Nova Scotia BS Thread
Discussion in 'Canada' started by TacoMitch93, Jun 3, 2014.
  1. Dec 19, 2019 at 7:15 PM
    #8441
    ravenlord
    ravenlord Well-Known Member
    Scott
    Nova Scotia
    Would probably be worth taking a multimeter to the wires to see if they are shorting to one another or to ground. Or just say shag it and replace the sensor on spec.
    I just ordered new tires for the truck. Almost ditched it in my subdivision the other day. If they are good enough for Volvo's in Swedish winters they are good enough for me.
    https://www.gislaved-tyres.com/car/tyres/nordfrost-van
    Also ordered most of the parts I need to get the truck back in decent working order. 312k wasn't kind to the motor and trans mounts. Or the suspension bushings.
  2. Dec 20, 2019 at 12:55 PM
    #8442
    Canoehead
    Canoehead Well-Known Member
    Duncan
    Dartmouth, NS Canada
    2007 DCSB, lots of scratches
    Rearview mirror upside down mod
    I am more worried about the 15 hours of tech time it takes to get to the sensors! I will probably buy a wire harness and sensor to have them on hand before I start. I don't have the downtime to pull the truck off road for a day to disassemble and diagnose, and only then learn what I need to order in. So far it looks like I need all of these:
    17176-0P010 - Air Surge Gasket
    17177-AD010 - Intake Manifold Gasket
    17178-AD010 - Intake Manifold Gasket
    16341-AD010 - Water out Gasket (two of these)
    96761-35031 - O-ring (two of these)
    00272-SLLC2 - Super Long Life Coolant
    just to get so I can reach this: 82219-0C010 - wire sensor
    Credit to @08TacoTrD for the part numbers and list
  3. Dec 21, 2019 at 4:13 AM
    #8443
    TacoMitch93
    TacoMitch93 [OP] Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    How many cars do you need for a fleet? I'm working my way there
    Canoehead likes this.
  4. Dec 21, 2019 at 4:24 AM
    #8444
    Canoehead
    Duncan
    Nice colour!
  5. Dec 21, 2019 at 4:47 AM
    #8445
    TacoMitch93
    Mitch
    09 Tacoma SR5
    I like the blue too!
  6. Dec 22, 2019 at 7:40 AM
    #8446
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    I like that little patch of red on the grill best
  7. Dec 23, 2019 at 6:11 AM
    #8447
    ravenlord
    Scott
    Nova Scotia
    Hit my 4WD switch today and all I got was blinken lightsn. Replace the actuator I don't hear moving or replace Tcase with FJ one?
  8. Dec 23, 2019 at 7:16 AM
    #8448
    Canoehead
    Duncan
    I have found mine to be fussy at times. Wiggle the steering wheel a little at roughly straight, reverse a little then forward gently, switch back to 2wd and try again are all things that have worked. Do you have the 2lo mod?
    I'm sure you've done all these, just thought I'd throw it out there anyway.
  9. Dec 23, 2019 at 10:23 AM
    #8449
    MoonKnight
    MoonKnight Well-Known Member
    chris
    Oromocto New Brunswick
    2018 silver Tacoma TRD or
    what year ? Cancel last
    I don’t know what the issue would be with 2nd gens
    I had a 1st gen that would do this all the time when I needed it most
    what was recommended to me was the actuator something in them comes loose and normally just has to be re-Soldered
    I was watching this the other day to
    https://m.youtube.com/watch?v=SMsan3BzZkE
    Starts at 9:27
  10. Dec 23, 2019 at 1:47 PM
    #8450
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Check your wiring first - there was a bracket rusted out on mine that held the last connector before the front diff. Zip tied the connector to the frame and it hasn't blinked since.
    Oh and electrical cleaner and di-electric grease helps too
  11. Dec 23, 2019 at 3:59 PM
    #8451
    ravenlord
    Scott
    Nova Scotia
    Ya, I didn't get a chance to put the multimeter to it today, but that was the plan. First make sure I have no shorts and it is getting voltage. Other than that I am probably going to lock it into 4wd for the winter and deal with it properly in the spring.
  12. Dec 24, 2019 at 3:33 AM
    #8452
    TacoMitch93
    Mitch
    09 Tacoma SR5
    If the actuator is seized, it is 100% more cost effective to swap in an FJ tcase.
    Or, atleast that's what I keep telling myself (especially since its a direct bolt in for me).
  13. Dec 25, 2019 at 8:08 AM
    #8453
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Merry Christmas fellas!
  14. Dec 25, 2019 at 9:12 AM
    #8454
    Canoehead
    Duncan
    Merry Christmas!
    TacoMitch93[OP] likes this.
  15. Dec 25, 2019 at 1:28 PM
    #8455
    Canoehead
    Duncan
  16. Dec 25, 2019 at 5:19 PM
    #8456
    Hawco636
    Hawco636 Great White North
    2010 MGM SR5 - V6 Manual
    Merry Christmas!
    No truck parts, but I got a front door for my house which is super nice. I'll post up pictures when it's installed
    TacoMitch93[OP], [KD] and Canoehead like this.
  17. Dec 26, 2019 at 11:29 AM
    #8457
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Not exactly a Christmas present but my wife thought it would be funny to put my new hub assembly under the tree for me :p20191219_174335.jpg
  18. Dec 26, 2019 at 11:32 AM
    #8458
    Canoehead
    Duncan
  19. Dec 27, 2019 at 7:36 AM
    #8459
    ravenlord
    Scott
    Nova Scotia
    Anyone with a RWD or Prerunner 2nd gen need a transmission mount. I fat fingered the wrong part from rock auto and isn't worth shipping back. $20.
  20. Dec 31, 2019 at 9:09 AM
    #8460
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Got a 5% rock auto discount code in the mail if anyone is parts shopping:
    Code: 127514230111068065
    Thank You for Being a RockAuto Customer!
    Using your discount code is easy! Enter your discount code in the 'How Did You Hear About Us?' box without any other numbers or characters for an additional 5% savings. Discounts cannot be applied once an order is marked as shipped.
    Your code expires on March 1, 2020, so do not wait!
    SHOP NOW
    Share Your Code!
    There is no limit on order size or number of orders - use your code on your next order, and share it with your friends and family
