Now another issue lol Would like some input
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyotaHunter, Sep 7, 2019.
  1. Sep 7, 2019 at 11:10 AM
    ToyotaHunter
    ToyotaHunter [OP] Well-Known Member
    2003 Toyota Tacoma TRD
    Hey guys thats the battle of having a tacoma thats hadn't been run all winter lol. i sloved the clunk i was having after a releasing the brake pedal after at stop now a new issue has arrived.
    I have a wush wush wush sound that comes and goes especially at low speed coming from the from passenger side sounds like a bad wheel bareing or an old rust rotor but the thing is i replace the whole hub and wheel baring assembly and i have all new rotors pads and calipers thinking it was that it didnt brakes by the way thats why i put in new studf and the wush wush sound is still there its annoying the crap out of me at low speed but on the high way to sound its quit ..
    any imput will help if anyone had that issue before. my truck is a 2003 double cab 4x4 automatic trd 3.4
  2. Sep 7, 2019 at 12:52 PM
    NvrSyNvr
    NvrSyNvr Well-Known Member
    Jim
    2000 Green PreRunner Xcab V6 Auto w/locking diff
    Hayden 678 Transmission Cooler
    One possibility would be the metal cover on the back side of the brake rotor. They are easy to bend when working around the brakes or when removing or replacing the wheel. When bent they can contact the rotor and make kind of a metallic scuffing noise. I had it happen recently. I just removed the wheel and found the spot where the cover was closest to the rotor and lightly bent it back. Good Luck!
    License2Ill and Rachelsdaddy like this.
  3. Sep 7, 2019 at 1:00 PM
    ToyotaHunter
    i double checked that i thought it was that as well but nothing there i even bent the dust shield i little further just in case but that didnt do anything
  4. Sep 7, 2019 at 3:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Man, I'd like to help but couldn't understand due to the long run on sentence :confused:
    TWJLee likes this.
  5. Sep 7, 2019 at 3:23 PM
    ToyotaHunter
    sorry basically i have a wush wush wush sound at low speed coming from the front passenger. its now wheel bareing because its new or bracks because they are new as well or the dust shield
  6. Sep 9, 2019 at 1:01 PM
    ToyotaHunter
    found the issue of mysterious wushing sounds it ended up being the rear passenger axle that was grinding its a bit bent.... now on the hunt for one
    jackn7 likes this.
  7. Sep 9, 2019 at 6:27 PM
    NvrSyNvr
    Jim
    Glad you found the source of the issue. I use this site to search for used parts in yards near and far. http://www.car-part.com Searching for rear axle assy allows you to select the ratio and with or without a locker. Even if you don't use one of the yards in the results it can give you an idea of the cost in your area.
