Nova Scotia BS Thread
Discussion in 'Canada' started by TacoMitch93, Jun 3, 2014.
  1. Dec 29, 2015 at 5:01 PM
    #3681
    TacoMitch93
    TacoMitch93 [OP] Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    Huh.. Didn't realize I had them on the small one.. Oh well.
  2. Dec 29, 2015 at 6:07 PM
    #3682
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    How did wiring in the horns go?
    I relocated my stockers and now the one acts finicky :(
  3. Dec 29, 2015 at 6:08 PM
    #3683
    Black007
    Black007 I dont know why I'm still here...
    Andrew
    Halifax, Nova Scotia
    2007 Frontier Nismo
    Pipeline was like... not even that fun that day. I was just scared to loose a gas tank and there was no mud. I was sad.
  4. Dec 29, 2015 at 6:09 PM
    #3684
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Is the one you moved the finicky one?
    Did you notice how there's only one wire going to the horn? It's because it's grounded though the body. If you didn't clean the metal where it attaches it's probably not getting a good ground.
    The Hella's have two prongs, one positive and one negative, so to make the wiring work I just made a little ground cable to go from the negative terminal on the horn to the body, NDB.
    AR15xAR10[QUOTED] likes this.
  5. Dec 29, 2015 at 6:10 PM
    #3685
    TacoMitch93
    Mitch
    09 Tacoma SR5
    That and you forgot about 4WD...
    On the plus side I got some pretty cool pictures!
  6. Dec 29, 2015 at 6:11 PM
    #3686
    TacoMitch93
    Mitch
    09 Tacoma SR5
    AR15xAR10 likes this.
  7. Dec 29, 2015 at 6:12 PM
    #3687
    AR15xAR10
    Didn't ground them. Oh fuck.
  8. Dec 29, 2015 at 6:14 PM
    #3688
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Thur ya go by.
  9. Dec 29, 2015 at 6:16 PM
    #3689
    AR15xAR10
    They're in the inner fender behind the fuse box on the driver's side.
  10. Dec 29, 2015 at 6:17 PM
    #3690
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Just ground them and make sure your positive wire is spliced properly and you'll be fine.
  11. Dec 29, 2015 at 6:18 PM
    #3691
    Black007
    Andrew
    2007 Frontier Nismo
    I did forget about that shit once....
    Also Mason, I only have the hi tone horn. It sounds like a homosexual fiat taking a shit. It's bad.
  12. Dec 29, 2015 at 6:19 PM
    #3692
    AR15xAR10
    But as of right now....they aren't grounded....thats problematic if the horn goes off...
    Dunno if they can be grounded to where they are....
  13. Dec 29, 2015 at 6:20 PM
    #3693
    TacoMitch93
    Mitch
    09 Tacoma SR5
    It just means the circuit will be open and the horn won't happen.
    Just make a ground wire and go to LITERALLY ANY METAL PART OF YOUR TRUCK.
  14. Dec 29, 2015 at 6:23 PM
    #3694
    AR15xAR10
    Horns work...because the paint stripped out of the holes when i ran the bolts in...but the ground isn't perfect because maybe one out of ever ten times pushing the horn...one of the two of them (cannot determine if its the high or the low) doesn't produce its sound
  15. Dec 29, 2015 at 6:25 PM
    #3695
    TacoMitch93
    Mitch
    09 Tacoma SR5
    I would just make sure the ground is good and it'll work fine.
    how did you splice the horn wire?
  16. Dec 29, 2015 at 6:26 PM
    #3696
    AR15xAR10
    Didn't. Unplugged the horns. Unclipped the covered wires and pulled the loom up under the battery and under the fuse box.
  17. Dec 29, 2015 at 6:27 PM
    #3697
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Then I'd say you're having a ground issue. I'm amazed you're having issues with that when I just.. made the connector fit on my horn.
  18. Dec 29, 2015 at 6:33 PM
    #3698
    AR15xAR10
    I'm pretty annoyed by it. There should be an included ground strap with its own bolt just like the negative terminal on the battery. But because toyota is fucking retarded, there is not.
    I don't know the first thing about making a ground wire like you said so i'm just going to PUT EM THE FUCK BACK.
    You know i hate wiring/electrical shit
  19. Dec 29, 2015 at 6:35 PM
    #3699
    TacoMitch93
    Mitch
    09 Tacoma SR5
    A ground strap?
    If I'm not mistaken there's a bolt on the back of the horn that is the "negative terminal".
  20. Dec 29, 2015 at 6:35 PM
    #3700
    AR15xAR10
    No idea.
    Ground strap = ground wire
