Now what?!?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rachelsdaddy, Oct 10, 2019.
  1. Oct 10, 2019 at 3:54 PM
    Rachelsdaddy
    Rachelsdaddy [OP] Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    00D36E6E-65E4-4E97-AB9F-21D7E97159DB.jpg AE20C0B1-7A60-4DC3-BFF5-FBA426EB2303.jpg Sooooo, recently I determined by vin my truck needs Denso 234-9001. I ordered one from EBay from someone with good feedback. It arrived. See pics. The FN plug doesn’t fit, please see the difference in the pics. The number on the sensor itself says 192400-8000 although the box says its 234-9001. Would you cut and splice the plug from my crappy bosch sensor I had hanging around or go through the bs of arguing about it with the meatheads on EBay? The plug That fits my truck is the one on the right. I am beyond frustrated with this friggen thing. Trouble is if I do cut the plug, they obviously won’t take it back and it’s a massive pain in my ass to send it back in the first place.!!!
    3pooches likes this.
  2. Oct 10, 2019 at 4:01 PM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    If you don’t want to send it back, and are going to hack it up either way, can you grind that tab off? Everything else looks the same to me. If that doesn’t work you can splice it. Lots of aftermarket o2’s come needing to have the oem pigtail spliced on.
  3. Oct 10, 2019 at 4:04 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    What's more trouble? grinding the tab off or sending it back and/or waiting for them to send you another one and risk it being the same (wrong) plug?
    I vote for grinding and leaving a review.
  4. Oct 10, 2019 at 4:06 PM
    Rachelsdaddy
    Southern NH
    Look again, even the connection pins are offset to the opposite side. I am soooo BS
  5. Oct 10, 2019 at 4:10 PM
    3pooches
    VA & WV
    Sorry it’s hard to tell from the pic. If it was me. I’d splice in the correct pigtail. I lack patience
  6. Oct 10, 2019 at 4:13 PM
    Rachelsdaddy
    Southern NH
    A59D9777-1C94-4E16-B3C3-04B6E2909478.jpg And when I pull up pictures of 123-9001 the plug isn’t what I need, see this pic from Amazon. It’s the same as the one I received which makes me wonder if that is even the sensor that belongs in the fn truck although when I enter the vin with Toyota dealer parts, this is what comes up :annoyed:
  7. Oct 10, 2019 at 4:15 PM
    Rachelsdaddy
    Southern NH
    Hundred plus dollar gamble but I guess that’s what I will try.
  8. Oct 10, 2019 at 4:16 PM
    Rachelsdaddy
    Southern NH
    Maybe I need to go over to the dealer and ask them wtf is supposed to be in there. Ask to see it.... fml
  9. Oct 10, 2019 at 4:22 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    When it comes to buying Denso I would only order from Densoproducts.com or Sparkplugs.com. In 20 years I've never had an incorrect part.
  10. Oct 10, 2019 at 4:23 PM
    Knoxdavid34
    Knoxdavid34 Stranger with candy
    David
    Nashville
    02 Prerunner 4x4
    TRD Off Road sticker. Not the whole package, just the sticker.
    Something similar happened to me. I needed a front o2 sensor and got an ebay one because it was cheap. Part numbers matched up but the actual part that was inside the exhaust looked different and the plug wires were much longer than the old one. The plug fit and the check engine light went away and I went back into a closed loop but the truck ran very wierd after it was installed. Like it had a loss of throttle every few seconds. I also noticed a loss of power, especially in the low end. After chasing a bunch of other stuff that wasn't the problem, I found the the sensor just wasn't sending the right signals to the ecu.
    I bit the bullet and ordered and OEM one from Toyota, installed it and sent the ebay one back for a refund. It's a pain to send back, but I seriously doubt this one will work properly with your ecu. Even if it numbers do match, their are a lot of shitty ebay knockoff parts out there.
  11. Oct 10, 2019 at 4:25 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I show you need one of these
  12. Oct 10, 2019 at 4:37 PM
    Rachelsdaddy
    Southern NH
    I hear ya but w/ all the confusion of late whether it is an O2 or f/a ratio because of being a mid 99, I went to Camelback Toyota, entered my vin, took the Toyota number and cross referenced through Napa to get Denso # 123-9001 . After a cup of coffee and a toke, it appears I can grind down the tabs and it will fit. I will try it tomorrow, if it don’t work I will go over to the dealer. I will never ever EVER buy anything from EBay again. I get burnt every time. Especially with heavy equipment parts. They ALWAYS send me the wrong crap.
  13. Oct 10, 2019 at 4:39 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    That's why cheaper isn't always better. Next time support a local auto parts store or at least go to rock auto where they have descriptions, pictures, and a fast return policy.
    jbrandt likes this.
  14. Oct 10, 2019 at 4:45 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If you pull that white piece out you should be able to unclip the pins and swap them over.
    3pooches and IvanhoeTaco like this.
  15. Oct 10, 2019 at 4:48 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    The fact that the harness isn't mating to the -9001 says you should have just ordered from the year and spec like normal and not from vin.
  16. Oct 10, 2019 at 4:49 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    eBay has a money back guarantee but you must first contact the seller. Most eBay sellers offer paid returns. There is a reason for the plug difference as O2 and A/f sensors plugs are not interchangeable. Contact seller for return. Denso Products.com offers identical OE Replacement sensors. eBay and Amazon may be cheaper but you don't always get the parts you need.
  17. Oct 10, 2019 at 4:54 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If the harness is wired for the 4162 which has the twin notch on top of the plug then you don't need an AFR sensor with single notch. Not sure if there will be any ill effects if you use it but why spend $125 for a $48 sensor.
  18. Oct 10, 2019 at 4:56 PM
    Rachelsdaddy
    Southern NH
    Normally I would agree but I thought a Toyota dealership number via the vin number of the truck would be the most accurate way of determining what is supposed to be in there. At this point I haven’t a clue. Some say it’s supposed to be an 02, some say it’s supposed to be an air/fuel. Two entirely different animals as far as the ecm goes
  19. Oct 10, 2019 at 4:57 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If it's wired for an O2 then that's your answer. Twin notch on top is O2.
  20. Oct 10, 2019 at 4:59 PM
    Rachelsdaddy
    Southern NH
    Last week you said I needed the 4162. Seems like you are correct, although the Toyota numbers say otherwise. :confused:
