Notching Wood
Discussion in 'Off-Topic Discussion' started by jeremy_283, Nov 3, 2011.
  1. Nov 3, 2011 at 8:23 PM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    I need to cut a notch like this in a 3 inch by 3 inch piece of wood. What's the best way to accomplish this?
  2. Nov 3, 2011 at 8:24 PM
    elblako91
    elblako91 Well-Known Member
    Blake
    Lubbock/Houston/Katy
    1992 Toyo Pickup
    Band saw or jig saw would be what I'd use
  3. Nov 3, 2011 at 8:27 PM
    Gieser
    Gieser Official Flatlander
    MB, Canada
    06 tundra yamaha edition
    scion Head Unit and magnaflow muffler...so far
    skill saw and a chisle... well thats what we do on the jobsites anyway.
  4. Nov 3, 2011 at 8:28 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    saw down both ends and chisel out the notch
  5. Nov 3, 2011 at 8:38 PM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    Red Prerunner AC
    Set circular saw to depth of notch. make a dozen or so cuts between your marks to remove as much wood as you can. Then clean it up with a chisel. Easy.
  6. Nov 3, 2011 at 9:01 PM
    jeremy_283
    Ok, I guess I'll try the chisel method
  7. Nov 3, 2011 at 9:05 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    This
  8. Nov 3, 2011 at 10:11 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    X2
  9. Nov 3, 2011 at 10:12 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    Thats what she said
  10. Nov 3, 2011 at 10:14 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    id jig it. run your blade up to the corners. then cut out the inside until you can get your blade turned sideways to cut the top line.
  11. Nov 3, 2011 at 10:15 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    thats what i said
  12. Nov 3, 2011 at 10:20 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Im just here to show off my wood working skills by agreeing with the chisel method:D
  13. Nov 3, 2011 at 10:21 PM
    OZ-T
    Peter North
    British Columbia
    God damn that's a long jigsaw blade to cut 3" deep
  14. Nov 3, 2011 at 10:23 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Sawzall baby!
    or just chisel it, takes all of 3 minutes.
  15. Nov 3, 2011 at 10:24 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    You could use a dado blade on your table saw, would take you like 3-5 passes to cut that out CLEAN, or like the others said run your circular saw through it and chisel it out, OR if you have a really good chop saw(like i do) you can select the height of your blade to come down and run the wood back and forth and side to side and it will eat that notch out in a couple minutes.
  16. Nov 4, 2011 at 6:48 AM
    kris77
    kris77 Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    I don't think he needs to cut 3" deep, just a 3" square piece of wood. Prob only 2" max he would need to cut. Still yet, jigsaw wouldn't be ideal for this, i agree with the above posters, circular saw set to the depth, make about a dozen or so cuts, hammer out the pieces, clean up with chisel.
  17. Nov 4, 2011 at 7:17 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    If he's asking the question. I highly doubt he has a table saw, much less a dado blade for it.
  18. Nov 4, 2011 at 7:23 AM
    OZ-T
    Peter North
    British Columbia
    3" x 3" stock , or at least that's what it says in the OP
  19. Nov 4, 2011 at 7:51 AM
    futuretacoowner
    futuretacoowner Well-Known Member
    Andrew
    Canada
    02 2.7L xtra cab
    circular saw
  20. Nov 4, 2011 at 7:54 AM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    that was my answer...i work in a woodshop, im the supervisor. lol
