NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Feb 28, 2017 at 11:59 PM
    JimSnell
    JimSnell Well-Known Member
    Jim
    Puyallup
    2015 White Tacoma TRD Sport DCSB
    Vibrations only show up 3 ways. A rotating object, driveline or tire, isn't balanced. duh. Or a ujoint or carrier bearing is either worn or too flexed. or somebodies girlfriend just went to a passion party. That's the simple physics. I'm legit puzzled how you're "feeling it".
    chanes8cwu likes this.
  2. Mar 1, 2017 at 12:13 AM
    Jon27
    Jon27 Well-Known Member
    Jon
    Salt Lake City, UT
    2015 Toyota Tacoma Off Road
    Shit on a black truck.
    Well no passion parties here but it's was a noticeable difference. I looked up proper angles and whatnot and I didn't think mine were that bad. I'll try reduce anyways as I like the truck lower and go from there I guess.
  3. Mar 1, 2017 at 12:28 AM
    JimSnell
    Jim
    Puyallup
    I got nothin. CV angle would only start to do that at full droop. Drivelines haven't changed. I'd start looking for a weight that fell off the wheel or a lug pattern that didn't get done right. Is it a wheel speed vibe or driveline speed?
  4. Mar 1, 2017 at 12:32 AM
    Jon27
    Jon
    Salt Lake City, UT
    Could possibly be a wheel maybe. Feel it around 40.
  5. Mar 1, 2017 at 6:51 AM
    Stanky taco
    Stanky taco Well-Known Member
    Auburn
    16 Tundra 1794 CM / 11 FJC / 19 GX460 / prev 13 TACO DCSB OR
    does the vibration go away when you put it in 4wd? if so its your needle bearing, get a ecgs bushing for the cure
  6. Mar 1, 2017 at 7:41 AM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    The lift I had left me with vibration most noticeable about 35-40. I never took the time to do a carrier bearing drop.
    Where do you feel the vibration (whole vehicle, steering wheel, back end)? If it is only about 40ish MPH, but goes away at other speeds, that sounds like driveline. If it is worse at speed and feels like the whole truck, that would be more of one or both rear wheels out of balance. Steering wheel shakes are front wheels out of balance.
  7. Mar 1, 2017 at 9:58 AM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Who has washed their wet okoles seat covers? My driver's is starting to show some drying of the neopreme. The directions say to wash them in place. I'm a bit weary of using too much water and soaking my floor boards. I've got the care kit that came with the covers when I ordered them.
  8. Mar 1, 2017 at 9:59 AM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    @dakotasyota uses something else to wash his.. can't remember what.
  9. Mar 1, 2017 at 10:02 AM
    Jon27
    Jon
    Salt Lake City, UT
    Not sure I'll have to try it.
    Mainly at speed and the vibrations feel like it's under my feet and slightly in the steering wheel.
  10. Mar 1, 2017 at 10:09 AM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Most likely your carrier bearing
  11. Mar 1, 2017 at 10:17 AM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    I've got the Wet Okole shampoo, odor eliminator, and protectant but haven't used them yet. Sounds like a good excuse for drinks?
    That reminds me I haven't called King about my replacement spacers yet. How's your front end squeaking/creaking?
  12. Mar 1, 2017 at 10:21 AM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Front end creaks have decreased even more so now with new inner/putter ball joints and tierods. Now I need to do the uniballs next. I have 2 replacement uniballs need to order 2 more.
    I've got a punch list of stuff to do this weekend if your down. Between the seat wash and I picked up a twin arb compressor yesterday, I still need to take out the Diff drop and put my main skid on. Also want to try and permanently fix my jiggle wire at the ECU. My truck was being a cranky bitch once I got to Puyallup. Good thing I know how to temporarily fix it and what symptoms to look for.
  13. Mar 1, 2017 at 10:43 AM
    JDAM
    J
    Worshington
    12 DCSB TRD OR
    Yeah man. I have an ARB twin install on my list as well. Lately I'm getting a higher pitched squeak on the passenger side. Sounds like a hamster wheel.
  14. Mar 1, 2017 at 12:43 PM
    Jon27
    Jon
    Salt Lake City, UT
    Update: dropped the preload 1/2" and the vibrations went away. Chopped a little more and no more rubs. Baby powder worked good just make sure you are upwind when you do it FYI. Anytime I hit a decent sized bump it sounds like I'm bottoming out the shock.
  15. Mar 1, 2017 at 12:53 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Oh yeah, I've got a rear axle seal to do also. Already did the extended brake lines in the front, still need to do the rears.
  16. Mar 1, 2017 at 12:55 PM
    JDAM
    J
    Worshington
    12 DCSB TRD OR
  17. Mar 1, 2017 at 1:01 PM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    That may be the uniball uca's. They do make some noise. Glad its fixed.
    Jon27[QUOTED] likes this.
  18. Mar 1, 2017 at 2:19 PM
    Smar969905
    Zach
    Deer Park, WA
    Go back to wherever you got your tires, and see about getting them to rebalance them. Start with the fronts for the vibrations in steering wheel.
    Does the vibration go away above 45ish mph? If so, don't bother to get tires balanced, and look into carrier bearing drop, what I quoted Brady on below. Installing it should take all of about 5 minutes, as it is held in place by 2 bolts. It is nothing more than a spacer with longer bolts to lower the joint in the rear driveline, which straightens it out so the balance of it is corrected as a whole.
  19. Mar 1, 2017 at 3:56 PM
    Foggy Noggin
    Foggy Noggin Well-Known Member
    Puyallup
    2019 Tacoma TRD Off-Road
    Anyone ride? Told my self I'd chill when it comes to truck stuff... so I was forced to start a new hobby :rofl:
    btripptrd, dakotasyota and Jon27 like this.
  20. Mar 1, 2017 at 4:33 PM
    Jon27
    Jon
    Salt Lake City, UT
    I hear the uniballs but it was a thump at the end of the shock. I pulled the winch for now. Had some family stuff come up.
    When I had the tires off I did notice a few weights missing so I am sitting at discount getting them all balanced and rotated.
