Not super well versed in suspension/lift kits. Need advice
Discussion in 'Suspension' started by FullyTorquedTaco, Jan 30, 2020.
  1. Jan 30, 2020 at 12:21 PM
    FullyTorquedTaco
    FullyTorquedTaco [OP] Well-Known Member
    Sacramento, CA
    2017 4x4 DCSB
    Whats up guys, 3rd gen 2017 SR5. Looking at bilstein 5100 but right now i have pretty new 265's on the truck and dont want it to look wonky with too much lift.
    Any suggestions? Lift with suspension kit? Or go with a lift/level...
  2. Jan 30, 2020 at 12:31 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Stay under 2” front. Get a suspension lift. For general around town driving, a 1” - 1.5” block will work in back. Consider a 2-3 degree shim and extended brake line in the black.
  3. Jan 30, 2020 at 2:31 PM
    DC5275
    DC5275 Well-Known Member
    David
    Nature Coast Hernando, FL
    2017 Tacoma TRD OR DCLB Black 4.88 Gears
    My Opinion, if sticking on 265/70/16
    5100's on factory coils set on 2nd clip 0.65" or 3rd clip 1.1"
    Level out your truck and if not happy then you can replace factory coils with OME or Eibach coils. Then on the rear decide on lift blocks, AAL or full leaf pack.
    For $375 front and rear 5100's it is a lot better option I feel over a spacer setup.
    or Just $219 for front 5100's. Plenty of choices, you got to know what you want and are willing to $$$
    Good luck
    Plenty of information here on TW to spin your mind out of control.
    Also welcome to the forum
    FullyTorquedTaco[OP] likes this.
  4. Jan 30, 2020 at 2:57 PM
    FullyTorquedTaco
    Sacramento, CA
    2017 4x4 DCSB
    So you only need the shocks?
  5. Jan 30, 2020 at 3:42 PM
    DC5275
    David
    The front 5100’s have clip settings to adjust ride height, you can use your OEM coils between these settings. If you use aftermarket coils you would use the lowest setting (typically).
    So yes you would only need the front shocks to level the front. The rear’s just add a little better valving vs stock and will allow you to add up to 1-1/2” in the rear if you decide on blocks, aal or whole new pack.
