Not sure how much oil I put in
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ninja89, Aug 7, 2016.
  1. Aug 7, 2016 at 5:24 PM
    ninja89
    ninja89 [OP] HUH?
    I'm not so sure if I hit the mark on this one. V6 1GRFE I wanted to put 5.5qts but I might have put almost a total of 6qts.. Maybe even 6.2qts. It's been sitting for 2 days now and it came out from the dip stick level as shown. Is it good or bad? Any info would help thanks guys
    And btw.. It's just 1inch shy away from the full mark.
    Watari06V6 likes this.
  2. Aug 7, 2016 at 5:33 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I believe it takes 1qt to get from the low mark to the high mark on the stick... looks like your maybe 1/2 to 3/4 of a qt over. Did you start truck/turn off and let it sit for a while, remove stick and wait a good 15 minutes before reinserting? Sometimes it will read high if you don't let the oil drain back down the tube that gets dragged up when removing the dip stick. They say 5.5 but mine takes around 5.2 to hit the full mark.
  3. Aug 7, 2016 at 5:35 PM
    ninja89
    ninja89 [OP] HUH?
    I mean I havnt started he truck for 2 days. If I started the truck I'm afraid I won't get an accurate reading.. Correct me if I'm worng
  4. Aug 7, 2016 at 5:38 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Thats too much. Drain some and recheck. Too much oil in the crank case will cause the oil to foam. Once this happens it doesnt lubricate and cool parts the way it should.
  5. Aug 7, 2016 at 5:38 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    When you filled the oil, did you start the truck to get oil pumped and filled into the filter? If not, you may have the correct amount.
  6. Aug 7, 2016 at 5:47 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Other than the dipstick, why do you think you added too much?
  7. Aug 7, 2016 at 5:48 PM
    ninja89
    ninja89 [OP] HUH?
    I mean how much is too much tho?
  8. Aug 7, 2016 at 5:49 PM
    ninja89
    ninja89 [OP] HUH?
    I started the truck first then checked the oil. And no, I did not start the truck and pumped the oil. I only started the truck once I think I was done adding the oil
  9. Aug 7, 2016 at 5:50 PM
    ninja89
    ninja89 [OP] HUH?
    Just by thinking it over my head and how much I actually put in. I wanna say I put about 6qts
  10. Aug 7, 2016 at 5:52 PM
    08TacoTrD
    08 TRD Offroad
    Just asking because I can't get a real clear reading off the dipstick on my truck to save the world.
  11. Aug 7, 2016 at 5:55 PM
    ninja89
    ninja89 [OP] HUH?
    Lol
  12. Aug 7, 2016 at 5:58 PM
    moondeath
    Pa, Gardners
    Well, whatever the toyota manual says is what is suppose to be max. Yes, you can go a little over, but yours looks like its quite a bit. Is it worth taking a chance? Its pretty easy to just drain a little. I did this on my last fill. The dip sticks are hard to read on these and I wasnt sure how much I had in there. Once I got it to settle, it was over the max mark by about a 1/4". I drained and rechecked until I got it down to the full mark.
  13. Aug 7, 2016 at 6:00 PM
    Markcal
    Markcal Well-Known Member
    I cut diamond groves from the low to full marks and it helped a little, but I wish Toyota would make a dipstick like I had in my last truck, because it was a lot easier to read.
  14. Aug 7, 2016 at 6:03 PM
    08TacoTrD
    08 TRD Offroad
    I've roughed it up petty good but I believe it's the fact it is a good bend in the tube so the oil drags along the stick when you perform a standard dip stick check. Pull it, wipe then pull it again to see the level.
  15. Aug 7, 2016 at 6:10 PM
    moondeath
    Pa, Gardners
    The only real thing I hate about the tacoma is the dip stick set up.
  16. Aug 7, 2016 at 6:13 PM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    How do you not know how much oil you put in? I mean,you physically took off the caps of the individual quarts or the 5 gallon jug right?
  17. Aug 7, 2016 at 6:15 PM
    Markcal
    Maybe try pulling the dipstick, wait a while and check, so the oil drains back and not getting dragged up. I agree, my last trucks dipstick was accurate and didn't have this problem.
  18. Aug 7, 2016 at 6:17 PM
    ninja89
    ninja89 [OP] HUH?
    Yeah I know, but then I started adding abit more then checking the dipstick over and over again. Till i noticed..
    That maybe I added Alittle to much B.
  19. Aug 7, 2016 at 6:21 PM
    Markcal
    That's the reason I prefer the quart size, but it's cheaper in the 5 quart jugs. It might be just me, but I'm never sure trying to read the sight window on the jugs and feel I'm not adding the correct amount.
  20. Aug 7, 2016 at 6:24 PM
    Monkeybutt2000
    Next time just put 5qts in and drive it for a few days. Re-chack and see where you're at. FWIW,I put 5qts in mine and don't worry about it.
