Noticeable engine load from running AC?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by timjb, Dec 14, 2015.
  1. Dec 14, 2015 at 10:02 AM
    timjb
    timjb [OP] New Member
    2015 DCSB TRD 4wd 6speed
    none
    Hi all.
    I upgraded from a F250 7.3L diesel to a 2015 Tacoma (4x, v6, 6-speed) back in February.
    So far everything is great, but I have one nagging question. I find that running the A/C has a very noticeable drag on engine power. I can ask the dealer, but wanted to first ask if others find it easy to notice the A/C is on just due to the truck feeling a bit sluggish. Not a lot, but I'm surprised I can tell.
    I understand my last truck had more torque, but this one is actually higher in horsepower. (Ok, 236 rated instead of 235. But still... :)
  2. Dec 14, 2015 at 10:44 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeah you feel it... It is also one of the things i noticed when i switch to my 2013 taco from a 01 chevy 2500hd with the 6.0L v8.
    I have noticed the more i use it the less noticeable it is... as if the compressor is freeing up etc.
    You will also feel the "bump from behind" when sitting at a stop light and the AC kicks on and the idle goes up a 1-200 rpms.
  3. Dec 14, 2015 at 11:34 AM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    Compressor definitely steals some power. There are a couple choices on the air selector knob that do t run the compressor. Feet and maybe in your face. I only use it when I need it.
  4. Dec 14, 2015 at 11:41 AM
    nd4spdbh
    SoCal
    FYI i have done the mod so that the feet / defrost or defrost only DOES NOT run the ac when selected.... essentially i have manual control over AC regardless of where the air is directed.
    Its a simple quick wire mod in the cab.
  5. Dec 14, 2015 at 11:44 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Do tell.
  6. Dec 14, 2015 at 11:46 AM
    nd4spdbh
    SoCal
  7. Dec 14, 2015 at 11:52 AM
    Monkeybutt2000
  8. Dec 14, 2015 at 3:09 PM
    Newto4x4
    Newto4x4 Member
    Michael
    2006 Tacoma 4x4
    I've notice that 'bump from behind' feel sitting at the light. First time I really thought someone bumped me!
  9. Dec 14, 2015 at 3:57 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It is all about the torque.
  10. Dec 15, 2015 at 7:08 AM
    timjb
    none
    Ok, thanks all for the confirmation that it's normal.
