Number of Zerts on Driveshaft?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bwise, Jul 31, 2025 at 5:19 PM.
  1. Jul 31, 2025 at 5:19 PM
    bwise
    bwise [OP] Well-Known Member
    2018 SR5 4x4. How many zerts total on the front/rear driveshaft? Do they all take the same grease? My first gen took the the moly stuff in the slips yokes
  2. Jul 31, 2025 at 5:36 PM
    Clearwater Bill
    Billy
    Largo Florida
  3. Jul 31, 2025 at 5:45 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    2018: zero rear zercs. I think either zero or one front, I forget the year they did away with that last little booger. I thought 2016 was the last with front zerc, but my fuzzy is memory.
    Phlogiston likes this.
  4. Jul 31, 2025 at 6:27 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    My understanding is 2017 is when they switched to 0 zerks. They also changed the carrier bearing in '17.
    Rock Lobster[QUOTED] likes this.
  5. Jul 31, 2025 at 6:55 PM
    tractorfarmer123
    tractorfarmer123 Well-Known Member
    2020 Tacoma
    Can I use the tractor grease on the 2020?
  6. Jul 31, 2025 at 7:05 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    xBloodxLinex likes this.
  7. Jul 31, 2025 at 7:50 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    We really should bring back the Alemite terminology. It would force us all to look up the correct spelling.
    But I read that Alemite "bought" the Zerk name just to close in on the market.
    Ain't industry great!
  8. Jul 31, 2025 at 8:00 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My 2017 has them on the front driveshaft
    #4TOY4ME likes this.
  9. Jul 31, 2025 at 8:18 PM
    Sasquatchian
    Sasquatchian Well-Known Member
    My 2018 (mid year built) has one zerk on the front driveshaft and none at all anywhere else. Not all trucks in the same year will necessarily have the same number or lack thereof.
    shakerhood and xBloodxLinex like this.
  10. Jul 31, 2025 at 8:32 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    As far as I can tell…..
    2016-2017 has 5 (2 front 3 rear)
    2018-2019 has 1-2 (front)
    2020+ has none.
    All the 2018-2019s I’ve heard of have had 2, one on each end. I don’t know why they’d install one and not the other to match. So I’d think there’d either be 2 or none.
    jmneill likes this.
  11. Jul 31, 2025 at 8:32 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Yeah, i always thought it was Zerk, this thread confused me.
  12. Jul 31, 2025 at 8:57 PM
    Jesse46
    Jesse46 Well-Known Member
    Jesse
    Orange County, CA
    2017 OR DCSB 4x4
    What was the reason or benefit of getting rid of them?
  13. Jul 31, 2025 at 9:06 PM
    BLtheP
    Plano, TX
    Not needing to do maintenance on them. Non greasable joints are generally reliable enough that not needing to grease them is more of a perk than it is a con to not be able to grease them. Unless someone is dumping their joints down in mud constantly, there is really no reason for a joint to need consistent regreasings.
  14. Jul 31, 2025 at 10:02 PM
    TA2016
    Oregon
    Here is some interesting reading.
    “Bottom line on strength: The non-greaseable joint is slightly stronger than a greaseable joint. The exact number, how much stronger, is unknown and we do not believe it to be very significant.
    Bottom line on wear life: A regularly greased greaseable joint will outlive a non-greaseable joint. But a non-greaseable joint will outlive a greaseable joint that does not get greased properly.”
    https://4xshaft.com/blogs/faq/greas...pJ43HNFfVW3id1PKObS9V0qG3F9pOcakYa7hRtGVXDLzV
  15. Aug 1, 2025 at 9:15 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    2018 here. Two Zertz up front.
    BLtheP[QUOTED] likes this.
  16. Aug 1, 2025 at 9:25 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Grease and seal technology improved to a point where the non-greasable U-joints can last a reasonable time, so greasing provisions were deleted, in the same vein as ball joints, tie rod ends, leaf shackles, and wheel bearings.
  17. Aug 1, 2025 at 9:42 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    2018 sr5: i have none on rear driveshaft, 2 on front driveshaft universals. first time i greased them they took quite a bit more than expected. fortunately front does not rotate unless using 4WD and i don't use it that often...i use it more to exercise it than need it.
    manual says NLGI #2 lithium grease...common but use the right stuff if you are going to go to the trouble.
  18. Aug 1, 2025 at 10:01 AM
    grambo911
    grambo911 Well-Known Member
    SF Bay Area, Kommiefornya
    2023 Lunar Rock Trail Edition
    AWE Exhaust, KARTBOY exhaust hangers, custom 1/0 exhaust grounding, lots of Titanium hardware from my old builds, silly JDM bits from my old Subaru builds, Uniden Bearcat Off Road CB, Firestik 2 w/custom CF mount, custom KARTBOY plate frame with Rigid Industries Spot on ball head mount, Yakima Mega Warrior w/custom CF cross brace. ARP extended studs (not installed yet), Optima Red Top, Siless Insulation in cab. Diode Dynamics LEDs throughout... More titanium fasteners. K&N intake snorkus delete. Greddy hose clamps throughout. DBA 4000XS Brake Rotors. TRD PRO fogs. Dakine Tail Gate Pad. Body Armor Sliders. Icon Stage 4 Lift. Eibach 1" Lift Blocks. Overland Taylor Tune. Rough Country Spare Tire Bed Mount. 67 Designs stuff on the dash. Uniden Radar Detector Hardwired. Spod Lighting Controls. RC Black Series Bumper Lamps RC Black Series Grill Lamp. Body Armor Stealth Front Bumper. Extended Brake Lines. Greddy Shift Knob. More to come of course.
    I can confirm the 2023 Trail has zero zerks in the driveline. I crawled all over it like a horny spider monkey just last weekend.
  19. Aug 1, 2025 at 10:41 AM
    1994SR54x4
    1994SR54x4 Well-Known Member
    No Zerts. There may be some zerks. :)
    Phlogiston, grambo911 and drizzoh like this.
  20. Aug 1, 2025 at 12:08 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    My '17 has 2 up front, nun in the rear!
