noticed no gains with afe pro dry s filter?
Discussion in '4 Cylinder' started by scrapedface, Jan 15, 2010.
  1. Jan 15, 2010 at 10:12 AM
    scrapedface
    scrapedface [OP] Well-Known Member
    vacaville, ca
    2008 2.7 liter 4wd tacoma
    ipod charger and aux cable, scanguage 2, wet okole seat covers, 35% tint, toytec ultimate set at 2.5"
    i havnt noticed gains like the 6cyl guys have when they use this drop in filter. other than i can use this filter forever thats the only gain i see. my mpg is the same as well as power and idle. if there is a difference its so minor i dont notice it. have u guys seen a difference?
  2. Jan 15, 2010 at 11:07 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I think a saw 1 or maybe 2 mpg increase.
  3. Jan 15, 2010 at 11:08 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    people say better airflow when cruising, the trucks not working as hard to get air its more free. did you remove the secondary charcoal filter?
    i did and it helped a little
  4. Jan 15, 2010 at 11:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    When cruising, the main contributer to engine pumping loss, is the closed throttle vavle. at 20% throttle (or whatever your at when at cruise), the TV is not opened much at all. The pistons going down to suck in the A/F are pulling against it.....Not the air filter. Given the square inches of surface area of the filter, Its invisible to the engine, unless under WOT. In fact, a guy on here actually dynoed his truck with the OEM filter removed, vs. the filter installed, and IIRC, there was only a couple hp difference.
  5. Jan 15, 2010 at 11:19 AM
    08pretaco
    Oliver
    az
    what about that secondary filter removed? did the guy who did the dyno take that off? i could imagine that it would act by itself as a filter because its so damn condensed and thick looking
  6. Jan 15, 2010 at 11:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No idea. I know they have no impact on the 4.0, but I dont know about the 2.7.
  7. Jan 15, 2010 at 11:47 AM
    08pretaco
    Oliver
    az
    interesting. do you remember the member so i can ask him/her those questions? cause thats interesting. i know that you can only get a certain amount of air into the cylinders without f/i, and the few extra hp would explain that cause the pistons at high rpm's would be cycling at great speeds which an open intake would help getting that air there a little quicker.
    this is why i want to get a scangauge, they arent 100% on say hp rating but doing some tests like this would be really fun!
  8. Jan 15, 2010 at 12:40 PM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    I noticed no gains whatsoever, with the 2nd filter out and the pro dry. Lifetime use is the real benefit.
    By winter, my mpgs are down in the 20~21 territory.
  9. Jan 15, 2010 at 12:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont remember his name, but he posted the Dyno slip in a 2.7 thread. Shouldnt be too hard to find.
  10. Jan 15, 2010 at 2:42 PM
    08pretaco
    Oliver
    az
    ^ thanks chris ill look furhter into it :)
  11. Jan 15, 2010 at 2:43 PM
    afd23a
    The Dynamo of Dixie
  12. Jan 15, 2010 at 2:46 PM
    08pretaco
    Oliver
    az
    ^thanks man. Read it and looks like a little gain in torwue but hp was lost. I'm looking more into torque and willing to sacrific some horses. Kinda would like to know my current reading might have to finally talk myself into a scangauge
  13. Jan 15, 2010 at 4:12 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I haven't noticed any gains (I have 4.0L).
  14. Jan 22, 2010 at 6:10 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    No difference here either. :confused: I got rid of the K&N though, so I have a little more piece-of-mind knowing there is no filter oil in there. :)
  15. Jan 22, 2010 at 9:54 PM
    Plain Jane Taco
    Plain Jane Taco You....out of the gene pool.
    Bill
    USA
    2015 DCSB TRD Sport PreRunner
    This is really the only real benefit to any reusable filter...and that's good enough for me.
  16. Jan 23, 2010 at 6:34 AM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Not much difference either. I have actually put back in my OEM filter. The only difference I have noticed is less intake roar with the Toyota(Denso) filter. I chart my fuel use on Fuelly so if a trend develops it will be noticed.
  17. Jan 25, 2010 at 6:17 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I did other mods first, 1 by 1 to get a feel at the pump what they did. My AfE improved power, but lost mpg. One thing else i did was a 0% throttle clutch letout sorta test. Stock it could kill the engine easily, with the filter it will not die when let out at a seady rate.
    I might pull the filter to get mpg back/ sorta retest. No regrets buying it though.
  18. Jan 25, 2010 at 7:49 AM
    vg05
    vg05 Active Member
    2008 Tacoma SR5 AccessCab
    PIAA 400/500MHz Horn, XRain Wipers
    i removed the charcoal filter and put in a afe pro dry s. so far not much difference.
    how often are you guys cleaning the filter?
