Not sure what the problem is....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GREEKBOY12295, Apr 17, 2013.
  1. Apr 17, 2013 at 8:25 PM
    GREEKBOY12295
    GREEKBOY12295 [OP] Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    I am worried that there is something wrong with the transmission/ drive line area. Every time I hit a bump I can feel something hit from under. It feels like someone is punching under the truck against my feet. Drives fine, but this has never happened and worries me. It happens over bumps and turning left and right. It feels like something is loose and wobbly. Anyone know what it could be?
    I have many possible fixes to this, but I cant seem to narrow it down. Under the truck everything looks fine. Please ask me questions so I can possibly get help on narrowing down my problem.
    On a side note I have had popping noises from the suspension for a while now ( I know what they are) but it has never had this "hitting from under problem".
  2. Apr 17, 2013 at 10:44 PM
    BradyT88
    BradyT88 Well-Known Member
    If it is only when you hit a bump, there has to be something loose somewhere... If you can feel it under your feet it is likely somewhere in that area too. Not sure what else to tell you though...
  3. Apr 17, 2013 at 10:45 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Positive its not your carrier barring?
  4. Apr 17, 2013 at 10:45 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Did you check your transmission bolts?
  5. Apr 17, 2013 at 10:46 PM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    I thought it could maybe be the y pipe? But I dont see how that possible if its on all the mounts.
  6. Apr 17, 2013 at 10:54 PM
    BradyT88
    My y-pipe rattles against my skid plate. Those are just rubber mounts. They have some flexibility to them. I doubt it is the y-pipe though. Too light to make much of a bang.
  7. Apr 17, 2013 at 10:55 PM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    Exactly. Looking under doesnt really help me that much. I dont know what to look for because it looks normal under the truck.
  8. Apr 17, 2013 at 11:09 PM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    Have you tried tightening your lca bolts? Mine have become a habit to routinly check
  9. Apr 17, 2013 at 11:12 PM
    BradyT88
    Just start grabbing things and trying to wiggle them. Anything and everything.
  10. Apr 17, 2013 at 11:14 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    your engine is gonna fall off dude. :eek:
  11. Apr 17, 2013 at 11:14 PM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    Actually I tightened down the passenger side one more because it could of been torqued down alot more. Now I need to try the other side behind the skid plate.
  12. Apr 17, 2013 at 11:15 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
  13. Apr 17, 2013 at 11:15 PM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    :pout:
  14. Apr 17, 2013 at 11:18 PM
    BMOC
    Paden
    Phoenix, AZ
    jk, just turn the radio up. problem solved.
  15. Apr 18, 2013 at 8:02 AM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    I personally believe it is the control arms. I bet everything is about shot. I took a right corner and thought my wheel was about to fall off or something.
  16. Apr 18, 2013 at 12:19 PM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    Ill check that today!
  17. Apr 18, 2013 at 2:50 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Lol
  18. Apr 18, 2013 at 6:48 PM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    I dont have the money to fix the problems. I have enough money pretty much for tie rods and lbj. I can do the tie rods on my own, but not the lbj or even the entire LCA then alignment after. Im trying to tell my dad but he doesnt really care, so I guess he will have to wait till the suspension fails and I give him a phone call that my truck is sitting on 3 wheels in the middle of the street.
  19. Apr 18, 2013 at 6:53 PM
    BradyT88
    If you are driving over 35mph more likely upside down in the median/ditch... LBJ failures are quite possibly worse than blowouts...
  20. Apr 18, 2013 at 6:57 PM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    I am going to try to convince my dad to help me out. He doesnt really care about car maintenance that much. He doesnt know anything about a car other than an oil change. It is sad and im not really sure how I even learned all this stuff on my own with no help from anyone (In real life at least). On the other hand the internet has done me well.
