NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Nov 26, 2013 at 5:54 PM
    #4361
    Greenhatter
    Greenhatter Well-Known Member
    Washington
    Silver 2008 TRD Sport
    TRD Supercharger, Toyo Open Country M/T 285/75/16, 16" TRD Ivan Stewart Wheels, Clearbra
    Depending on what you're doing the handset speaker can get washed out in noise. But thats why there is an external speaker out jack.
  2. Nov 26, 2013 at 9:17 PM
    #4362
    08dsm
    08dsm Member
    Rory
    Graham, WA
    2013 TRD-off road
    Well not sure how to say it, but I'm looking for help installing a 3 inch bilstein 5100 with rear aal. I went to tackle it tonight, but am so overwhelmed. I live in graham.... Or any advice on shops that can do it without killing the wallet?
  3. Nov 26, 2013 at 9:46 PM
    #4363
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    It's not that bad.
    Get the front end on jack stand take
    take off tires and wheels
    Pull off skid plate, both skid plate brackets and sway bar (from frame and knuckle)
    Loosen the top 3 coilover nuts. Do not remove completely
    take off lower shock mount nut from bolt
    Remove cotter pin from upper control arm knuckle ball joint tthen loosen the nut. Not completely off but almost
    Smack the knuckle with a hammer pretty hard to allow the ball joint to pull out of the knuckle and drop.
    support the lower control arm and remove the ball joint nut so that knuckle can pull away from the upper control arm.
    With blocks or a jack hold up the lower control arm. Be careful not to let the cv joint pull out to far or it will separate the joint inside the boot. (Not advised)
    Remove remain coilover nuts and pull it all out.
    Take those coil overs and new ones to an auto shop the have your springs swapped over and the reverse this process for installation.
    it's not to hard just take your time. There can be many threads found on here way more informative than all that cap I just wrote down! Search and ye shall receive! ! Good luck!
  4. Nov 26, 2013 at 9:54 PM
    #4364
    08dsm
    08dsm Member
    Rory
    Graham, WA
    2013 TRD-off road
    Yea I called a shop like 3 blocks from my house, and he will do it for 40 plus tax. Gonna rip it all out in the morning. I was trying to do it myself. Had it all ripped out and the damn spring compressor won't even fit in between the coils. Just had a major panic attack lol. Well after I'm done and get tires installed on Friday, I am really interested in some meets. Any coming up?
  5. Nov 27, 2013 at 7:21 AM
    #4365
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    It's really not too difficult to do if you have some basic mechanic skills (I did it and I'm certainly no mechanic) but for $40 I would totally pay a pro to do the job. Your truck will be way more badass when the lift is on too! Good luck
  6. Nov 27, 2013 at 7:30 AM
    #4366
    InTheRough
    InTheRough Well-Known Member
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    I am about to order some t-nuts for the bed rack from Grizzly. I am getting 3 packs (12 t-nuts) for $12 but shipping is $8. Thought I would offer up to see if anyone else in the area needs any.
    Here is the link:
    http://www.grizzly.com/products/G9513
  7. Nov 27, 2013 at 11:05 AM
    #4367
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    Kolt -
    I just used Unitstrut nuts; they're already drilled and tapped to 3/8", and worked just fine for me. You should be able to source them at any electrical supplier locally..
    http://unistrutconstruction.com/pdfs/S04_hardware.pdf
  8. Nov 27, 2013 at 11:15 AM
    #4368
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    Or source through an electrician you know...I do have this well loaded van with strut nuts. I have a few threaded for 1/4-20, and probably a few for 3/8-16.
  9. Nov 27, 2013 at 11:44 AM
    #4369
    Bishop4x4
    Bishop4x4 Active Member
    NW Washington
    2012 SBDC Offroad
    OME 2", AP front APEX bumper
    Any one have a source for stainless tee nuts?
  10. Nov 27, 2013 at 11:48 AM
    #4370
    InTheRough
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    If you have some laying around I need at least 8 but was ordering extras for later uses.
  11. Nov 27, 2013 at 1:01 PM
    #4371
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    This seems a little more involved. I've always just removed the tie rod ends to change the coil-overs. This way you don't have to worry about the axles slipping out.
    RJM
  12. Nov 27, 2013 at 2:19 PM
    #4372
    08dsm
    08dsm Member
    Rory
    Graham, WA
    2013 TRD-off road
    Well all installed. Looks like I need new upper control arms. Passenger spring touches :(. Is this common?
  13. Nov 27, 2013 at 2:59 PM
    #4373
    Greenhatter
    Washington
    Yeah when you do a suspension lift it usually requires a UCA swap to clear the coils.
  14. Nov 27, 2013 at 3:42 PM
    #4374
    YFZ450MOE
    Moe
    Is the sway bar touching the coils?
  15. Nov 27, 2013 at 5:40 PM
    #4375
    LAoffroadin
    LAoffroadin BURY ME WITH MY TACO!!
    Joshua
    Northwest
    2012 offroad 4x4
    ICON stage 5 coilers w/ ICON ucas, dakar leaf pack with Fox rears, k&n cai, LED cab light, raceline 16 inch wheels , toyo m/t 33",painted front yota emblem gloss white, retrofit headlights with mirrimoto 3 " lenses running the 6k headlights. Bhlm, bestopper, wet okole seat covers (max 4), weather tech mats,winch with piaa fogs. All pro apex front bumper. Sliders etc
    this might sound like a stupid question, but did you take it off the stands and then see if its still touching?
  16. Nov 27, 2013 at 6:27 PM
    #4376
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    Plus if you rotate the coil a little bit you might get some clearance while you wait for uca's
  17. Nov 27, 2013 at 6:47 PM
    #4377
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    THIS is a good idea.
  18. Nov 27, 2013 at 9:21 PM
    #4378
    Bishop4x4
    NW Washington
    2012 SBDC Offroad
    I have 2" between my control arm and my springs. I didnt realize this was a problem. I wouldnt think the ball joint would last long if the arm was at enough angle to touch the spring. My springs had to be rotated just right to clear the sway bar.
  19. Nov 27, 2013 at 11:39 PM
    #4379
    mutilatedjak
    WA
    So benson.....
    When are you going to bust out map?
    And plan our next trip?
  20. Nov 28, 2013 at 1:29 AM
    #4380
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    :rofl:
    Dora needs to start working the strip to earn some pesos before she can go on any adventures. Whore.
    Probably after the New Year we can get something planned.
    Happy Thanksgiving you turkeys! Gobble Gobble
