now that i bought it, will it work?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 92dlxman, Mar 1, 2013.
  1. Mar 1, 2013 at 11:58 AM
    92dlxman
    92dlxman [OP] drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    finally did it! placed an order at wheelers for
    ome885's
    5100 fronts
    5100 rears (14.02x22.94)
    wheelers 3 leaf aal (1.5" lift)
    i asked that they call me before processing the order because im worried about this setup a little bit. will the 5100s dampen the 885s? i dont do much high speed stuff but dont want the truck to be a pogo stick when i do. do the stiffer coils hamper slow-speed articulation? maybe i should just stay with the stock springs?
    im also worried about the rears with the addition of the aal kit. i want to be sure i can reach full compression/ droop at the rear without hurting the bilsteins.
    and lastly for asthetics, is this thing gunna bro lean????
    please help guys im kind of scared to death as the truck wheeled ok before, i dont want to make it any worse. thanks again
  2. Mar 1, 2013 at 12:07 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Haha don't worry man! Your going to love it, yes it will be a little stiffer especially right after you install it. Only thing i would worry about is alignment with stock UCAs
  3. Mar 1, 2013 at 12:11 PM
    92dlxman
    Kevin
    Visalia, CA
    i was hoping for the accronym "uca" to never come up in this thread. you'r opening a nasty bag of worms for me lol.
    i was affraid of that too as i think i/ve heard of people getting like 2.5" of lift from the 885/s alone, but wheelers claims 1.75. I plan on running the bilsteins at 0"
  4. Mar 1, 2013 at 12:33 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    I got 2.5 with 885s i would be surprised if you get less
  5. Mar 1, 2013 at 3:06 PM
    92dlxman
    Kevin
    Visalia, CA
    crap. so you ended up buying uca's i take it?
  6. Mar 1, 2013 at 3:10 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Yep. I installed the UCAs at the same time as the lift. Well light racing UCAs pretty much guarantee a good alignment if the alignment tech is good, and they are only $375. Some people have 2.5-3" with stock UCAs and claim it is fine. Your caster numbers will be lower than ideal, it might cause your truck to feel like it wanders at highway speeds. Worse case scenerio is deal with it until you can install UCAs, then you have to do alignment again, or it might not be bad at all and you can run the stock UCAs. In my opinion it is worth it to do it all at once.
  7. Mar 1, 2013 at 3:15 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    2.5" from 885's.. 3" with 885's + top plates. You'll sit a tad high in the rear. Especially until the leafs settle
  8. Mar 1, 2013 at 3:21 PM
    92dlxman
    Kevin
    Visalia, CA
    fantastic. hard to justify buying control arms without having some nice coil-overs to sit behind them. . . . . crap
  9. Mar 1, 2013 at 3:21 PM
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    Dude you will love it. Had mine for about 1000 miles. 3 inches in front with 885s and 5100s only. I have a 2wd v6. You may get a little less than 3 with 4x4. Yea you'll need UCAs
  10. Mar 1, 2013 at 3:23 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Some old info from chris regarding AAL and 5100s compared to stock shocks
  11. Mar 1, 2013 at 3:24 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Time to break open the piggy bank
  12. Mar 1, 2013 at 3:27 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    This is what happened to me. I don't have the springs, just the 5100's set at 2.5" and my caster is out. I will be dropping it to 1.75" for now because I don't want to fork over the extra cash for UCA's.
  13. Mar 1, 2013 at 3:29 PM
    92dlxman
    Kevin
    Visalia, CA
    thank you for that info on the rear, thats good to know. and yea either that or not buy the coils. . . . . . gunna have to go cruise and browse and take another year and a half to figure out exactly which arms I would want.
    so far i like camburg's arms with king or fox c/o's. . . . . . hell im dreamin
  14. Mar 1, 2013 at 3:59 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    Have you not considered the OME 884 spring? Might fit your needs perfectly...no uca needed
  15. Mar 1, 2013 at 4:07 PM
    PETEREDGE
    PETEREDGE Well-Known Member
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    ARB FRONT BUMPER...16x8 SR8 RIMS ,YOKAHAMA MT'S,DEMELLO SLIDERS,UPGRADED SOUND SYSTEM...
    I am just about to install Light Racing UCA on Tuesday.I have the same lift but with Eibach springs and my truck wanders so i got the uca's.Luckly i bought some off a guy for 200$.
  16. Mar 1, 2013 at 9:50 PM
    92dlxman
    Kevin
    Visalia, CA
    ok, they dont list it on their site so i never considered it. what is the difference again? is that stock hight with a higher spring rate? i've never quite gotten the full breakdown of ome's lineup.
  17. Mar 1, 2013 at 9:51 PM
    92dlxman
    Kevin
    Visalia, CA
    i know very little of the eibach springs, are they a little bit shorter?
  18. Mar 1, 2013 at 10:01 PM
    Raz4back
    Raz4back Well-Known Member
    Brett
    Benton, Arkansas
    2012 DC TRD Offroad 4x4
    Blacked out badges, Tinted Tail Lights, Fog Light Anytime Mod, Sock Monkey Bedside Decal, Painted Wheels, 20% Tint on Front Windows, 886 Bulb Backup Light Mod, Plasti Dip Rear Bumper (temporary until I get color matched), Color Matched Grill, Front Emblem, Door Handles, Mirrors, Bilstein 5100 all around, front set at 1.75, 1.5 aal, Crossfab light bar with 3 Hella Black Magic 500s, TRS Retrofit with D2S Projectors and Apollo Shrouds, BHLM with color matched Bowls and shrouds, CSJumper LED interior kit, CSJumper LED switchback DTRLs and Side Markers, 17x9 -12 Offset Ballistic Jester Wheels, 255x75x17 Nitto Trail Grapplers
    884s should put you right around 2" of lift, they are the same spring rate as 885s just shorter
  19. Mar 1, 2013 at 10:12 PM
    92dlxman
    Kevin
    Visalia, CA
    wonderful thank you. i will suggest that when they call
  20. Mar 2, 2013 at 7:10 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    Yes eibachs are shorter and a little stiffer than OME. Eibachs on 5100s are suposed to give you 1.6" of lift, with the billies set at the first notch you would be somewhere around 2.5. The spring rate on eibachs is around 620 lb/in vs. OME around 590 lb/in
