NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Sep 21, 2016 at 9:30 PM
    Lost In The Woods
    Lost In The Woods 4 out of the 5 voices in my head say go for it!
    Eric
    Buckley, WA
    21 Gladiator Rubicon Diesel
    An unusually high amount of pinstriping.
    That would be a great trip, but I've already got to much on my plate for October. Be safe and post pics when you get back.
  2. Sep 21, 2016 at 9:32 PM
    Honeybadger
    Honeybadger Powaaaaaah!
    Alex
    Kirkland, Wa
    05 Tacoma TRD Sport 05 4Runner Lmt
    ARB: Front bumper, compressor, tire repair kit, deflate 4xinnovations: Full skids King Racing: extended travel coil overs. Bamf shock relocation buckets with 12" smoothies. EBC: Slotted/drilled brakes with Yellowstuf pads Pioneer: Deck, speakers Wheelers: Front and rear superbumps, extended brake lines Homemade: Rear HC bumper with swingout Toyo: 255/85R16 Open Country MT
    Exactly the way I ran it. Also the thing is super loud and gets scolding hot . Keep it in the engine bay. I mounted mine next to the airbox
  3. Sep 21, 2016 at 9:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Honeybadger[QUOTED] likes this.
  4. Sep 21, 2016 at 9:38 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    Wierd mine doesn't get that hot. With the pressure switch, only runs when filling, for a few min per tire. I leave the seat back forward for about 5 min and it cools off enough.
    Not like my Vaiar 380 that melted the hose off the fitting!
    Also if you have a 2011 or newer, the spot on the pass side in front of the fire wall is taken by the secondary air pump. Still fits, but super tight.
    TACOVRD likes this.
  5. Sep 21, 2016 at 9:52 PM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    I'll be in greater Seattle area this weekend, but in Black Diamond on Saturday for Tough Mudder. I'd like to meet up in Snoho but don't think it will work this trip.
    On the compressor topic, I have to agree with everybody else, run the relay. I am an electrician for a living. 40 amp takes #8 copper or #6 aluminum wiring to be safe. Don't use aluminum wiring. A switch for more than 20 amps becomes a disconnect and you don't want to put that in a truck. Also, don't run 1 wire through the firewall. Run 2. That way, you can send +12v in to the switch, then have it come out the other wire to the coil of the relay. I wouldn't run anything smaller than 22 gauge to trigger a relay, and make sure the wiring is rated to be water resistant, something like THWM THHM or TWHM2.
    Honeybadger likes this.
  6. Sep 21, 2016 at 10:05 PM
    twalchlii1
    Tom
    Wa
    2018 GC Trailhawk
    What he said!
    I ran Ancor 16 sheathed duplex to the switch, and 8 to the pump. Super fine strands so they don't break down as much from vibration and flexing, also tinned to resist water migration. Get from West Marine. Expensive, but worth it.
    Run is short enough you won't get voltage drop with the bigger wire.
    Also, what it this tough mudder thing?
  7. Sep 21, 2016 at 10:09 PM
    Honeybadger
    Alex
    Kirkland, Wa
    Touch the air manifold after filling 8 tires. It gets hot. And yes the newer body style has a diiferent layout.
  8. Sep 21, 2016 at 10:23 PM
    twalchlii1
    Tom
    Wa
    2018 GC Trailhawk
    You have 8 tires!!!!!!!!!????
    Shit. Now I feel ready inadequate. :D
  9. Sep 21, 2016 at 10:32 PM
    Honeybadger
    Alex
    Kirkland, Wa
    No I've filled up mine and my brothers. Also filled.up 2 air mattresses. Lol
  10. Sep 21, 2016 at 10:49 PM
    Kappes03
    Kappes03 Legend of the UG
    Colorado
    2014 Tundra CM
    Yeah I think you got yours on right after me
    twalchlii1[QUOTED] likes this.
  11. Sep 21, 2016 at 10:58 PM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Whose truck did I see at PJs on East hill this evening?
  12. Sep 22, 2016 at 5:08 AM
    Smar969905
    Zach
    Deer Park, WA
    Tough Mudder is a military grade obstacle course that supports Wounded Warrior Project. This year will be my 5th time doing it. toughmudder.com for more
  13. Sep 22, 2016 at 6:50 AM
    tpotnoc
    tpotnoc Sit on my face
    Bellingham, WA
    15 2.7 DCSB PR
    I'll be running the harness that ARB included with the compressor. Hopefully they've thought of all that already.
    twalchlii1 likes this.
  14. Sep 22, 2016 at 7:26 AM
    Kappes03
    Colorado
    2014 Tundra CM
    I stopped supporting WWP after they were investigated for spending 70% of their donations on themselves. I think recently they've changed
    Haslefre likes this.
  15. Sep 22, 2016 at 8:45 AM
    Smar969905
    Zach
    Deer Park, WA
    I haven't contributed anything directly to WWP, just registration fees for TM. @JoeTacoma02 and I did TM a couple times. Did it in Portland a couple years ago, and Seattle last year. This year, I'm doing it with my brothers.
    JoeTacoma02 and Kappes03 like this.
  16. Sep 22, 2016 at 10:58 AM
    Kappes03
    Colorado
    2014 Tundra CM
    I was just giving my 2 cents on WWP not TM itself :thumbsup:
    I've always wanted to do a TM though.
  17. Sep 22, 2016 at 11:00 AM
    twalchlii1
    Tom
    Wa
    2018 GC Trailhawk
    The stock harness is just about perfect for under hood mount. If you go bac seat or in bed cubby, power and pressure wires have to be extended.
  18. Sep 22, 2016 at 11:06 AM
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
  19. Sep 22, 2016 at 11:11 AM
    twalchlii1
    Tom
    Wa
    2018 GC Trailhawk
    PNW/TRD Steve[QUOTED] likes this.
  20. Sep 22, 2016 at 11:13 AM
    PNW/TRD Steve
    WA
    2012 DCSB TRD
    Only took three months. LOL.
