Now THAT is a Conundrum...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ryan_3TacosIn, May 16, 2017.
  1. May 22, 2017 at 11:23 AM
    Ryan_3TacosIn
    Ryan_3TacosIn [OP] Well-Known Member
    Houston, TX
    '02 XTRA Cab, 4x4, TRD- Working on Restore
    OME Shocks, 883 Coilovers, Synthetic Brake Lines, Dakar Leafs with AAL, Baja Rear Bumper; ES Body mount Bushings, Light Racing UCAs, American Racing Wheels w/ 33" Hercules Tires, and more to come...
    True... The only problem is, these wheels are only a few months old... Truth be told, I'm not that worried about spacers now after see what @Blackdawg with Frank. It'll be fine.
    keakar[QUOTED] likes this.
  2. Jul 13, 2021 at 9:04 PM
    Rawdoggin91
    Rawdoggin91 New Member
    Wyan
    2001 silver Tacoma
    Old man emu suspension
    so what ended up working with your set up? Did you have to go with the spacers or bigger wheels or what?
  3. Jul 13, 2021 at 10:39 PM
    Glamisman
    Glamisman Well-Known Member
    On my 96 4X4 the prior owner put on thick aluminum wheels to solve the problem BUT he left the stock lugs in the hubs. The wheel nut had maybe, 6 complete threads before it hit the rim. I installed longer Lexus? lugs, I think 75mm longer and bought lug nuts that were open on the end so I can see just how far down the nut goes. Not knowing your setup exactly I would watch out for not enough stud sticking out if going with spacers.
  4. May 18, 2023 at 5:42 PM
    Wolfjesus
    Wolfjesus Member
    Colorado
    2001 Tacoma TRD
    OME 881's with nitro charger shocks and full Dakar leaf pack
    I know this thread is a little dated now, but I was wondering something. This thread is linked as a source in an Adventure Taco post about wheel fitment for the Tundra brake upgrade. They posted a list of wheels that fit. The AR Baja 16" wheels are said to fit but need a spacer, listing this thread as the source of this info.
    The OP said that the passenger side wheel fit (albeit tight), but the driver side wheel didn't fit and was thinking he needed spacers. He then found out that the caliper was defective and was questioning the tolerances.
    Did the driver side wheel fit without spacers with the replacement caliper? Or were spacers still necessary after installing the replacement for the defective caliper?
    I have the same wheels and want to do the upgrade, but don't want to do spacers.
  5. May 18, 2023 at 7:37 PM
    tacobellingham
    tacobellingham Well-Known Member
    Bellvue, CO
    2000 TRD OR, 2015 TRD OR
    better suspension....
    I’m in the same boat. Interested to see if anyone has any insights here…
