NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Aug 18, 2019 at 6:05 PM
    Bigheadtinyarms
    Bigheadtinyarms Well-Known Member
    Seth
    Cedar City, UT
    91 FJ80, 07 DCSB
    37’s locker bumper winch lights seats LS Swap, 35’s winch lights roof rack suspension armor plasti dipped
    You can just remove sway bar entirely.. I’m able to just disconnect upper arm from spindle and pull it
  2. Aug 18, 2019 at 6:38 PM
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    Sway bar is in the garage
    Bigheadtinyarms likes this.
  3. Aug 18, 2019 at 6:53 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    I don't have one on my truck but I don't like to assume it's been removed from every truck on TW. If I say remove just outer TRE and there's still a sway bar they will still have a problem.
    Even easier then, one but for the TRE, 3 at the top on the coilover and one at the bottom. Loosen the coilover bolts while it's still on 4 wheels, then jack the front end and the coilover will drop right out
  4. Aug 18, 2019 at 7:59 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    My 10mm has more kills than any other gun i own except my shotguns
  5. Aug 18, 2019 at 8:00 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    What suspension are you running?
  6. Aug 18, 2019 at 8:25 PM
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    Not sure if anyone answered yet, just now seeing this. Been gone all weekend for my bachelor party.
    This is similar to the one I have. I got it from a guy who was advertising on here as Instant Air Supply but it sounds like he isn't doing it anymore.
    https://www.amazon.com/dp/B0085EVSOU/ref=cm_sw_r_cp_apa_i_0wHwDbEZSWAH0
    The fixed pressure regulator keeps it nice and simple for our application. 150 might be a little much if you want to run air tools but most should be able to handle it for limited use.
    Also I snapped a picture of the mount I have. When the tank is in there I have it setup with the regulator pointing toward the side so I can access it just fine with the bed fully loaded. Having it at the front of the bed means my 12ft hose can reach all 4 tires from that location as well.
  7. Aug 18, 2019 at 8:53 PM
    PNW/TRD Steve
    WA
    2012 DCSB TRD
    BP-51s
  8. Aug 19, 2019 at 7:12 AM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Any reason you dont adjust the driver side preload to compensate for lean?
  9. Aug 19, 2019 at 7:28 AM
    PNW/TRD Steve
    WA
    2012 DCSB TRD
    Mule said adjusted it to the point that any mow may.adversely affect the handling. Plus, more preload equals less down travel if I'm correct.
  10. Aug 19, 2019 at 7:34 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
  11. Aug 19, 2019 at 9:11 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    One thing the Harrop does it unlocks when you come to a stop and go in reverse but will quickly lock again
  12. Aug 19, 2019 at 10:48 AM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I've seen a few rattlesnakes in E. Washington. They're very shy, had to look under bushes to find them.
  13. Aug 19, 2019 at 11:29 AM
    TexMeg89
    TexMeg89 Well-Known Member
    Seattle
    2017 Barcelona Red Tacoma TRD Off-Road
  14. Aug 19, 2019 at 11:41 AM
    Jon@Mule
    Jon@Mule Well-Known Member
    Jon
    Issaquah, WA
    2001 Tundra Limited
    35" MTR's, 4.88's , Air Locker front and Rear
    Exactly why I run a ARB.
    TheToyotaGarage likes this.
  15. Aug 19, 2019 at 12:46 PM
    hoarder23
    Shay
    NJ
    Scratches
    I've never noticed that I had that occur and have used it in similar circumstances to what I've heard can cause that to happen. I think the times when that happening would cause a problem are so rare that it's not really worth worrying about. I find the downsides of an air locker are more of a cause for concern, real hard to trail repair an air line.
    TireFire[QUOTED] likes this.
  16. Aug 19, 2019 at 1:06 PM
    Jon@Mule
    Jon
    Issaquah, WA
    2001 Tundra Limited
    Airlines are easy to repair, anything internal not so much. That being said, installation is critical! I haven't had an issue with either of my air lockers in the 4-5 years I've been running them. I'm just not a fan of Harrop, and I get some people aren't fans of ARB's. That's ok!
    PNW/TRD Steve likes this.
  17. Aug 19, 2019 at 5:05 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    No Jon, it's not okay. This is the internet, and we don't take kindly to dissenting opinions around these here parts. The correct response is to talk to anyone who doesn't agree with you as if they are an idiot, and then insult something about them that has nothing to do with the topic.
  18. Aug 19, 2019 at 5:44 PM
    TireFire
    Olympic Peninsula
    I agree which is why I went with it. Tried and true down under where they do wheel their rigs hard, not baby them like most here in the US.
    I installed mine myself and I use CO2 for tires instead of a compressor so the Eaton/Harrop locker made more sense for me but I wouldn’t say it’s better than ARB. Just a little cheaper, in my case, and simpler to set up
  19. Aug 20, 2019 at 9:39 AM
    Capt. Obvious
    Darrick
    Gig Harbor
    '12 DCLB TRD
    Random question about the ARB locker (or any air lockers in general I guess): when locked, does it require constant air pressure to stay that way, or does it just need a single burst of air to lock, then another another burst to "turn it off"?
  20. Aug 20, 2019 at 9:40 AM
    TireFire
    Olympic Peninsula
    Needs constant pneumatic pressure
