NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Dec 16, 2016 at 10:09 AM
    MNmtb
    MNmtb Well-Known Member
    Jeff
    2015 Tacoma Lifted
    I'm not going to look into this further, but Washington Code Says:
    RCW 46.37.375
    Steering and suspension systems.
    (1) Construction of steering control system. The steering control system shall be constructed and maintained so that no components or attachments, including horn activating mechanism and trim hardware, can catch the driver's clothing or jewelry during normal driving maneuvers.
    (2) Maintenance of steering control system. System play, lash, or free play in the steering system shall not exceed the values tabulated herein.
    Steering wheel diameter
    Lash
    (inches)
    (inches)
    16 or less . . . .2
    18 . . . .2-1/4
    20 . . . .2-1/2
    22 . . . .2-3/4
    (3) Linkage play. Free play in the steering linkage shall not exceed one-quarter of an inch.
    (4) Other components of the steering system such as the power steering belt, tie rods, or idler arms or Pitman arms shall not be broken, worn out, or show signs of breakage.
    (5) Suspension condition. Ball joint seals shall not be cut or cracked. Structural parts shall not be bent or damaged. Stabilizer bars shall be connected. Springs shall not be broken, or extended by spacers. Shock absorber mountings, shackles, and U-bolts shall be securely attached. Rubber bushings shall not be cracked, or extruded out or missing from suspension joints. Radius rods shall not be missing or damaged.
    (6) Shock absorber system. Shock absorbers shall not be loose from mountings, leak, or be inoperative.
    (7) Alignment. Toe-in and toe-out measurements shall not be greater than one and one-half times the value listed in the vehicle manufacturer's service specification for alignment setting.
    Could be interpreted as only if they are there (ie, no quick disconnect), but thought it was interesting none the less.
    FWIW - Washington Law does state specifically that anti-sways are required for coil spung rears.
  2. Dec 16, 2016 at 10:17 AM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Lmao my truck is so illegal if you look at WA state law. Sway bar is least of my worries.
  3. Dec 16, 2016 at 10:40 AM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    Just say no to sway bars mmmkay
  4. Dec 16, 2016 at 10:41 AM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    I can't even fit a sway bar on my truck anymore
  5. Dec 16, 2016 at 10:50 AM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    im still rocking mine...with fox 2.5's haha the real thing that used to keep me from removing it was having to remove the pelfry skid which is like 45 lbs and nothing more than a mere pain to do by yourself without a lift. so i told myself when i took the skid off next time, i would take the sway bar off (I know its limited some of the travel for my front susp, so I hate the aspect that im not getting "everything" i paid for). THEN my baby was born back in sept and it was not worth it to me to jeopardize her riding with me. I trust myself driving with it off with me in the vehicle on the interstate, but im not willing to gamble with her, thats just me personally. i figure in the coming year it'll come off, but I just havnt made a specific attempt to remove it yet. (after 4 months, my daughter has ridden in the my truck 1-2 times...so the odds of her riding with me is much less than I originally anticipated, which is why my reasoning is turnin to removing it)
  6. Dec 16, 2016 at 11:43 AM
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    The big risk you face is being sued. If an attorney can prove that a properly attached sway bar (if the vehicle was originally equipped with) could have prevented an accident, you're screwed.
    I would think it likely of this happening would be extremely low.
    Yetimetchkangmi likes this.
  7. Dec 16, 2016 at 12:08 PM
    BoatRacer
    BoatRacer Well-Known Member
    Olalla WA
    '02 TRD 3.4 5-Speed
    All Pro front bumper, Warn winch, leds, Dakar leaf pack, locker wire mod.
    Sway bar? Never herd of it. Lol
    BTW, someone left one at my place after installing a lift. There might be a couple of them here if anyone feels the need to install one.
    Jon27 and NorthwestCruiser like this.
  8. Dec 16, 2016 at 12:08 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Not directed at you @Pyrite Mica...
    Agreed....But there are many of us that aren't in compliance within WA and much less in CA and CN and other states.
    I am not pointing fingers b/c there would be several pointed back at me. :anonymous:
    For instance:
    Rear Bumper cannot be higher than 19"
    Vehicles are required to have a license plate light.
    Mudflaps are required for all lifted vehicles and where tires extend outside the fender wells.
    Off road lighting is not legal to use as a primary source of lighting for highway driving.
    Horn is only used for emergency purposes.
    Etc.
    Etc.
    Etc.
    The list goes on and on.
    Stating an RCW in an offroading forum; it like tattle tailing on someone that didn't see a sign to "stay on the path".
    Good thing it wasn't stated on Pirate4x4...
    Honeybadger and bobsuruncle like this.
  9. Dec 16, 2016 at 12:17 PM
    BoatRacer
    Olalla WA
    '02 TRD 3.4 5-Speed
    Anyone know if the locker controller or computer needs to see the resistance of the locker motor to function?
    I have the locker relay mod on my truck still, after switching to a 9" rear with an ARB, I left the relay in place hoping to use it as a ABS cancel, but it doesn't work. I hear the relay make, but the dash doesn't light up for the locker anymore and it doesn't cut out the damn ABS
  10. Dec 16, 2016 at 12:55 PM
    lockwire24
    lockwire24 Well-Known Member
    Mark
    Vancouver
    2012 MG DBL cab LB TRD sport
    Cobra CB, Firestik II w/ Relentless hood mount, 4x Innovation sliders, Level 8 tracker pro, TRD exhaust, home made grill insert, Leer XR, led bed lights, King shocks, LR uca, Pelfreybuilt front/rear bumpers and skid plates, B.A.M.F. rear shock relocate.
    If you are still going, I'm in. Haven't been having fun in over 2 months ish.
  11. Dec 16, 2016 at 1:07 PM
    JDAM
    J
    Worshington
    12 DCSB TRD OR
    If we can get one more person to confirm that would be great. Do you have a winch? I have a friend in a stock Rubicon that wants to go.
  12. Dec 16, 2016 at 1:51 PM
    lockwire24
    Mark
    Vancouver
    Winch, recovery gear and co2 bottle if needed. I don't have lockers but 33" tires.
  13. Dec 16, 2016 at 3:03 PM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    Bring a bottle of lighter fluid or gasoline and a lighter. Doesn't take much to get the poof to set a bead. I suggest a longer lighter to help keep hands back, or have a piece of paper to light and drop on it.
  14. Dec 16, 2016 at 3:07 PM
    lockwire24
    Mark
    Vancouver
    The rims I have was designed with a bigger in bead. You should of seen Discount trying to seat it.:curls:
  15. Dec 16, 2016 at 6:11 PM
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    Depending on when and where I am in, I just have to try to be back home by around 7 tomorrow. If we do Sunday I am completely open.
    I unfortunately do not have a winch but hopefully with you guys both having one we can get by.
  16. Dec 16, 2016 at 6:44 PM
    McMash
    McMash The only thing better than light bars? Sarcasm.
    Tyler
    Gig Harbor, Wa.
    '04 Tacoma AC TRD 4x4
    Tomorrow or Sunday?
  17. Dec 16, 2016 at 6:50 PM
    McMash
    Tyler
    Gig Harbor, Wa.
    Also:
    Been looking to get some tire deflators. Something I can set and forget to a particular PSI rather than babysitting each tire with a gauge while airing down. Any recommendations?
  18. Dec 16, 2016 at 6:51 PM
    lockwire24
    Mark
    Vancouver
    I have the Staun tire deflators and love them.
    McMash[QUOTED] likes this.
  19. Dec 16, 2016 at 7:00 PM
    GSPRunner
    GSPRunner Well-Known Member
    Joe
    Seattle, WA
    17 Mag Grey DCSB OR
    I second the Stauns
    McMash likes this.
  20. Dec 16, 2016 at 7:14 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Test a known good circuit?
