Not using TPMS on my winter tires
Discussion in 'Wheels & Tires' started by Fat boy, Nov 16, 2023.
  1. Nov 16, 2023 at 10:57 AM
    Fat boy
    Fat boy [OP] New Member
    Is there anything I should be aware of when I do not use the tire pressure sensors on my winter tires?
  2. Nov 16, 2023 at 10:58 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Your tire pressure.
  3. Nov 16, 2023 at 10:59 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    The little yellow light will show up on your dash about five minutes after you start the truck, and there's no way to extinguish it.
    Other than that, its fine. Just stick electrical tape over it or something.
  4. Nov 16, 2023 at 11:01 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I did that with my 2013 4Runner. You learn to ignore the light.
  5. Nov 16, 2023 at 11:07 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    skippyscage likes this.
  6. Nov 16, 2023 at 3:10 PM
    Go Fish
    Go Fish Well-Known Member
    2022 SR5 4x4 DCLB
    A tire shop may refuse put the rims without sensors on the truck. If you do it yourself, your fine.
    eurowner and YF_Ryan like this.
  7. Nov 21, 2023 at 4:50 PM
    stayalert
    stayalert Member
    Vermont
    2010 access cab Taco with 2.7L 4 cyl. egine and manual trans.
    front receiver hitch from 4x innovations
    Will cruise control work if dash has flashing yellow TPMS light?
  8. Nov 21, 2023 at 6:06 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    it should, yes
    SH10151 likes this.
  9. Nov 22, 2023 at 8:24 AM
    N8tiveTaco21
    N8tiveTaco21 Well-Known Member
    Central Washington
    '10 TRD OR
    OME Dakar leaves, 886 springs, SPC UCAs, Softtopper, GFC Superlite, Caliraised Rock sliders, 4.56 regear w/ Eaton Elocker
    As others have said, the TPMS light will be on constantly, but other than that, everything should work fine. My batteries in my sensors died years ago, and I never cared to have them replaced. I go to the mountains frequently, so I pay attention to my tire pressure anyway :notsure:. When I bought a second set of wheels to have mud tires put on, I had them place a regular rubber valve in just to avoid the extra cost of buying TPMS sensors and calibration. If the light on the dash doesn't bug you, then you should be fine.
  10. Nov 28, 2023 at 1:46 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    @Fat boy what's keeping you from purchasing new sensors for your winter set up?
