Now building my audio setup
Discussion in 'Audio & Video' started by cbcs1987, Jun 15, 2009.
  1. Jun 15, 2009 at 2:34 PM
    cbcs1987
    cbcs1987 [OP] Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    I recently made a thread discussing options for my build, and now I finally have the time to do it. The only piece I currently have is a Pioneer avh5700dvd flipscreen.
    I have decided that I will NOT be putting in a sub woofer because there is nowhere possible to put one where it will be out of my way. So with that being said will the next best option be component speakers all the way around?
    For those of you who missed my other thread I simply want a cleaner than stock sound with more power. Not looking to make it loud enough for people on the other side of the state to hear the system.
  2. Jun 15, 2009 at 2:52 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    How did you come to the conclusion that there wasn't a place to mount the subs that was out of the way? Do you use the bins that are under the rear seats? (double cab?)
    How much are you looking to spend on components? Will you have a separate amp for them?
  3. Jun 15, 2009 at 2:53 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    Component set of the 6X9 flavor, and what ever fits in the rear of an access cab. Nice amp...done. Won't be outrageous, but will kick the crap out of the stock set up.
  4. Jun 15, 2009 at 2:58 PM
    cbcs1987
    Cody
    East Tennessee
    Yeah I always use my bins under the seats. And I've seen the enclosure that mounts in the center console... it takes up to much room as well. I have an access cab (2007)
    As far as the price on the components I'm not too concerned with. I am willing to pay more for quality. I have an amp but I'm not sure if it will work or not with component speakers. I'm fixing to go look and see what model the amp is.
    What I may do is just put the pioneer head unit in and the components i decide on (with yall help of course) and try it out. Then if I decide it needs more power I could add an amp.
  5. Jun 15, 2009 at 2:59 PM
    cbcs1987
    Cody
    East Tennessee
    Is flavor a brand? sorry i really dont know jack about audio...
  6. Jun 15, 2009 at 3:10 PM
    ItalynStylion
    Steven
    DFW, Tx.
    I think he was suggesting a 6x9 component set. I would not recommend this.
    My suggestion to you is to buy a nice set of components and deaden your front doors. If you seal up the doors with deadener the bass response from the front speakers will increase DRAMATICALLY. If you are looking to keep them fairly inexpensive the Phoenix Gold 6.5 RSD components are a great bargin. There is a great set of Precision Power components that are very budget oriented as well.
    http://www.sonicelectronix.com/item_17121_Precision+Power+PPI+356CS.html
    http://www.sonicelectronix.com/item_7294_Phoenix+Gold+RSd+65cs+-RSd65cs-.html
    Remember, a speaker can only perform it's best when you place it in it's ideal environment. Treat your doors correctly and get a decnet set of speakers and you wont need much else but an amp! :D
  7. Jun 15, 2009 at 3:21 PM
    cbcs1987
    Cody
    East Tennessee
    Thanks for the heads up. I'll look into deadening the door. What are those boxes in the pictures with the speakers and are they hard to wire?
  8. Jun 15, 2009 at 3:28 PM
    cbcs1987
    Cody
    East Tennessee
    Also, I notice these component speakers only have 2 front speakers and the tweeters. What about the back speakers?
  9. Jun 15, 2009 at 3:29 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Component sets all have those. Those boxes are called crossovers. Basically, you send power to them from your amplifier in the form of a + and - wire, then they send the high frequencies to the tweeter and the low frequencies to the midbass. They are pretty self explanatory and you should do fine wiring them.
  10. Jun 15, 2009 at 3:49 PM
    cbcs1987
    Cody
    East Tennessee
    I see what your sayin and just found a layout of how they wire on crutchfield.
    I have had infinity components before and am considering them again :
    http://www.crutchfield.com/p_1086020CS/Infinity-Reference-6020cs.html?tp=106
    What would you suggest I do for rear speakers?
  11. Jun 15, 2009 at 4:11 PM
    ItalynStylion
    Steven
    DFW, Tx.
    I don't favor infinities. VERY bright tweeter in my opinion. Not a lot of bass either. Either of the two options I posted is light years ahead of the infinity set. I know you stated that you were happy with your past infinities but trust me, I think you will like both of those options more.
    Here is the thing about rear speakers. You don't really need them. All they do is pull the sound stage to the rear of the car and screw up the sonic imaging. What size are the speakers in the rear? Are they the same 6.5" like in the double cab doors? If you were wanting to keep a stock look and still get a subwoofer you could use a 6.5" subwoofer. I run 4 Tang Band subwoofers in my car and they are glorious little beasts!
  12. Jun 15, 2009 at 4:18 PM
    cbcs1987
    Cody
    East Tennessee
    Well I might give one of the ones you suggested a try then. Those infinitys were all I ever had so I dont have anything to compare them to. So for the rear speakers are you suggesting I leave the stock ones, or unhook them completely? And your right, the rears are 6.5" as well. Do you have a link to said woofer?
  13. Jun 15, 2009 at 8:18 PM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Keep in mind what the OP is asking for here...not a full blown system.
  14. Jun 15, 2009 at 8:21 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    no offense dude but when i read this post it made me think about the 40 yr old virgin, "Is it true that if u dont use it you lose it?" haha and flavor is not a brand
  15. Jun 15, 2009 at 8:29 PM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Sorry, as posted already, it was just a word play. MB Quart, Eclipse, and Rockford Fosgate all make nice versions.
    The RF is a little more complicated with it having two tweeters, just more mounting options is all.
    http://www.sonicelectronix.com/item_2481_Rockford+Fosgate+Punch+P1692S.html#
    http://www.sonicelectronix.com/item_9487_Eclipse+SC6900.html
    http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=20082
  16. Jun 15, 2009 at 8:43 PM
    cbcs1987
    Cody
    East Tennessee
    haha yeah its cool. made me laugh at myself too.
  17. Jun 15, 2009 at 8:44 PM
    cbcs1987
    Cody
    East Tennessee
    So how would a set of 6.5 componets in the front sound with 6x9's in the back(primarily to provide the bass)
  18. Jun 15, 2009 at 9:16 PM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    well, factor in that you have 6X9's up front and 6.5's in the back currently, there would be major surgery (fabrication work:D) to get them 6X9's in the back.
    Just stick with the factory layout and upgrade the speakers that will fit in them. You'll end up with the most bass response you can get, and still be way ahead of the stock speakers. Add an amp, and it'll be that much better.
    Try not to get all hung up on 6.5 components sounding so much better than a set of 6X9 components. For what you are looking for, you'll not notice anything negative at all. Some folks just get wrapped around the axle and think there is only one way to good sound. Good sound is what YOU think sounds good. Since you don't know poop about audio, let's not get all fancy. Keep it simple.
  19. Jun 15, 2009 at 9:23 PM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Like to add that you should plan on getting your speaker baffles (adapters) from MrMarv. Top notch product and one of the nicest guys you'll ever talk to.
  20. Jun 16, 2009 at 1:08 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Here is a link http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-832
    Great little woofer. Takes more than double RMS wattage and will love it. Could be an option for you.
    I thought about that later last night. I think he might be ok with a 6x9 component set but generally the offerings aren't all that great. If you think that 6.5" component systems can't provide decent bass you're out of your mind. If you do it right you can get a significant amount of low end output from 6.5's.
    Agreed on Mr.Marv. Great guy. He's on the DIYMA forum that I'm on too and he's got a good rep there too!
