Not Sure What Happened
Discussion in '2nd Gen. Tacomas (2005-2015)' started by this_is_nascar, Jan 31, 2015.
  1. Feb 1, 2015 at 12:06 PM
    this_is_nascar
    this_is_nascar [OP] Well-Known Member
    Gloucester City, NJ
    2007 TRD Off-Road
    35 psi, checked before and after service. No way for me to tell. I suspect all are making noise. Definitely not from brakes.
  2. Feb 1, 2015 at 12:07 PM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Why, in all these years with this truck, would I have never experienced this until this time?
  3. Feb 1, 2015 at 12:08 PM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    ... and why noise remain after swapping them back almost immediately? Doesn't make sense to me.
  4. Feb 1, 2015 at 12:09 PM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    I do appreciate all the feedback from everyone.
  5. Feb 1, 2015 at 12:19 PM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    What brand tires are you running? I had Firestone Destinations that did the same thing after rotation & balance at 20,000 miles. I couldn't figure it out for anything. Took it by Tires Plus (where I bought said tires) and they said I needed new axles, rotors, a brake job and some other ridiculous stuff. I laughed and walked out. I got an alignment across the street at Sears and the sound went away.
  6. Feb 1, 2015 at 12:30 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You should run a 'chalk' test to check your tires for proper inflation.
    If you're running stock tires.... 35psi is pretty high. Toyota recommends 29psi.
    Have you tried lowering the pressure to see if anything changes?
    http://www.tacomaworld.com/forum/wheels-tires/133031-trust-bfg-chalk-test-tire-pressure.html
  7. Feb 1, 2015 at 2:18 PM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Yes, I tried lowering the pressure, with no difference. Again guys, been doing the same routine on this truck for 105k miles. On my 3rd set of theses Rugged Trails, so I know how they're supposed to work on my truck. Had the tires rotated probably 20 times without an issue, until now. Balance and wheel alignment when needed and each new set of tires.
  8. Feb 2, 2015 at 11:08 AM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Not sure if these means anything or not, but the noise is the worse at 35 and 60 miles per hour. At other speeds, it's still louder than it was before service, but not as bad at these speeds.
  9. Feb 2, 2015 at 2:27 PM
    Janster
    Jandy
    Lancaster, PA
    Have you lubricated your driveshaft ujoints lately?
    Who's been doing the work on your truck? Take it back to the shop and ask them....
    If you're not seeing anything else and we've all probably suggested just about everything that isn't helping. I honestly don't know what to tell you other than take it back to them....
  10. Feb 2, 2015 at 3:25 PM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Truck has been going to the same Toyota dealer from day one.
  11. Feb 2, 2015 at 3:42 PM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Not sure that they've ever been lubed. I do get the regular maintenance done each 5k miles.
  12. Feb 2, 2015 at 3:50 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    ^^ In other words....no.
  13. Feb 2, 2015 at 3:53 PM
    devkurf
    devkurf Member at Large
    midwest
    better pump some grease in there and see if it changes anything, at least then you can rule that out
  14. Feb 2, 2015 at 4:03 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Did you check all 4 tires to be sure they did not get worn out of round??? Jack up and spin the tires with a ref point off the tires .... I had a prob like this years ago with a car that had f bearings going. After I did the bearings the tires sounded terrible and vibs after repeated balancing. The SHop found mine with a TPD .
  15. Feb 3, 2015 at 5:01 AM
    #35
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    I'm scheduled to take the truck into the dealer, 1st thing Thursday morning. I asked that the Tech test drive the vehicle, with me, so I don't get that standard "I didn't hear anything wrong" answer.
    At a minimum, I'm asking them to visually inspect the Drive Shaft, U-Joints, etc. Since I don't know if the joints have ever been lubed, I'll ask for that to be done. Can you folks think of anything else I should request, assuming that they're not going to find anything right away?
    Again, I appreciate all the help guys. I know I sometimes come off like I'm disregarding your suggestions, but I'm just frustrated. My truck went in without this issue and came out having this problem. The only thing that I can't undo from what they did is the tire balancing. Obviously, I can't get those tires back to how they were setup when I took it in.
    My original service was for the following:
    Oil/Filter Change
    Lube
    Tire Balancing
    Tire Rotating
    Inspect Frame for Rusting Issue
    That was it.
  16. Feb 3, 2015 at 5:31 AM
    #36
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    I agree as stated before. Exposing new tread that has not been run in that direction before, and need to wear in. You said that it had been longer than usual for your rotation, that could be the little extra that you can hear. Just rotate the tires back if it didn't help and wear them in to the new position.
  17. Feb 3, 2015 at 6:24 AM
    #37
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    As mentioned, I did rotate them back and the problem still exists. Also they are rotated from front to back, back to front so they're still spinning in the same direction.
  18. Feb 3, 2015 at 10:20 AM
    #38
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Problem starts at about 35 MPH. from 40 to 60, it's still there, but not terrible. Come 65, it's off the charts, so loud, so annoying. It sounds like you're in an airplane or have huge knobby tires on there. At 75, it quiets considerably, but is still present. Seems to be coming from the front, not the rear.
  19. Feb 3, 2015 at 10:24 AM
    #39
    Old School
    Old School You are ignoring covfefe by this member.
    Best answer so far!
  20. Feb 3, 2015 at 11:11 AM
    #40
    Canufixit
    New England
    Check your Front Diff fluid/tranny fluids also ... Check for color and smell (smell burned, filings, muddy, etc ?)
    Also I'd check the front end for anything loose (loose bolts, bad stabilizer bushings, Broken/loose motor / tranny mount, loose bell housing to engine ....
