NST Pulleys and a Tuner?
Discussion in 'Performance and Tuning' started by extremachn1, Jul 14, 2011.
  1. Jul 14, 2011 at 4:50 PM
    extremachn1
    extremachn1 [OP] I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    OK guys, about to pull the trigger on the DTLT and a Y pipe but have a few questions about a few other parts and want peoples opinions on them.
    Does anyone have any experiance with these, the NST pulley kit http://www.nonstoptuning.com/NSTPULLEYS/pKitToyXRTRD.html?
    Also, since I cant get a X-1 tuner anymore, what do people reccomend, I am going to need something to put a custom tune in it, here is what I will be running.
    TRD S/C, URD S/C underdrive pulley, AFE CAI, DT LT Header, Y-pipe, NST light weight pulleys? What do you guys reccomend as a tuner for this set up?
  2. Jul 14, 2011 at 4:56 PM
    Lucario Runner
    Lucario Runner Resident SUV racer
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Map3 is a good alternative plus URD has the plug and play harness.
  3. Jul 14, 2011 at 5:32 PM
    extremachn1
    Turd Furgison
    Tucson, AZ
    What is this plug and play harness you speak up (I am looking it up now), I asked gadget a while back about a replacement tuner but never got back to me.
  4. Jul 14, 2011 at 5:40 PM
    Lucario Runner
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    I just saw your year (09- current has different ecu clips on the back of it), it might not work for you. Still I would use the map3 to fine tune your truck.
  5. Jul 14, 2011 at 6:23 PM
    extremachn1
    Turd Furgison
    Tucson, AZ
    I know of unichip and a few others. I was just hoping some of the tuners here had experiance with them and could give me a recomendation and opinion.
  6. Jul 21, 2011 at 8:00 AM
    bcroach78
    bcroach78 Well-Known Member
    TN
    2010 Crew cab TRD L/B S/C
    xr-undergeround is a great place for tuning questions. There are several tuners out there, haltech, the map-ecu3 from urd, apr x-1 if your lucky enough to find one, also proEFI has two different ones depending on your tuning needs.
    If you are going to be running all the mods listed above you should consider getting the 7th injector to help keep it cool and upgrade to bigger injectors and a better fuel pump to provide the fuel needed to run that set-up safely!
  7. Jul 23, 2011 at 4:51 PM
    extremachn1
    Turd Furgison
    Tucson, AZ
    I thought the 7th injector was for 1st gens only? I have bigger injectors, that was part of the install with the TRD kit was larger injectors.
    The URD site seems to be down so I cant get on a actually check.
  8. Jul 23, 2011 at 6:11 PM
    Lucario Runner
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    You can use the 7th with the map3 or any other ems that allows for additional injectors. You can use the 7th injector in two ways, you can use it if you max out your injectors and/or use it for cooling if you have big primaries like the 668 injectors. Tuning it isn't that hard, it can be done it just takes a little more work than on the X1.
  9. Jul 23, 2011 at 7:53 PM
    extremachn1
    Turd Furgison
    Tucson, AZ
    Problem is I cant use the X-1 because I have a 2010 and they are not compatable with my ECU plug I believe.
