure what all you need to do. but for spark plugs its pretty easy just dont break your intake tube when takin it off. i broke mine pretty easy. that was on my old landcruiser though. i was careful on my tacoma haha
  11. Apr 21, 2012 at 2:11 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    My truck ran like shit and got terrible gas mileage until I realized it had several cracks in the exhaust manifold. Replaced it with an LCE header, and I am back up on power and getting 18mpg on 33's.
  12. Apr 22, 2012 at 7:04 PM
    ethanfoy
    ethan
    Little Rock AFB
    Well I cleaned the MAF and its starting up better and its running better but I didn't change the spark plugs because my dad said he changed them not to long ago but i have ngk spark plugs for next time Haha. But cleaning it did help i dont know about mileage yet
