NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Apr 15, 2019 at 3:56 PM
    gravyboat
    gravyboat Well-Known Member
    Jon
    Olympia
    Jesus, glad you’re alright. Great reminder for the group. Probably couldn’t pull a needle out of your ass with a tractor when that happened lol
  2. Apr 15, 2019 at 3:59 PM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    18 LX570 on 35s, 06 Tundra DC beater
    I almost literally shit myself.
    Fixxxer, OutbackHack, Eazy.E and 4 others like this.
  3. Apr 15, 2019 at 4:01 PM
    gravyboat
    Jon
    Olympia
    Damn lol record scratch, freeze frame- this is me when I nearly pooped my pants.
    scollins and Nimitz[QUOTED] like this.
  4. Apr 15, 2019 at 4:09 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    Not gonna lie, I like that.
  5. Apr 15, 2019 at 4:11 PM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    This month
    BlackPearl and gravyboat[QUOTED] like this.
  6. Apr 15, 2019 at 4:12 PM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    Same. I like GXs on 24s too but im not sure thats how i want to live my life.
  7. Apr 15, 2019 at 4:35 PM
    JimSnell
    JimSnell Well-Known Member
    Jim
    Puyallup
    2015 White Tacoma TRD Sport DCSB
    Neither. I got actual sick. It sucked.
  8. Apr 15, 2019 at 4:40 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    I’m considering
    I dony hate that.
    Glad you here you’re safe. Time to upgrade jackstands.
    Nimitz[QUOTED] likes this.
  9. Apr 15, 2019 at 4:43 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Let me know, It definitely needs to be adjusted but i think that my heavy right foot and laughing at the black smoke is hurting me more than anything.
  10. Apr 15, 2019 at 4:46 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    The values that the egr uses to open and close need to be maxed out so it doesn’t open. Same with the fueling rate.
    Stolen from the TDI club forum:
    Idle Injection Quantity: Larger nozzles will deliver more fuel than the ECU thinks that itís delivering. By changing the idle injection quantity (which is sort of a misnomer), youíre recalibrating some constants in the ECU relating to fuel delivery which results in better idle speed control and, depending on the state of your particular engine, less smoke.
    With your engine idling and warm (very important!) and all accessories off, hook up your VagCom and go to 01 ñ Engine. Login using 12233. Go to ìAdaptationî and select Block 1. The adaptation value should be at a default of 32768, and you should see a field indicating the amount of fuel being injected in mg/R. Itís a good idea to get the injected quantity in the range 3.0 ñ 5.0 mg/R. Modify the adaptation value by 100 at a time and press ìTestî to see what happens to the injected quantity. To make the injected quantity go up, you reduce the adaptation value by 100. Play with this until you get in the range, and hit ìSaveî. If you canít get within the range, get as close as possible (there is a minimum and maximum adaptation value), and as long as your engine runs OK, donít worry about it.
    EGR Adjustment: At idle and part-load situations, the EGR system recycles some of the exhaust gas into the intake. This reduces NOx emissions. Itís possible to reduce the amount of EGR so that there is less exhaust recirculated and more fresh air. More air is good, because your larger nozzles mean more fuel! (Note: this is a good idea even for stock engines, since less EGR means less soot to gunk up the intakeÖ do a search for ìmanifold cloggingî on Fredís for details if youíre not familiar with the problem.)
    With your engine idling and warm (very important!) and all accessories off, hook up your VagCom and go to 01 ñ Engine. Login using 12233. Go to ìAdaptationî and select Block 3. Give the throttle a quick punch to the floor (if the car idles too long the EGR system turns offÖ this turns it back on.) The default adaptation should be 32768, and the screen should indicate an actual flow rate of around 250 mg/R. Enter 33768 as the new value, hit ìTestî, and the flow rate should increase. Hit ìSaveî and youíre done.P
  11. Apr 15, 2019 at 4:49 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    Heard it slam shut in Tacoma!
    Glad you’re ok.
    Nimitz and gravyboat[QUOTED] like this.
  12. Apr 15, 2019 at 4:55 PM
    Capt. Obvious
    Darrick
    Gig Harbor
    '12 DCLB TRD
    My version of VAGCOM can definitely do what you posted above. Worst case scenario (if you don't find anyone with the unlimited VIN version), you can use a VIN on mine for $100 (it's $200 for three VINs and I only have one VIN left). Added bonus, if you do that you can borrow it anytime to do more fiddling.
    Oh wait, what year is your TDI? Certain years don't have the VIN stored in the ECU so it doesn't count against the three.
  13. Apr 15, 2019 at 6:10 PM
    SalmonTaco
    SalmonTaco Well-Known Member
    Andrew
    Naches
    08 Silver TRD Sport
    Brute Force bumpers, TRD FauxLocks, 5100s & 885s, Falken Wildpeaks, SnugTop MVP Shell, Tuffy Bed Box, Console Vault, Fogs anytime, ImMrYo mirror bracket, Wet Okoles, aFe Pro Dry S, PowerStop Z36 pads & drilled/slotted rotors, more shit I can't remember
    Why do I find VAGCOM so damn funny every time I see it?
  14. Apr 15, 2019 at 6:11 PM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    I'm hoping to get some VAGCOM tonight
    hello vag can you hear me?
    yes, exulted one
    Eazy.E, JimSnell, Juforrest and 2 others like this.
  15. Apr 15, 2019 at 7:55 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Id go with @Capt. Obvious 's offer since Im not sure when Ill see him again let alone borrow his laptop for the weekend.....let alone make it your way lol
    Just saying VAG (volkswagen auto group) is fun
    Usethe2nd[QUOTED] likes this.
  16. Apr 15, 2019 at 8:01 PM
    Sparky.
    Sparky. Bought, built, totaled
    Dawson
    Enumclaw Washington
    ‘14 AC 6MT -R.I.P, ‘08 cummins
    That’s no good, we needed someone to brave the first run over.
    If you want to try on a weekend day hit me up. Maybe on the 27th before the brewery?:notsure:
  17. Apr 16, 2019 at 8:59 AM
    Eazy.E
    Eazy.E Big gulps huh?!
    Erik
    Snohomish, Wa
    06 DCLB TRD Sport Trail Whale
    sketch man.
    I had a oh shit moment last year. In a rush and wasn't thinking things through all the way. nothing fell but I had a sway going that terrified me.
    glad you're ok!
  18. Apr 16, 2019 at 12:05 PM
    Sparky.
    Dawson
    Enumclaw Washington
    Conspiracy theory podcasts make the work day fly by..... and makes my head hurt....
    Bigheadtinyarms and velillen like this.
  19. Apr 17, 2019 at 9:48 AM
    TheToyotaGarage
    TheToyotaGarage Well-Known Member
    Monroe
    Pacific NorthWest
    2017 TRD Toyota Tacoma
    King 2.5 Resi / ADJ/ EXT - king 2.0 Rear Bump Stops - Kibbetech Gold Billet UCA's - 285/75/17 10ply Nitto Ridge Grapplers - Stealth Custom Series 17x9 -38 Stealth Blue Ray10's, Icon RXT Rear Leaf Springs
    Got a set of 2019 TRD Pro Tacoma Fox Shocks for sale if anyone is interested. 4 Miles on them.
  20. Apr 17, 2019 at 11:07 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
