NOW AVAILABLE, All New Redesigned HS 3 Leaf AAL
Discussion in 'HeadStrong Off-Road' started by HeadStrong Off-Road, Mar 23, 2020.
  1. May 22, 2024 at 1:29 PM
    #281
    Mason502
    Mason502 Well-Known Member
    Mason
    Kentucky
    2015 Tacoma 4x4 Access Cab 2.7 Automatic
    Bilstein 5100 shocks, cali raised LED.
    I’ve had this kit for long time now, not impressed with the product nor the sales team, started having issues about 20k miles or so. Get a fully upgraded leaf pack or stay stock.
  2. May 22, 2024 at 1:46 PM
    #282
    rybern
    rybern Well-Known Member
    N Alabama
    2025 TRD OR & 2000 SR5
    What kind of issues were you having?
    I've only had mine for nearly 1.5 years and 16k miles but outside of squeaking (which I think I have resolved) I've been very happy with mine. Having said that, I don't haul around a bunch of extra weight.
    Mason502[QUOTED] likes this.
  3. May 22, 2024 at 1:55 PM
    #283
    Mason502
    Mason
    Kentucky
    Well the leaf spring clip or bracket that holds the brake line got extremely loose sounds awful driving because it sounds like a spray paint can going down the road, I haul a trailer 8x5 ft. With a 48inch mower once every two weeks and combined weight of 1200 pounds it sags quite a bit. But to also mention when going through a sharp turns there is no sway in the rear which is nice but overall with my experience I went back to stock for temporary purposes.
  4. Jun 18, 2024 at 8:42 PM
    #284
    Lunchmeat79
    Lunchmeat79 Well-Known Member
    Kansas
    '18 Off Road
    Has anyone ran this on the TRD OEM lift kit instead of the spacer block? I ordered the Icon AAL a couple days ago then found this. Looks like a good alternative. Running a shell and a decked box in the bed. Maybe 300 lbs extra weight. Also ordered 3 degree shims. Are they used on this spring set?
  5. Jun 19, 2024 at 4:33 AM
    #285
    rybern
    N Alabama
    I'm running this with 5100's and very happy with it but I didn't add any weight. See the link below if you care about preventing leaf pack squeak while your doing this:
    https://www.tacomaworld.com/threads/2023-mgm-trd-off-road-mildly-modded.787908/page-6#post-29926632
    Lunchmeat79[QUOTED] likes this.
  6. Dec 24, 2024 at 3:39 PM
    #286
    jmferg
    jmferg Well-Known Member
    I am picking up a set of these. In regards to the 1/2" spacer, i can simply cut my overload to the length of the perch and achieve the same thing? Seems like a waste to throw them away.
  7. Dec 24, 2024 at 4:09 PM
    #287
    rybern
    N Alabama
    Yes, I've read of other guys that have done the same thing. It's like adding a 5/8" lift block.
    If your bothered by squeaks then do your self a favor at add these liners between the AAL's. I went back and added them after the fact and GREATLY wished I would have added the liners it from the get-go.
    jmferg[QUOTED] likes this.
