noticed something weird under the hood. Anyone know what it is?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TenderTacoNipples, Sep 30, 2019.
  1. Oct 1, 2019 at 8:47 AM
    Muddinfun
    Muddinfun Well-Known Member
    Since this piece of aluminum yardstick goes from ~21" to ~28", I am guesing that 28" to 36" was the 1st failed attempt.
    Crazydave and DesertRatliff like this.
  2. Oct 1, 2019 at 8:56 AM
    74cam
    74cam Automotive Engineer
    Michigan
    2010 Tacoma TRD Sport 6spd
    TRD Supercharged, 3 inch lift, TRD beadlock wheels
    Well if you end up taking it off I'll give you a few bucks for it! I've got the supercharger and heard it's a good addition
  3. Oct 1, 2019 at 9:32 AM
    mray
    mray Well-Known Member
    Colorado
    2011 4cyl Base Access Cab 4x4
    LOL...I have that same ruler, but mine is still straight. Gives me an idea for future uses for it.
  4. Oct 1, 2019 at 11:32 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    If you ever get any lean codes or vacuum leaks, this would be the first thing to check. Definitely be careful opening it the first time, who knows how much is in there. Definitely not needed on an NA engine but probably won't hurt anything either. I'm of the personal opinion that oil mist sucked from the crankcase through the intake will provide a bit of upper cylinder lubrication :rofl:
    Grossomotto likes this.
  5. Oct 1, 2019 at 11:36 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Nice bracket.
    Unsubbed.
  6. Oct 4, 2019 at 2:11 PM
    2016Taco
    2016Taco Well-Known Member
    Greater Toronto Area
    2016 Blazing Blue TRD Sport Upgrade DCLB 4X4
    I like the bracket haha, someone got creative
  7. Oct 4, 2019 at 5:49 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Flux capacitor. The ruler is for measuring 1.21 gigawatts
  8. Oct 4, 2019 at 6:40 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    The ruler is for checking the gaps on the spark plugs quickly.
    Rachelsdaddy likes this.
  9. Oct 4, 2019 at 7:25 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I think the ruler mount is a great touch! That's some improvisation!
  10. Oct 7, 2019 at 4:31 AM
    2016Taco
    I read an article a while ago where there were tuning an engine and the catch can made a slight difference. They could see it in the knock sensor tables. The octane rating of fuel was higher with the catch can because the fuel mix was not being diluted with oil vapors. The oil vapors lowered the octane rating thus lowering power output as timing had to be pulled. Now this was for an LS tuned performance engine so not sure if it would make any difference to the taco. I think the LS was blown as well.
    DesertRatliff[QUOTED] likes this.
