NST Crank pulley specs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Sep 13, 2015.
  1. Sep 14, 2015 at 8:00 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I'm only referring to the specific pulleys on the s/c tensioner bracket.
    The water pump pulley was designed to be underdrive and I believe for clearance of the NST O.D. s/c pulley.
  2. Sep 14, 2015 at 8:01 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You sir need more coffee :pccoffee:
  3. Sep 14, 2015 at 8:11 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I don't drink any, so it takes me a while to equalize this early in the California mornings. Lol.
    I'll have to look at the entire setup later to see what the heck is going on in there. It almost is starting to seem as if it is not worth it due to the very close tolerances between all the pulley's.
  4. Sep 14, 2015 at 8:13 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just have to look. If all it takes is swapping on one pulley, then it would really be worth it. But you've got to check.
    12TRDTacoma[OP] likes this.
  5. Sep 14, 2015 at 8:26 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'll report back at the end of today's workday. Probably around 7PM Cali time. If all looks well I could then figure out what the plan of attack will be.
