Nova Scotia BS Thread
Discussion in 'Canada' started by TacoMitch93, Jun 3, 2014.
  1. Jan 15, 2021 at 7:05 AM
    #9181
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    66 lbs,
    I'm guessing its some extra leafs for the rear
    the box looks to be the same length as what I received mine in.
    *edit* I was thinking canopy, but it looks to be too short for that
    [KD][QUOTED] likes this.
  2. Jan 15, 2021 at 7:08 AM
    #9182
    D2.
    Dan
    Nova Scotia, Canada
    New tires are now in my driveway.
    its taking considerable restraint to NOT put them on this very moment, but to sit at my desk and check a few things off my list of "to-do's" ( work )
    perhaps I'll wisely use my lunch break and slap those puppies on! :bananadance:
    ACtC-3eMMF7QxRI7m-uueSN_gL5W-AQcsxZ-FcaN_50433f9f7f0d1fc81da8d2e2aee8cfbdf352edd9.jpg
    ACtC-3cSAXf1am4VfBIjU2NYl5n5EOYvluMmlzy1_cc078bec6af224f7253bbaa97e28dbce1c47574f.jpg
    Fahrenheit and [KD] like this.
  3. Jan 15, 2021 at 9:40 AM
    #9183
    D2.
    Dan
    Nova Scotia, Canada
    All done!
    ACtC-3eY06dkxi12VHIUfTvr2E0YPjJ7RLOfJeSA_c258177b92d2d29a3b1220f77d5b057bbf40dfeb.jpg
    Man it looks good!
  4. Jan 15, 2021 at 9:50 AM
    #9184
    Canoehead
    Canoehead Well-Known Member
    Duncan
    Dartmouth, NS Canada
    2007 DCSB, lots of scratches
    Rearview mirror upside down mod
    Too clean though... need mud now!
    Awesome
    [KD], D2.[QUOTED] and TacoMitch93[OP] like this.
  5. Jan 15, 2021 at 11:11 AM
    #9185
    D2.
    Dan
    Nova Scotia, Canada
    what I need is more metal to finish my Sliders.
    got one slider all welded up, just need some more metal before I dig into the other one.
    I'm heading out soon to get that done so I can hack away at it this weekend.
    Canoehead[QUOTED] and [KD] like this.
  6. Jan 16, 2021 at 8:01 AM
    #9186
    k.strong
    k.strong \m/ (*.*) \m/
    kirk
    Nova scotia, Canada
    09 Tacoma SR5
    Baby got rack
  7. Jan 16, 2021 at 12:14 PM
    #9187
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Ha! Called it :D
    Nice rack ;)
  8. Jan 22, 2021 at 1:57 PM
    #9188
    TacoMitch93
    TacoMitch93 [OP] Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    Ohhhhh buddy!
    Fahrenheit and Canoehead like this.
  9. Jan 22, 2021 at 2:00 PM
    #9189
    Canoehead
    Duncan
    Oh yeah!
    time for a run!
  10. Jan 22, 2021 at 3:32 PM
    #9190
    Fahrenheit
    Fahrenheit Well-Hung Member
    Garth
    NS
    I'm not going to pretend I know anything about the 4banger engine, but, that TB looks like it can breath very well now!
  11. Jan 22, 2021 at 4:36 PM
    #9191
    D2.
    Dan
    Nova Scotia, Canada
  12. Jan 22, 2021 at 7:09 PM
    #9192
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Its finally going back together after an extended period with the head off hahahah
    [KD] likes this.
  13. Jan 22, 2021 at 7:09 PM
    #9193
    TacoMitch93
    Mitch
    09 Tacoma SR5
    [KD], D2.[QUOTED], maritimer8 and 2 others like this.
  14. Jan 25, 2021 at 1:57 PM
    #9194
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    There isn’t a NB section but this made me laugh
    maritimer8, D2., Fahrenheit and 2 others like this.
  15. Jan 25, 2021 at 5:09 PM
    #9195
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Sounds like my house. One thing leads to 100 others “while I’m doing that”
    [KD] likes this.
  16. Jan 25, 2021 at 7:12 PM
    #9196
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Mine to, except the "that" usually ends up not getting done cos I get distracted by all the while I'm doing that's :rolleyes:
  17. Jan 26, 2021 at 11:22 AM
    #9197
    D2.
    Dan
    Nova Scotia, Canada
    well my idler pulley bearing has been shot for 2 years, I figured it was time to replace it a few weeks ago since the part has been sitting on my shelf for about the same amount of time :rofl:
    all was going "OK" until I tried to give it that little extra smidge of push. the bloody cast in socket head broke off. Its pretty clear the Gates replacement part is no where near the same OEM quality ( shocker right? )
    so that lead me to try and find a replacement bearing. on the 2TR, the factory numbers off the bearing are:
    NSK 6203DG8
    engraved on the outer race - 6203A30
    Inner race - 6203A26
    ID - 17mm
    OD - 40mm
    Width ( thickness ) - 12mm
    I can't seem to find an exact NSK replacement based off those numbers, but what I did find was that 6203 bearings all pretty much have the exact same measurements.
    the only thing I was extra aware of the max RPM's of the bearings. Some were only rated for 12,000 RPM's. the one I chose off Amazon is good to 20,000 ( I Have no idea what RPM it spins at now, but figured that I'd go as high as I can just to error on the side of caution )
    my amazon bearing should be here on Thursday and I'll let you all know how it goes!
    [KD] and Canoehead like this.
  18. Jan 26, 2021 at 1:17 PM
    #9198
    Canoehead
    Duncan
    It would be awesome if we could find bearings designed to run under water.
    TacoMitch93[OP], Fahrenheit and [KD] like this.
  19. Jan 27, 2021 at 8:14 AM
    #9199
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Don't even get me started on the house.....
    Anyone wanna help me carry a slab to the basement?
    [KD], Fahrenheit and D2. like this.
  20. Jan 27, 2021 at 10:21 AM
    #9200
    TacoMitch93
    Mitch
    09 Tacoma SR5
    6203
    6 means its a single row ball bearing
    2 duty rating (Also dictates the outter diameter)
    03 is the bore size
    The letters at rhe end indicate whether or not they're sealed or shielded or both (generally)
    [KD], Canoehead and D2.[QUOTED] like this.
