Nuetral safety switch bypass help!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by guahantacos, Jan 28, 2024.
  1. Jan 28, 2024 at 1:53 AM
    guahantacos
    guahantacos [OP] New Member
    2004 Toyota Tacoma 2wd
    3”drop coil springs,3”blocks in the rear,gonna delete middle spring soon.kenwood touchscreen player,4Runner front end...
    Hi I’m trying to find a post to answer my question.Can anyone tell me what wire (color) goes to what eg.reverse light,park,reverse,neutral over drive on my 2004 taco 2wd 2rz neutral safety switch?I’m currently trying to bypass for my manual conversion.I believe it has only 5 wires.
    any info is greatly appreciated.
  2. Jan 28, 2024 at 8:17 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Give it time someone might post up the circuit diagram.
    Are you skilled with a multi meter ?? simple to figure out what wires you need.
    Another way is to run a wire from the starter fuse to pin one of the starter relay that bypasses the neutral safety switch since that switch is no longer needed . That is what I do for my swaps.
    Are you also switching to the manual ECM and wiring harness or going to live with the check engine light always on?
    Good luck
  3. Jan 28, 2024 at 3:37 PM
    guahantacos
    thank you for the help. I do have the manual ecu but not the harness just yet. For some reason both boxes are the same maybe the pinout are different. But will try a multimeter like you said.
    thanks again
  4. Jan 29, 2024 at 3:00 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
