Noticed something strange
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoguy, Dec 22, 2009.
  1. Dec 22, 2009 at 6:09 PM
    Tacoguy
    Tacoguy [OP] Well-Known Member
    Alex
    Chicago
    03 Tacoma PreRunner V6 3.4 TRD
    Bed Liner, Running Boards, Cargo Net, Deck Plate Mod, K&N Air Filter, NGK Iridium Spark Plugs
    In the last couple of weeks I have noticed something really strange with my taco.
    I have noticed that my gas peddle seems to be a lot stiffer. Like it doesnt want to move without more force needing to be applied. It just happened out of the blue. The only thing that I can think that I did differently was using my Rear differential lock for the first time a couple weeks ago.
    Anyone ever have issues like this before?
  2. Dec 23, 2009 at 5:49 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    I can't think of any way using the rear diff lock could have an effect on gas pedal feel ...
  3. Dec 23, 2009 at 5:51 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Your throttlebody may need cleaned. It is also possible the throttle cable is sticking.
  4. Dec 24, 2009 at 7:08 AM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    check under the hood where the throttle cable meets the throttle body assemby and lube that bad boy up, if that fails trace the cable to insure its not stuck on anything
