Nova Scotia BS Thread
Discussion in 'Canada' started by TacoMitch93, Jun 3, 2014.
  1. Apr 19, 2018 at 6:33 AM
    #6741
    TacoMitch93
    TacoMitch93 [OP] Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    Supra has the proper amount of pedals now!
    ravenlord likes this.
  2. Apr 19, 2018 at 6:37 AM
    #6742
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    :yes::bananadance:
    That was pretty quick,
    how long did it take you?
  3. Apr 19, 2018 at 7:01 AM
    #6743
    TacoMitch93
    Mitch
    09 Tacoma SR5
    I've only done the pedals, interior bits and dropped the exhaust. I'm draining the auto tranny right now, then maybe a coffee..
    I have to wait for my buddy dean to get here before I get too far, he'll need to help me take the tranny off the stand and such. If the stand wasn't shoulder height I'd probably be able to manage it on my own. Them trannies aint light.
  4. Apr 19, 2018 at 7:13 AM
    #6744
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    Are we talking
  5. Apr 19, 2018 at 8:05 AM
    #6745
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Gettttttting there
  6. Apr 19, 2018 at 8:14 AM
    #6746
    Canoehead
    Canoehead Well-Known Member
    Duncan
    Dartmouth, NS Canada
    2007 DCSB, lots of scratches
    Rearview mirror upside down mod
    Nice!
  7. Apr 19, 2018 at 9:09 AM
    #6747
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Just two bolts holding the tranny in! Took me forever to figure out how the electrical connectors lock together. Friggen annoying
    D2. likes this.
  8. Apr 19, 2018 at 2:00 PM
    #6748
    MoonKnight
    MoonKnight Well-Known Member
    chris
    Oromocto New Brunswick
    2018 silver Tacoma TRD or
  9. Apr 20, 2018 at 8:42 AM
    #6749
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Got my tires mounted!
    taconick89, Canoehead and Hawco636 like this.
  10. Apr 20, 2018 at 9:29 AM
    #6750
    D2.
    Dan
    Nova Scotia, Canada
    those looks great!
    TacoMitch93[OP] likes this.
  11. Apr 20, 2018 at 10:52 AM
    #6751
    ravenlord
    ravenlord Well-Known Member
    Scott
    Nova Scotia
    Man I love gold and bronze wheels. Looks awesome.
  12. Apr 20, 2018 at 11:44 AM
    #6752
    ravenlord
    Scott
    Nova Scotia
    Does anyone know if the throttle kill when braking can be defeated? Kinda makes left foot braking kinda impossible.
  13. Apr 20, 2018 at 11:54 AM
    #6753
    TacoMitch93
    Mitch
    09 Tacoma SR5
    I've never heard of anyone doing it.
    Why do you want to brake while you're on the gas? I know people do it to build boost but you're NA right? Just curious.
  14. Apr 20, 2018 at 12:57 PM
    #6754
    ravenlord
    Scott
    Nova Scotia
    A, I don't have an LSD so it is a manual way of simulating an LSD.
    B, Dirty burnouts.
    D2. and TacoMitch93[OP] like this.
  15. Apr 20, 2018 at 4:36 PM
    #6755
    D2.
    Dan
    Nova Scotia, Canada
    do you have your traction control engaged while doing this? ( not sure the year of your truck, its not in your sig )
    I know on mine it reduces throttle when traction kicks in, first press of the button stops the throttle kill, and if you are at a dead stop with the traction fully engaged ( like the default setting ) and you press AND hold the traction button then wait for JUST the car with the squigglies underneith to show up, then ALL traction crontrol / computer Nanny stuff is disabled :devil:. Use that one quite a bit in the parking lot at work after a snow storm :rofl:
  16. Apr 20, 2018 at 4:45 PM
    #6756
    D2.
    Dan
    Nova Scotia, Canada
    lookie at what I did!
    _rWS8STGt_t5NDjJ4kx-00Uhfg_X5JQhPLWT_dpc_c987a81ae40b895f4b98d7c3e1a8bd98f29566bc.jpg M5E7x24jLDpt1s8lKLNCPW7Qpr5EVm7WrZ3-SUKW_9568ed9df165da6dfb527daa39de86e339fc6e41.jpg WDF0C-RnphgaMNoy9Qe2ZwWdd0V2uWQcuotJA9WJ_8565753e701112b0ababb9ecba1bea25f0c18e92.jpg
    Its hard to see with the black, but those ridges on the side of the filter wrench are actually drain holes, 4cyl guys feel my pain ( @TacoMitch93 ) during an oil change, oil running down your arm into your arm pit! well no more! with this little beauty, it gets funneled down into where the 1/2" socket is. the socket while inserted blocks the final drain hole until you are ready, simply un plug and let it drain!
    also when the filter is removed, this turns into a funnel that fits over 4l jugs!
    I can't take credit for it, but I did ask the original designer to make a size that fits the OEM 4cyl filter size!
    Full size pics here
    TacoMitch93[OP] and Hawco636 like this.
  17. Apr 20, 2018 at 4:47 PM
    #6757
    D2.
    Dan
    Nova Scotia, Canada
    did you finish it?
    what's it like? inquiring minds want to know.....
    also did you put a new clutch in while you were at it? anything fancy?
  18. Apr 20, 2018 at 5:52 PM
    #6758
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Ouuuu ain't that fancy! I normally crack it and spin it and let it drain into a pan, I normally dont get any oil on my arm!
  19. Apr 20, 2018 at 5:57 PM
    #6759
    TacoMitch93
    Mitch
    09 Tacoma SR5
    I put a 6puck sprung hub in it. With a "light weight" flywheel. Its 14 lbs rather than 17. However these have pull clutches (same style the iS300 had after the R154 swap) so a lot of the mass from the clutch comes from the pressure plate. Its MASSIVE.
    Tranny is full. Neutral safety switch is wired up. Clutch is bled. Just have to adjust the master cylinder. It's pretty well ready to go. Gonna head to the junk yard in the morning for a little pin I overlooked when gathering parts.
    Still need to figure out which wires on the auto harness are for the reverse lights, but I'm getting kicked out of the garage in the morning. So that'll have to wait
  20. Apr 20, 2018 at 5:57 PM
    #6760
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Oh and I have to put the interior back together... flack
    D2. likes this.
