Nuckle swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by TocoTime, Dec 6, 2022.
  1. Dec 6, 2022 at 8:15 AM
    TocoTime
    TocoTime [OP] New Member
    Jack
    2000 Tacoma Extra cab SR5 4x4
    None
    New here and still learning so thanks, can anyone tell me if I can put a 2nd gen knuckle on my 1st gen Tacoma in order to alleviate pressing bearing hub assembly, Id rather do the bolt on assembly
    Thanks in advance
    Taco critter likes this.
  2. Dec 6, 2022 at 8:21 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Nope- completely different assemblies. If you're handy and have a second vehicle, pull the knuckle yourself and take it to a shop to do the press work- it will be far more affordable. Try a regional forum to get shop recommendations.
  3. Dec 6, 2022 at 8:43 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW...
  4. Dec 6, 2022 at 9:07 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    You can change the bearing out at home if you have a good vise and rent a few tools from Autozone or QRielys Auto parts. Just did one a few weeks ago. You also need a torque wrench and a big breaker bar and correct socket.
    tools needed: Bearing puller to rent
    Ball joint installer to rent
    I'm going to do a complete write up on it when I do the other side in a month or so.
    Digiratus likes this.
  5. Dec 6, 2022 at 9:12 AM
    TocoTime
    Jack
    None
    Well yall busted my bubble Ive done the hubs on my sons Tacoma which is 1st gen I was just hoping a swap would work, guess Im buying a press
    Thanks
  6. Dec 6, 2022 at 9:40 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
  7. Dec 6, 2022 at 11:03 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    The easiest way to install new bearing into the spindle/knuckle it self is to use heat and cold. Take your new bearing and put in in the freezer a few hours before you install it. :confused: Clean up your knuckle, fire up your BBQ on low setting and cook your spindle to 200-250F.:eek::eek: Watch grill temp and don't let temp get over 250F. Once it's warm pull it out and immediately drop frozen frozen bearing into it.:D Save the old outer race and have a hammer close by incase it needs a tap to seat it. Sounds crazy but it works.
    Oh and wrap upper ball joint in tinfoil to keep any grease that might drip out away from your BBQ grill. Mine didn't leak any out.
