NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Feb 16, 2018 at 7:41 AM
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    “Front wheel bearing swap is 45 minutes per side” they said......
    3.5 hours later, one side is done.....:annoyed:
    Projects never seem to go smoothly for me. I think my CB needs to be replaced. Thinking I’ll just order a 1-piece from Tom Woods.....
    Juforrest and bobsuruncle like this.
  2. Feb 16, 2018 at 8:00 AM
    utroda
    utroda Well-Known Member
    Jared
    PNW
    06 DCSB SR5 4x4
    I don't understand how a 1 piece would work without modify your pinion angle?
  3. Feb 16, 2018 at 8:03 AM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    I'll be doing a wheel bearing and carrier bearing on my truck this weekend too. If I've got time, my LCA uniballs too.
    Unrelated, I'm on the hunt for a 4.30 elocker 3rd member and a 3rd gen front diff equipped with 4.30 ratio also. I think I've found the easy way to change gears without spending $$$. Hoping I can find both for around $1200 or so.
    Juforrest and utroda like this.
  4. Feb 16, 2018 at 8:12 AM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    As long as both angles are (close to) identical but opposite on both ends it’ll work (both outputs must be parallel), which is how Tacoma’s come stock even with the CB. It wouldn’t work if there say the pinion pointed at the tcase because there would be an angle at one end but not on the other. That would be the set up for a double cardan.
  5. Feb 16, 2018 at 8:28 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    What are you cooking up?
  6. Feb 16, 2018 at 8:47 AM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    97+ elockers are the same. The Limited T4R came factory with 4.30 ratio and will bolt right into a 2nd gen off-road housing. The 3rd gen tacomas still use the 8" High pinion that the 2nd gen uses. They changed the rear axles on the 3rd gens so no interchanging there. The 1st gen off-road tacomas came with 4.10 ratio, which I'm contemplating also. The 4cyl 2nd gen tacoma AFAIK also uses a 8"HP and was available with 4.10 ratio. Still need to confirm the 4cyl assembly will be a direct swap. With the 2nd gen having a carrier break at 3.73/3.91, gear swaps jump in price significantly as you need to purchase the 3.91 housing to put lower gears in it. Not possible with the 3.73 front clamshell as there isn't enough room for the ring gear on lower gear sets to fit in there and also the deck height difference.
  7. Feb 16, 2018 at 8:48 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Somebody's been doing their homework.
    Yetimetchkangmi likes this.
  8. Feb 16, 2018 at 8:52 AM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Yeah, I doubt I'll ever DD on 35's, just outings here and there, so 4.10/4.30 would be in the ideal range. 4.56 is a bit low if I'm going to be on 33's the majority of the time, from what I've read posted by others.
  9. Feb 16, 2018 at 9:03 AM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    No tacomas have a HP 8"... only Toyota's to have that were the 80 series I think.
  10. Feb 16, 2018 at 9:04 AM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    The front diff on the 2nd gen tacomas is a 8" HP. At least for v6. Same with 4thgen+ t4r and fj cruiser.
  11. Feb 16, 2018 at 9:09 AM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    The front is really? huh did not know that
  12. Feb 16, 2018 at 10:46 AM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    For sure! Let’s tey to plan a trip in April for some spring skiing
  13. Feb 16, 2018 at 10:53 AM
    STacoS
    STacoS Well-Known Member
    Loren
    Poulsbo, Washington
    2019 T4R OR
    I still have my oem 4.30 gears sitting in the garage.
  14. Feb 16, 2018 at 12:36 PM
    Greddy
    Greddy Would you eat the moon if it were made of ribs?
    Cam
    Bonney Lake, WA
    It's a Tacoma, white n black, DCLB
    Front & Rear HC Bumper with Swing Out, Full Skids, Icon CO's and UCA's, Dakar w/AAL, Icon Rear Shocks and U-bolt flip, w/Superbumps. 17" XD Wheels, 34" BFG KM3s, CB/Ham Radio, 10% Tint, Snugtop, WeatherTech Mats and Deflectors, Rigid Fog Lights, UltraGauge, TRD Seatcovers, On-Board CO2 and 20L fuel. Roof Top Tent. AirFlow Snork, smittybilt winch, 20" light bar.
    This is probably not the right place to ask this question but you guys are smart.
    My buddy has a 2005 GMC 2500HD regular cab long bed. He's got a 4wheel camper on it, the big 8foot Grandby. He's turning it into the ultimate overlander, but right now its stock height with 265s.
    He can't find a lift kit that works for his truck. 4 wheel parts was installing a 6" procomp Knuckle lift but on page 7 it says "will not work on regular cabs" because the drive shaft is too short and will cause serious vibrations due to the extreme angle. He really wants to avoid a drop bracket lift, but there aren't a lot of options.
    Any one know anything about these trucks and the suspension. It's got IFS with a solid axle in the back much like our trucks. How do people lift these regular cab long beds?
    Thought I would give it shot.
  15. Feb 16, 2018 at 12:56 PM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Doesn't say poop about not working on a regular cab. Have some deaver springs custom made and maybe find better shocks but it comes with bilsteins so that's a good start.
    https://www.superlift.com/6-inch-li...ra-2500hd-or-3500-4wd-knuckle-kit-with-shocks
    Greddy[QUOTED] likes this.
  16. Feb 16, 2018 at 1:19 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    Does anyone want to offer a few bucks for my double cab bed to make into a trailer? No tailgate needs tail light area worked on bobbed 10". I dont have room to store it.
  17. Feb 16, 2018 at 1:20 PM
    TheToyotaGarage
    TheToyotaGarage Well-Known Member
    Monroe
    Pacific NorthWest
    2017 TRD Toyota Tacoma
    King 2.5 Resi / ADJ/ EXT - king 2.0 Rear Bump Stops - Kibbetech Gold Billet UCA's - 285/75/17 10ply Nitto Ridge Grapplers - Stealth Custom Series 17x9 -38 Stealth Blue Ray10's, Icon RXT Rear Leaf Springs
    Shoulda! If anyone needs major services and stuff let me know. I can get you all set up with an advisor and some discount.
  18. Feb 16, 2018 at 1:32 PM
    scollins
    Scott
    Renton WA
    Yep, figuring a double cardan at the T-case.
    https://www.tacomaworld.com/threads/single-piece-driveshaft-vibes-be-gone.475797/
  19. Feb 16, 2018 at 1:38 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    PM inbound
  20. Feb 16, 2018 at 1:44 PM
    Greddy
    Cam
    Bonney Lake, WA
    Yeah my idea was for him to build it piece by piece. Get a custom leaf pack, longer shocks, then boost up the front springs and upper control arms. Just seems like the GMC lifts are all drop bracket, mall crawler lifts.
    Things are just so much simpler on a Toyota.
