Nother lift question, help please
Discussion in 'Suspension' started by matt74, May 16, 2013.
  1. May 16, 2013 at 6:04 PM
    matt74
    matt74 [OP] Member
    TRD
    I hav 2010 extended cab w/ 3 leafs If I get 5100s set at .85 w/ eibach coils and 2" aal will that make my truck level? Thanks
  2. May 21, 2013 at 6:50 AM
    matt74
    matt74 [OP] Member
    TRD
    Bump? Anyone? Coooommee onnnnn, I'm a hot chick
  3. May 21, 2013 at 6:51 AM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    It helps if there is a picture of one. I bet you will be close to level. Most guys run the Eibach's on 0 with a 1.5AAL in the rear and they are good.
  4. May 23, 2013 at 7:52 AM
    matt74
    matt74 [OP] Member
    TRD
    Will that be around 3" of lift though? The lady at toytec said a 2" should make it level but I think it will make the rear slightly higher and I wud rather hav the front higher
  5. May 23, 2013 at 8:25 AM
    ntilehman
    Seth
    Charlotte, NC
    2" in the front if the rear is left alone would make the front higher. Most guys run about 2.5" lift in the front and 1.5" in the rear to get it level. If you have to have the extra .5" then you could try the coils on .85 setting with a 2" AAL. I think the front would be a little higher but you don't mind that. You could make it east and get adjustable coilovers.
