NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Apr 2, 2019 at 4:25 AM
    BoatRacer
    BoatRacer Well-Known Member
    Olalla WA
    '02 TRD 3.4 5-Speed
    All Pro front bumper, Warn winch, leds, Dakar leaf pack, locker wire mod.
    Anyone going to the Portland swap meet? Stop by space 6132 at the Raceway and say hello. I’ll have a few extra chairs and cold beer for anyone here wanting to rest a bit.
    PNW/TRD Steve likes this.
  2. Apr 2, 2019 at 6:43 AM
    PacNW_Taco
    PacNW_Taco Get lost.
    Colby
    Tacoma, WA
    2016 Black DCSB OR
    Peachy Peach air fesheners
    For the turd gen'rs out there. Have any of you replaced your HPFP? The chirping on mine seems to be getting louder. Looks like T-SB-0016-18 addresses it. T-SBs are covered by the dealership, correct?
  3. Apr 2, 2019 at 7:17 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Do share how they do. Im getting rather close to needing the FJ40 tub to get blasted and been looking for places that will actually do it and not charge an ass ton fo rit
  4. Apr 2, 2019 at 7:55 AM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Will do
    They quoted me $100 an hour. For a whole tub it might make sense to rent a blaster and get several guys to go in and split the cost
  5. Apr 2, 2019 at 8:00 AM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    I have a "portable" 110lb one already. Did the frame with it and it wasnt bad. $100 an hour doesnt sound bad. With an industrial setup they should be able to get it done in an hour or two. I called one place and they wanted 100 an hour plus a 300 "handling" fee. And a 4 hour minimum charge. My response was "ya know, if you dont want the work just fing say that instead of quoting me BS" and hanging up
  6. Apr 2, 2019 at 8:15 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Nuh uh. Didn't even know it was an issue. Tsbs are covered under warranty.
  7. Apr 2, 2019 at 8:19 AM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    :eek: That’s insanely expensive. They said that the have no minimum. @bobsuruncle, I’ll let you know if i can do it before then, grandpa passed away this weekend so the farm is kinda chaos right now
  8. Apr 2, 2019 at 8:35 AM
    PacNW_Taco
    Colby
    Tacoma, WA
    2016 Black DCSB OR
  9. Apr 2, 2019 at 8:51 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    Just be sure to clean everything really well with some brake cleaner before you weld it.
    bobsuruncle[QUOTED] likes this.
  10. Apr 2, 2019 at 8:52 AM
    Capt. Obvious
    Darrick
    Gig Harbor
    '12 DCLB TRD
    It depends on the issue, but a lot of TSBs apply whether you are in or out of warranty.
  11. Apr 2, 2019 at 8:57 AM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Yeah Ive really found I get pissy with people who just waste both our time doing BS quotes like that. Which is kind of funny cause those that do that shit Ill never call again. The few companies ive dealth with that just turn down the work right away I usually end up going back to for other stuff.
  12. Apr 2, 2019 at 9:28 AM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    I haven't had mine replaced, but I have noticed that it's less noisy with Costco gas and noiser with Fred Meyer gas. Could all be in my head though.
    PacNW_Taco[QUOTED] likes this.
  13. Apr 2, 2019 at 11:12 AM
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    How many miles do you have? Washington is covered under the California Emissions Control warranty rules, and the HPFP is covered for 7 years or 70,000 miles.
    https://www.toyota.com/t3Portal/document/omms-s/T-MMS-16Tacoma/pdf/T-MMS-16Tacoma.pdf
    dilbert likes this.
  14. Apr 2, 2019 at 11:30 AM
    PacNW_Taco
    Colby
    Tacoma, WA
    2016 Black DCSB OR
  15. Apr 2, 2019 at 11:48 AM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    18 LX570 on 35s, 06 Tundra DC beater
    I just ordered a Coastal Offroad bumper kit that I need to weld together and I have a few questions. I have a MIG setup that I am currently running flux core wire in. Should I upgrade to gas shielding for better results on 3/16ths steel and do you guys think this is something im going to be able to glue together with decent technical knowledge but not much practice?
  16. Apr 2, 2019 at 11:57 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    bobsuruncle, JeffRoyJenkins and ST77 like this.
  17. Apr 2, 2019 at 12:09 PM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    It says metal right there on the label
    Eazy.E and rlx02[QUOTED] like this.
  18. Apr 2, 2019 at 12:28 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Looks like a pretty easy kit to do. Lots of tacking it together and then you can just stitch weld it and grind down. Long as you are comfortable in your welds (ie getting penetration) I'd say do it.
    As for flux vs shielded.....up to you. If you dont weld much flux will work fine. Gas will leave cleaner welds but you are going to be grinding anyways for the bumper. But if you buy a bottle you'd also have 5+ years (depending on the hydro) to use up the gas.
    milleniumfu and Nimitz[QUOTED] like this.
  19. Apr 2, 2019 at 12:48 PM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    Dont do enough to really justify the bottle and you make some good points about it not really being visible too.
  20. Apr 2, 2019 at 1:00 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    In which case I'd just stick to flux core if thats what you are used to.
    I only breifly looked at the kit over at ih8mud but looks like its just all the pieces precut so its more just an assembling it than having to do any sort of fabricating. Tack it every 6" or so then just do some stitch welding to keep the temps down and keep it from warping. Then grind everything smooth.
    Nimitz[QUOTED] likes this.
