Nova Scotia BS Thread
Discussion in 'Canada' started by TacoMitch93, Jun 3, 2014.
  1. Aug 19, 2020 at 8:50 AM
    #8841
    gnewman545
    gnewman545 Well-Known Member
    Gary
    2013 Red DCLB
    BWG Winch Plate Teck Deck K&N Vent Filter
    [KD][QUOTED] likes this.
  2. Aug 19, 2020 at 9:18 AM
    #8842
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Gives you an idea of what they're worth anyway
  3. Aug 19, 2020 at 4:51 PM
    #8843
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    So this is a first - wife's Kia was making a rotational scraping noise after braking. Took the caliper off and there was wear on the clips that hold the pads in, where they cross the inside of the caliper. Meant to take a picture but forgot, anyway seems like the rotor has grown by means of rust to the point where it's near to rubbing on the inside of the caliper. I beat it with a hammer and there was an outside rim of rust that just came right off and to look at it now you'd never know. Anybody ever come across something like that and will beating on the rotors cause them to explode next time she's on the highway?
  4. Aug 19, 2020 at 4:57 PM
    #8844
    TacoMitch93
    TacoMitch93 [OP] Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    Chipping the rust off the rotor is a pretty normal part of a brake service! Provided you weren't beating on it hard enough to crack it I'm sure it's fun!
    Snowman and [KD][QUOTED] like this.
  5. Aug 19, 2020 at 5:01 PM
    #8845
    Canoehead
    Canoehead Well-Known Member
    Duncan
    Dartmouth, NS Canada
    2007 DCSB, lots of scratches
    Rearview mirror upside down
    And i bet Mitch even meant *Fine!
    I also think you are totally okay, but my opinion should mean nothing to you.
    Did you blast everything with brake cleaner and lube the sliders? If you didn't, you are still totally okay from a safety perspective. In my untrained opinion.
    TacoMitch93[QUOTED][OP] and [KD] like this.
  6. Aug 19, 2020 at 5:05 PM
    #8846
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Opps, I absolutely did mean fine!
    [KD] likes this.
  7. Aug 19, 2020 at 5:56 PM
    #8847
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Fun works too :D
    I meant to hit it with brake cleaner but all of a sudden the caliper was back on and oh well, my hands weren't that greasy.. I took it for a test drive and it felt normal. What do you mean by lube the sliders?
  8. Aug 19, 2020 at 6:35 PM
    #8848
    TacoMitch93
    Mitch
    09 Tacoma SR5
    The Kia would have floating calipers. When the piston actuates, it pushes one pad against the rotor, and pulls the other pad against the rotor.
    There are (generally) two sliders that connect the two halves. During a service you'd take the sliders out and clean the gunk off them, and then lube them with some sort of silicone based lube (oil based lubes will swell the rubber boots and can cause the sliders to leak and seize).
    (not my picture)
    D2. and [KD][QUOTED] like this.
  9. Aug 21, 2020 at 5:33 AM
    #8849
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    toyotapartsdirect.ca
    I've ordered stuff from them, easy peasy
  10. Aug 21, 2020 at 5:41 AM
    #8850
    D2.
    Dan
    Nova Scotia, Canada
    I really hope I just suck at searching for parts :(
    I could not find the part number for it
  11. Aug 21, 2020 at 11:00 AM
    #8851
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Offered that guy with the 05 ACLB $650 for the gearbox and t.case (incl new clutch but no actuator) and the steering rack and tie rods. Good deal you think?
    D2. likes this.
  12. Aug 21, 2020 at 2:57 PM
    #8852
    TacoMitch93
    Mitch
    09 Tacoma SR5
    That seems pretty good, the going rate for a junk yard trans is 850-1200 bucks!
    [KD][QUOTED] and D2. like this.
  13. Aug 21, 2020 at 3:31 PM
    #8853
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    I haven't picked it up yet, quick delete this post!
    Lol, I thought it was an ok price but it's not in the truck so I'm buying it on faith.
  14. Aug 22, 2020 at 6:27 PM
    #8854
    ravenlord
    ravenlord Well-Known Member
    Scott
    Nova Scotia
    What's the best wheel bearings to go with for the 2nd gens? Mine are starting to make noise so I should probably do them before winter.
  15. Aug 22, 2020 at 6:41 PM
    #8855
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    Koyo make them for Toyota. They are fairly reasonably priced and easy to come by
  16. Aug 22, 2020 at 7:01 PM
    #8856
    ravenlord
    Scott
    Nova Scotia
    I am looking at the Dorman hub assemblies out of pure laziness. Probably source an NSK/ SKF/ FAG bearing once they let go and rebuild the hubs at my leisure. Just hurts looking at the 400 dollar price tag for the pair.
    TacoMitch93[OP] likes this.
  17. Aug 23, 2020 at 11:33 AM
    #8857
    TacoMitch93
    Mitch
    09 Tacoma SR5
    That's not too bad honestly.
    The bearing is like 120, Toyota seals will run you ~50ish so you're looking at almost 200 bucks a side.
    Those numbers are from when I last did a wheel bearing, and also they're from memory.
  18. Aug 23, 2020 at 3:00 PM
    #8858
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Rock Auto have NSK assemblies for $100 - add taxes, shipping and t world discount and you're into it for $250
  19. Aug 23, 2020 at 3:37 PM
    #8859
    TacoMitch93
    Mitch
    09 Tacoma SR5
  20. Aug 24, 2020 at 3:50 AM
    #8860
    D2.
    Dan
    Nova Scotia, Canada
    @Canoehead currently has the doorman's IIRC, Perhaps he can comment on them.
