Not sure to go with 885's or 886's???
Discussion in 'Suspension' started by Eesh, Apr 7, 2012.
  1. Apr 7, 2012 at 10:32 AM
    Eesh
    Eesh [OP] Well-Known Member
    Canada
    2025 Tacoma Limited
    I have an Avid front bushbar and a pretty heavy duty skid plate(100lbs) that I'm going to be putting on my truck when I put my lift on. Should I get 885's or 886??
  2. Apr 7, 2012 at 10:42 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    How much lift do you want ?
  3. Apr 7, 2012 at 10:46 AM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    I'd do 885's if I were you. 886's with that weight will add a lot of lift and give you some interesting CV angles.
  4. Apr 7, 2012 at 10:52 AM
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    885's and 886's give the same lift height. The 886's have a heavier spring rate, due to the thicker coils themselves. I have heard mixed opinions on these, and have yet to install my 885's, so I wouldnt be much help for the time being.
  5. Apr 7, 2012 at 10:53 AM
    Eesh
    Canada
    2025 Tacoma Limited
    3 to 3 1/2 inches. I already have the Dakars and I'm going to also add the XL leaf with the Dakars.
  6. Apr 7, 2012 at 11:00 AM
    ross123
    ross123 Well-Known Member
    fort bragg
    I like my 886's check out my truck in the link in my sig. My cv angles are ok. plus I haven't added my steel bumper or skid plates yet.
  7. Apr 7, 2012 at 11:17 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    You probably don't want to go over 3" in the front. Do you really need the XL with the Dakars? Check out this 1st Gen OME - take out the add a leaf?
    I got my lift used (8 months) from a local TWer that had a TRD AC. He had 885s & Dakars until he got a Relentless bumper and winch (also had BudBuilt skids & sliders). When he switched to 886s he "it felt like I was being assaulted, so I went back to the 885s and added a 1/4" spacer".
    I would recommend the 885s with 1/4" spacer and no XL.
  8. Apr 7, 2012 at 11:29 AM
    Eesh
    Canada
    2025 Tacoma Limited
    Ok.. so 885's in the front it is. Anyone know of any pics of a second Gen with Dakars with the XL leaf added???
  9. Apr 7, 2012 at 11:43 AM
    OZ-T
    Peter North
    British Columbia
    The d29xl adds 5/8" to the rear lift .
  10. Jun 29, 2012 at 10:46 PM
    wtbthree
    wtbthree Well-Known Member
    figure I would ask this here before starting yet another 885 vs 886 thread. I have a DC SB and am about to jump on the OME 3" kit.
    I was planning to go with 885 springs, but does running a SC (as I am) add enough weight to require 886s? I'm looking for a full 3" of lift? I'd think not at all, as a full plate bumper is certainly more metal, but just wanted to make sure..
  11. Jun 29, 2012 at 10:48 PM
    OZ-T
    Peter North
    British Columbia
    885's ^^^
    you may only get 2 1/2" though
  12. Jun 29, 2012 at 10:53 PM
    wtbthree
    Hmm, even with the top plate spacers? you're probably right.
    I'll call Toytec and see if they have an opinion. I really want the full 3, but a big part of the reason I'm getting the kit is for ride quality, so wouldn't want to compromise that by going with 886s. finding a weight for the whole SC setup would be ideal - if it's close to w winch, or winch/bumper then it might work out, but I can't imagine is that heavy
  13. Jun 29, 2012 at 10:58 PM
    OZ-T
    Peter North
    British Columbia
    You'll get 2 1/2" without the spacers , 1/4" spacer will add 1/2"
  14. Jun 29, 2012 at 11:04 PM
    wtbthree
    well there ya go....thanks
  15. Jun 29, 2012 at 11:07 PM
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
