Nova Scotia BS Thread
Discussion in 'Canada' started by TacoMitch93, Jun 3, 2014.
  1. Apr 17, 2019 at 11:42 AM
    #7821
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    nice place.
    1st order of business, swap that door on the clothes washer to be on the other side!
  2. Apr 17, 2019 at 11:54 AM
    #7822
    ravenlord
    ravenlord Well-Known Member
    Scott
    Nova Scotia
    All the appliances belong to the current Tenants. I have my own craptacular appliances that will work fine for now.
    I don't want to put a ton of work into the place as it is a temp home, not a forever home. So redo the bathrooms, install new windows, and finish the back room. Then pick away at everything else as I have time and money.
  3. Apr 17, 2019 at 12:14 PM
    #7823
    TacoMitch93
    TacoMitch93 [OP] Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    Dan said the EXACT same thing when he walked through my house :rofl:
    Took a couple months... but I eventually did it.
  4. Apr 17, 2019 at 2:27 PM
    #7824
    Canoehead
    Canoehead Well-Known Member
    Duncan
    Dartmouth, NS Canada
    2007 DCSB, lots of scratches
    Rearview mirror upside down mod
    Dan is smart.
    TacoMitch93[OP] likes this.
  5. Apr 17, 2019 at 2:51 PM
    #7825
    Snowdog95
    Snowdog95 Member
    Justin
    Nova Scotia Canada
    02 Tacoma 4x4
    I cut a big hole in my fender and installed a snorkel :D
    this means I can drive across the ocean floor now right?
    xjros, mgmdclb, Tertius420 and 4 others like this.
  6. Apr 18, 2019 at 5:55 AM
    #7826
    D2.
    Dan
    Nova Scotia, Canada
    Awesome!
    and I would assume so, Just bring a towel, just in case...
  7. Apr 19, 2019 at 5:25 AM
    #7827
    ravenlord
    Scott
    Nova Scotia
    Inspection made the house look even better than I initially thought. Garage is wired for 220v already, with wire size able to handle 40 amps. So just need a new breaker panel in the garage and a 40 amp breaker for the supply. Then insulate the place and throw some better lighting and I will have a wicked little workshop.
    Just waiting on the water test to come back good. Moving in August provided everything goes well.
  8. Apr 19, 2019 at 8:31 AM
    #7828
    TacoMitch93
    Mitch
    09 Tacoma SR5
    That's awesome!
    Did you get the well flow tested too? When I bought my house the well failed and they had to drill it deeper and replace the pump and pressure tank. Roughly 7500 bucks worth of work, for a 400 dollar inspection (the same people scoped the septic as part of the inspection).
    Canoehead likes this.
  9. Apr 20, 2019 at 6:01 AM
    #7829
    ravenlord
    Scott
    Nova Scotia
    xjros and TacoMitch93[OP] like this.
  10. Apr 22, 2019 at 8:44 AM
    #7830
    Snowdog95
    Snowdog95 Member
    Justin
    Nova Scotia Canada
    02 Tacoma 4x4
    One more peice of the rust free puzzle found!
    and Garmin GPS's suck with anything rural, we ended up going down some old logging road for 15km before coming out on the backside of the sellers road, and had to go another 20km down a dirt/mud road before getting to his house. Pretty much we started on the farthest end of the road way out in St.Andrews, and took this road all the way to the other side to antigonish. oh well
  11. Apr 22, 2019 at 6:02 PM
    #7831
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    FTFY ;) pretty sure we took that same road once only in the opposite direction! Tried to take a shortcut out of Antigonish, missed the St Andrews road by one exit but Google Maps said we could get through. Ended up in a farmer's field lol. He didn't really look twice at us so I figure it wasn't the first time.
  12. Apr 23, 2019 at 11:38 AM
    #7832
    D2.
    Dan
    Nova Scotia, Canada
    :thumbsup:
    truck is looking good
  13. Apr 23, 2019 at 4:29 PM
    #7833
    D2.
    Dan
    Nova Scotia, Canada
    I finished it!
    JLXEhOLkNE36V695pdmAu8L8yVaFxu94FeQpsQEV_909541709e05a3d3d6067af690f6945219be7843.jpg
    Annnndddd then I broke it, like A LOT!
    v7BfUVCBJYsx3LF9zsd-DE-80WEBz-XhEAaaJ3YN_76023b1f69e81c9b67ed228c04cc6a305b8838c6.jpg
    BdizsRFKj9z4P7bsNDuQvPU6dJ5FmSS7VvfdgHnr_4a019de671fe16f1d9672762e024ac7a958af025.jpg
    qe3E8bh1j3uWXyfCWF3epulk64UFgj-bx1zYiHZx_277bb128aaecd774416ef5f25432076a23c30e96.jpg
    The good news is that none of my welds broke! and that round bar is 1/2" solid steel.
    once everything stop deforming, I did manage to pull this off...
    TZofD3uVjQw7IOX5JrKUglZGEYG5g4g9vOGjZnKR_91abcb53725eb14ccba48fa13f977426953f6180.jpg
    its a bit deformed, but If I can get the other stuff to not bend then I think I have a fix for that too.
    scUvQU39q4N5nuFtcXOTx2VTq7Obn4j2RNg_RlVV_49d84dadffd11a655bd30e3f02700bb4f91df78f.jpg
    xjros, [KD], Hawco636 and 2 others like this.
  14. Apr 24, 2019 at 4:37 AM
    #7834
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Well it is a bender!
    You need the flanges where the bars pass through to be tight to one another so there is no bending moment (leverage) on the bar.
    Cool af project
  15. Apr 24, 2019 at 4:58 AM
    #7835
    D2.
    Dan
    Nova Scotia, Canada
    that's exactly what @TacoMitch93 texted me last night! Great Minds....:thumbsup:
    I did lots of cutting and welding last night and did exactly that. The pivot on the die is as tight as I can get ( ended up welding three 1/4" thick plates to the "ears" ). it was hard to see in the pics, but the little short peice that held the pipe tight to the die was pushed down, so a BFH and some 1/4" angle iron was welded in there. The only thing left is to tighten up at the top. I have the steel to do it, but I have to re assemble everything and see which whats best, 1/8" on each side to keep things center, or perhaps a single 1/4" on one side depending on how tweaked things got.
    should be able to button it up tonight and see what breaks next :rofl:
    when in doubt..... make it stout!
  16. Apr 26, 2019 at 5:54 AM
    #7836
    D2.
    Dan
    Nova Scotia, Canada
    update time!!
    the new
    Improved ( aka, more metal )
    Beefcake bender 2.0!
    remember these wimpy 1/4 " angle Iron thingys?
    5kwV82dE305hL2qPKq5GROCygHkRwLW9n-_s9Rx0_2ec46841368ef8ba9cc6d68ec1cf6d30043da516.jpg
    now with 125% more metal! ( alright I'll stop with the infomercial stuff :D )
    psEPVbRXE4uxeVjCYKXy3r1qruoyHQHzQVXVWAEI_009eb619c40e4a87fb1cc7aec87b4e7a4ca69c15.jpg
    xgn-IZnvK-tpPvDZnbwH9iNh4agCtSKCQKtfjONN_b4109a0763cf8291847b5381dc63ff2825e07e64.jpg
    Fully welded in 1/4" angle iron for stoutness
    hACBAGF5kYxCqFieuXsT_QrZNi8rK3mQ_qk5y47f_2af762bc099b96c335991a367d3d53f75acb6db9.jpg
    taking up the slack up top with another 1/4" plate
    68_4QEXXFMwMF8i_DtX2Qor5zh5AD_Rxl74S-Yzc_78e8973dbea838a6ac05908c026e0eb64a0a3043.jpg
    she's Good'N Tight now!
    2KSnRKPg4UEHXsY2uhL55EpDK-rlq7ROBK7zcRR2_7b0589465ac16ce0f6d18f780cc5480c585c14c9.jpg
    The end result?
    Sucess!
    its not a 90 Degree bend, but I think I ran out of stroke on the bottle jack. Also the curve is a bit smooshed, but I think I have a fix for that.
    PS: this MoFo is HEAVY... way over 50lbs. It has to be, my toddler is like 45, and he's a featherweight compared to this beast.
    7YxrZZG283RXjxFCKJmUYa6UxuDNRD1UzJtkETqP_b865f81be73011af7686bb3837530031d190c037.jpg
    Happy Friday!
    :mudding:
    Hawco636, [KD], xjros and 1 other person like this.
  17. Apr 27, 2019 at 1:31 PM
    #7837
    Spillproof
    Spillproof Well-Known Member
    Ken
    Nova Scotia
    2018 Inferno AC OR
    Wow, giving that welder a good workout :) Nice looking fab work.
  18. Apr 28, 2019 at 4:31 PM
    #7838
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    @Canoehead called it :/ Kid I bought it off must have done the brakes after he put his winter rims on because I just put one of the RTXs on and the caliper left a nice scratch in the back of it. :mad: Anybody running spacers want to buy a set of rims?
  19. Apr 28, 2019 at 5:50 PM
    #7839
    Canoehead
    Duncan
    They are very cool rims, people were always gathering around my truck in parking lots when I had them on.
  20. Apr 28, 2019 at 6:07 PM
    #7840
    k.strong
    k.strong \m/ (*.*) \m/
    kirk
    Nova scotia, Canada
    09 Tacoma SR5
    Pictures of the rims?
