NOW AVAILABLE: Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics
Discussion in 'Diode Dynamics' started by Diode Dynamics, Nov 16, 2021.
  1. Nov 16, 2021 at 9:10 AM
    Diode Dynamics
    Diode Dynamics [OP] Automotive Lighting Experts Vendor
    St. Louis, Missouri
    There's plenty of ways to add light behind your vehicle, but the new Universal Stage Series Reverse Light Kit stands out with innovations in both function and ease of use. This kit allows you to mount two flush mount SSC1 or SSC2 LED pods in your rear bumper, adding a high-power reverse light, along with a red accent light. With the included wiring harness, this kit connects to your vehicle's wiring for simple, everyday operation.
    Focused: Most LED pods on the market, even certain premium options, use outdated technology like reflectors or simple lenses that lose light internally and to glare. By comparison, our custom-engineered total internal reflection (TIR) optic collects all of the light from the LED chips, drastically reducing wasted light and improving total efficiency.
    While other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the Stage Series LED pods serves as both the optic and main lens for greater efficiency and light output (patent pending). Thanks to this innovative feature, when coupled with high-intensity LED chips, the total intensity of the Stage Series Pod is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
    Simple connections. The included wiring harness allows you to connect this kit to your vehicle's wiring for simple, everyday operation. The kit operates as an additional red accent light, with your tail lights, and then automatically switches to a high-power backup light when your vehicle is in reverse. The included toggle switch allows you to override the vehicle signals and turn on the main beam anytime.
    Each kit will include:
    Two (2) SSC1 or SSC2 Flush Mount LED Pods
    One (1) Universal Reverse Light Wiring Harness
    Two (2) Flush Frame Gaskets
    Ten (10) Zip Ties
    Two (2) T-Taps
    Mounting hardware and drilling template
    Functional Patterns. All Stage Series beam patterns were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern.
    Flood pattern was designed to provide uniform, even illumination with a full 50x50 degree spread of light on the SSC1 LED pod, and a 60x60 degree spread on the SSC2 LED pod. Unlike generic "flood" lights that are simply a heavily diffused spotlight, our flood pattern uses pillow optics on the outer lens surface, to provide a true optically designed spread, for even illumination throughout.
    Backlight Functionality. The Stage Series LED pods included with this kit feature a distinctive backlight in a vibrant red color which functions as an additional accent light while driving! The backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
    Sport or Pro. Stage Series LED pods are available at two different power levels. Both options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. However, the Pro option is double the amount of total power. Click the Specifications tab to see more information!
    Proven Reliability: Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
    If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com.
    PM us for the free-shipping code (U.S. forum members only)
    John C.
    Diode Dynamics
    Grand Inquisitor and Bravisimo like this.
  2. Nov 16, 2021 at 11:03 AM
    Bravisimo
    Bravisimo So many mods, very little money.
    Joe
    Santa Clarita, CA
    2014 Tacoma PreRunner SR5 DCLB
    Tint, headlights wrapped & rear lights smoked, power outlet mod., grill & rear bumper wrapped, Falken A/T 3W,
    WOW! NICE! I like these! Nice work guys! Question, Can we use a different switch than the one provided?
    Now all need now is a new armor bumper to slam on these bad boys. Definitely going together these once I get a new rear bumper.
  3. Nov 16, 2021 at 2:13 PM
    Diode Dynamics
    St. Louis, Missouri
    Great question!
    Yes, you could use a different switch than the one provided with our harness.
    John C.
    Diode Dynamics
    Bravisimo[QUOTED] likes this.
  4. Nov 19, 2021 at 9:29 AM
    Diode Dynamics
    St. Louis, Missouri
  5. Jan 12, 2022 at 9:44 AM
    Diode Dynamics
    St. Louis, Missouri
    FREE CALENDAR ALERT!
    For a limited time with every $300 purchase, we're throwing in our new 2022 Diode Calendar!
    Plus, all forum US forum members are eligable for a free shipping promo code. Just PM us!
  6. Feb 4, 2022 at 11:43 AM
    Diode Dynamics
    St. Louis, Missouri
    Did you know?
    We offer our Universal Reverse Light Wiring Harness separately to pair with any of our Backlit Stage Series LED pods!
    There have been many customers custom mounting our standard (non-flush) pods to their vehicle using our universal mounting brackets and hardware to factory mounting locations!
    Please, feel free to let us know if you have any questions!
    John C.
    Diode Dynamics
  7. Apr 13, 2022 at 9:40 AM
    Diode Dynamics
    St. Louis, Missouri
  8. May 26, 2022 at 12:55 PM
    Diode Dynamics
    St. Louis, Missouri
    Diode Dynamics’ Memorial Day Sale is going on NOW through Friday, 6/3.
    Get 15% off all LED lighting upgrades with code "USA22" during checkout!
    Plus, all orders over $300, will receive FREE shipping.
    Click HERE to shop Diode Dynamics LED Lighting products!
    Note: Products on pre-order (Elite Series Fog Lamps) are excluded from this sale.
  9. Jun 3, 2022 at 1:49 PM
    Diode Dynamics
    St. Louis, Missouri
    Don't miss your chance to save 15% off your entire order of lighting upgrades!
    Coupon Code: USA22
    Plus, get FREE shipping when you spend $300! HURRY, this sale ends TONIGHT!
    Click HERE to Shop!
    Sale ends 11:59 p.m. CST | Friday, 06/3/2022.
    Note: Items on pre-order are exempt from the sale.
  10. Sep 6, 2022 at 12:09 PM
    Diode Dynamics
    St. Louis, Missouri
    The clock is ticking!
    Hurry! There are ONLY 3 DAYS LEFT to save on your favorite LED lighting products from Diode Dynamics.
    Click HERE to shop!
    John C.
    Diode Dynamics
    Sale ends 11:59 p.m. CST on Friday, 9/9/2022. Cannot be combined with other coupon codes.
  11. Mar 6, 2023 at 9:09 AM
    Diode Dynamics
    St. Louis, Missouri
    Our Spring Sale is LIVE! Visit our website to SAVE!
    ➡ Up to 15% OFF All Lighting Upgrades
    ➡ 15% OFF Stage Series Rock Lights & HitchMount LED Pods
    ➡ 10% OFF Elite Series JL/JT Headlights
    ➡ Free US Shipping on any order over $300!
    No coupon code is required.
    Click HERE to shop your ride!
    John C.
    Diode Dynamics
    Sale ends 11:59 p.m. CST on Monday, 3/13/2023. Cannot be combined with other coupon codes. Excludes items with pre-order status.
  12. Mar 10, 2023 at 12:29 PM
    Diode Dynamics
    St. Louis, Missouri
    ⌛THE CLOCK IS TICKING... ⌛
    NOW
    is your chance to SAVE up to 15% sitewide on your favorite Diode Dynamics LED lighting products.
    Up to 15% OFF LED Lighting Upgrades
    CLICK HERE TO SHOP NOW
    Did you know?
    You can find all of the products we offer for your vehicle using our vehicle finder tool! Simply enter the year, make, and model.
    SALE EXPIRES 11:59 P.M. MONDAY, MARCH 13TH, 2023.
    Discounts cannot be combined with other offers or any previous orders. Excludes items with pre-order status.
  13. May 9, 2023 at 11:42 AM
    Diode Dynamics
    St. Louis, Missouri
  14. May 25, 2023 at 12:51 PM
    Diode Dynamics
    St. Louis, Missouri
    Our Memorial Day Sale is LIVE!!! ​
    ➡ Up to 15% OFF Sitewide
    10% OFF JL/JT Elite Series Headlights
    ➡ Free US Shipping on any orders over $300!
    Excluded: F150 Elite Series Headlights, and F150 Elite Series Fog Lights
    John C.
    Diode Dynamics
    Hours: Monday-Friday 10 a.m. - 5 p.m.
    Email: contact@diodedynamics.com
    Phone: 314-205-3033
    Sale ends 11:59 p.m. CST on Friday, 6/2/2023. Cannot be combined with other coupon codes.
  15. Jun 1, 2023 at 9:37 AM
    Diode Dynamics
    St. Louis, Missouri
    ⏳ WARNING! TOMORROW IS THE LAST DAY TO SAVE! ⏳
    FREE US Shipping on any order over $300!
    Click HERE to shop lighting upgrades for your ride!
    Sale ends 11:59 p.m. CST on Friday, 06/02/2023. Cannot be combined with other coupon code
    John C.
    Diode Dynamics
    Phone: 314-205-3033
  16. Jun 30, 2023 at 1:34 PM
    Diode Dynamics
    St. Louis, Missouri
    https://youtu.be/Bv0Hjp6URBw
    Ignite your lighting game this July 4th!
    20% OFF Single Row Stage Series Light Bars
    15% OFF Sitewide
    10% JL/JT Elite Series Headlights
    Plus, score FREE shipping and a FREE Diode Flag Tee with any purchase over $300!
    NO COUPON CODE REQUIRED
    https://www.diodedynamics.com/ ⬅️​
    Expires at 11:59 p.m., Friday, July, 7th, 2023.
  17. Aug 31, 2023 at 1:13 PM
    Diode Dynamics
    St. Louis, Missouri
    https://youtu.be/FbSa-XpQF2I
    It's our LAST SALE of the summer!
    Save BIG on premium US-assembled lighting sitewide!
    The time to upgrade is NOW!
    20% OFF Single Row Stage Series Lightbars
    10% OFF Sitewide
    FREE US Shipping on orders over $300!
    The sale ends Friday, 9/8.
    *Exclusions apply. While supplies last.*
    CLICK HERE TO SHOP YOUR RIDE AND SAVE!
    Did you know?
    You can find all of the products we offer for your vehicle using our vehicle finder tool on our website! Simply enter the year, make, and model and all options will appear.
    Grand Inquisitor likes this.
  18. Jan 19, 2024 at 6:18 AM
    Grand Inquisitor
    Grand Inquisitor Well-Known Member
    Northern Calif
    2023 Tacoma TRD Off road
    When will you guys be having another sale? I just got my 2023 Taco TRD Off road and I’m looking for some lights
    Thanks!
  19. Jan 19, 2024 at 7:48 AM
    Diode Dynamics
    St. Louis, Missouri
    Hey there!
    We don't have plans for another sale until July 4th at this time.
    You can always send us a direct message for a free US shipping code if that helps for being a forum member.
    Cheers
