Not taking enough oil?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kacer4, Jul 18, 2018.
  1. Jul 18, 2018 at 7:45 PM
    Kacer4
    Kacer4 [OP] New Member
    Brandon
    2018 TRD Sport
    TRDpro 4Runner wheels
    Hello, first post.
    Today I did my first oil change on the Tacoma after 5000km..Don’t really want to wait 16000. Anyways, the manual says it takes 6.1/6.2 quarts, or 5.7/5.8 liters. Since I’m in Canada, I buy by the litre. I used Mobil 1 which only came in 4.4L jugs as the largest size so I bought 2, dumped one in, then used a 500ML measuring cup and filled it up twice and dumped that in. That should have only been about 5.4 liters of oil but I checked the dip stick anyways and it was just above the second highest dot on the dipstick. So I drove around the block a bit, filled up gas and came home and checked again and it was still at the same level. I dont want to put any more oil in and over fill it. Has anyone else had this issue? I’m sure all the oil was drained prior to filling. Thanks you.
  2. Jul 18, 2018 at 7:56 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The dipsticks in these trucks are pretty hard to read with clean oil, if you properly drained all the old oil out, and then added 6.2 Quarts I would not worry.
    Tacotickler likes this.
  3. Jul 18, 2018 at 8:01 PM
    Bishop84
    Bishop84 Well-Known Member
    You're good, we don't use factory specs in the industry, we memorize the liters sure, but the dipstick is the tool we rely on.
    My gun reads 6.3L on these trucks when I do oil changes, but who knows how accurate it is, I go by the dipstick.
    5,000km is really early but good for the first change. I would suggest just doing it at 10,000k or more, otherwise you're just wasting synthetic oil.
    Also if you're gonna do your own changes look into getting a metal cap for the filter, the older highlanders had it. Way more durable, it makes the changes a lot easier.
    https://www.amazon.com/APDTY-Aluminum-Assortment-Cartridge-Compatibility/dp/B00C8C74RU
    Mr-Paul, MOC221_ and Kacer4[OP] like this.
  4. Jul 18, 2018 at 8:50 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    You are good too go.
    shakerhood likes this.
  5. Jul 18, 2018 at 11:07 PM
    Tacotickler
    Tacotickler Active Member
    16 TRD sport DCSB 4x4 6MT
    Just changed mine for the first time tonight, I thought the same thing iv found that dipstick hard to read since I got the truck even worse with fresh 0w20. I put 5.8L in nd called it good also had to use a strong arm to get the filter housing unscrewed.. I found the dealer the cheapest for oil in can $5.70/L
    MOC221_ likes this.
  6. Jul 19, 2018 at 3:35 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    This^^
    I also bought this tool :
    https://www.amazon.com/Motivx-Tools..._rd_t=40701&psc=1&refRID=8ENT8E55WZB9WYRBKBGF
    shakerhood and Mr-Paul like this.
