NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Jul 27, 2018 at 9:15 AM
    CullenG
    CullenG Well-Known Member
    Cullen
    2012 white TRD Off Road
    I would say they are standard size. It's the set my dad gave me when i got my license, so haven't really paid attention to what's out there. Could be time for an upgrade, prior to this i had a 83 chevy k20 and 62 c10, much simpler ignition systems and they were manual so i pretty much had jumper cables for good simaritain reasons only.
    i will start with cleaning the terminals tonight.
    Loco38SUP likes this.
  2. Jul 27, 2018 at 9:20 AM
    JimSnell
    JimSnell Well-Known Member
    Jim
    Puyallup
    2015 White Tacoma TRD Sport DCSB
    do you have a regular 110v battery charger?
  3. Jul 27, 2018 at 9:20 AM
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    Is the starter cranking and it just won't fire or is it the starter not even cranking the engine?
  4. Jul 27, 2018 at 9:30 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Always start simple in diagnosing. Just swap the battery from your wifes car into the truck and see if it cranks (and starts). If it does you know its the battery. if it doesn't you know its electrical on the truck. Then move on from there. Even a car battery should crank over our engines....unless its some odd battery that's super low CCA.
  5. Jul 27, 2018 at 9:32 AM
    CullenG
    Cullen
    I did, it walked off with my tools about a year ago.
    Not even cranking, no clicking, nothing
  6. Jul 27, 2018 at 9:34 AM
    CullenG
    Cullen
    She drive a jeep liberty, sameish size battery. I would have tried that this morning, but didn't have time.
    velillen[QUOTED] likes this.
  7. Jul 27, 2018 at 10:09 AM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    My wife’s Acadia all of a sudden wouldn’t crank after the day prior having no issues. We would go to crank and the security theft stuff would flash on the dash. I figured someone at the oil change place messed something up from 2 days prior. End of the day: the battery just died that hard that it wouldn’t even turn the crank AND I learned that newer vehicles will befinn”shutting down” auxiliary systems to try and conserve power to crank, which is why the theft stuff came on (the vehicle stopped sending power to that portion which was just how severe the battery was). I was able to jump it with our Stanley battery box and once a new battery from oreillys was installed, we had no issues. Oreillys can also check the alternator to make sure it’s charging like it should also, free of charge. Gave me peace of mind knowing the alt was still good.
  8. Jul 27, 2018 at 10:13 AM
    JeffRoyJenkins
    Jeff
    Lake Stevens, WA
    Agreed, this is the fastest and easiest way to eliminate the battery as an issue. If you aren't even hearing the starter relay click though there is a chance you have something else going on because if it's got enough juice to light the dash it should have enough to cycle the relay even if it doesn't have enough to crank the starter. Then again with all the computer controls in there now it may just prevent power from getting that far if it senses that there isn't enough voltage to run the starter.
  9. Jul 27, 2018 at 10:21 AM
    JimSnell
    Jim
    Puyallup
    Where you located?
  10. Jul 27, 2018 at 10:35 AM
    CullenG
    Cullen
    North Bend
  11. Jul 27, 2018 at 10:49 AM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    That's what I'd do when you get home and I would bet itll point to the battery being bad. Sounds kind of like what happened to my Tacoma with the stock battery. But mine worked fine then sat for like 2 weeks then went to start it and got nothing. Tried jumping it and nothing. Hooked up a battery charger nd waited an hour and nothing.
    Course then I called Toyota Care and told them it was the battery. To which they told me I couldn't just take the battery to the dealer but had to have it towed there. So they towed it there just to replace the battery. But to make it even better the dealer decided to do an oil change since it was there without asking me. Which was ok since it was due more or less anyways. But then they tried to charge me for air filter (5k miles on it so still was good), cabin filer, and something else. Told them to pound sand and that I never even told them to do that service and it was only there for a dead battery under warranty. Was only like 30 bucks but it was more the point and them doing shit just to try to make money off warranty work. Took a good 30 minutes for them to finally accept that I wasn't going to be paying for shit I didn't authorize. Probably helped this was in their waiting room which was full of people and I made damn sure everyone could hear what was happening.
    bobsuruncle likes this.
  12. Jul 27, 2018 at 10:58 AM
    CullenG
    Cullen
    Yeah i'm going to do all of the more in depth things tonight. I had about 20 minutes this morning before my wife had to leave, so it was a kick the tire and say well shit troubleshoot.
  13. Jul 27, 2018 at 11:22 AM
    JimSnell
    Jim
    Puyallup
    So if I were to get pulled over right now, and the back of my truck were searched, they would legit find a body wrapped in a black garbage bag. :notsure:
  14. Jul 27, 2018 at 12:05 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    We had the same $hit happen to the CR-V (wouldn't crank as the security shit was "thinking" for me). Got it jumped and wife drove it to Costco but they refuse to install batteries yet the car was dead in their driveway bay. Kinda forced them help out.
  15. Jul 27, 2018 at 12:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Ah... Porcine goodness?
  16. Jul 27, 2018 at 12:29 PM
    JimSnell
    Jim
    Puyallup
    Unfortunately, this is the true ending to Charlotte's web.
  17. Jul 27, 2018 at 12:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I'm sure wilbur will be tasty.
  18. Jul 27, 2018 at 12:42 PM
    FN-2187
    FN-2187 Well-Known Member
    Irvine
    2017 Stormtrooper White Tacoma TRD Pro
    Snugtop Rebel with windoors
  19. Jul 27, 2018 at 12:50 PM
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    I'm mildly depressed that I'm going to miss the carnage:annoyed:
  20. Jul 27, 2018 at 1:48 PM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    @CullenG let me know if you need anything. I have a battery charger, tools, and what not.
