NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Nov 19, 2019 at 11:31 AM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    That is when there are heavier straps, rated for more weight, and more of them.
    I was pulling a 20 ft flatbed a couple months ago loaded with logs, some of the logs hanging over the rear. I estimate it was about 13-14k lbs of trailer and load. The trailer was loaded wrong, and ended up fish tailing then peeled off the hitch and rolled. My safety chains were attached with carabiners, which of course straightened out instead of holding. The logs all stayed strapped to the trailer when it rolled into the ditch, as well as when it was rolled back onto the wheels by the wrecker. If those safety chains held, it probably would have taken my truck too.
    Check the air filter first. New fuel second. I have occasionally put a splash of fuel on the air filter to help it start when too lean, but if it is already flooded, that won't help. Also look at the spark plug. That could be fouled by too rich of fuel mix. You may need to get a new fuel filter and lines. Old fuel can leave crystals, which block the line, or can block the jets in the carb.
    After getting to this point, things start getting a bit more complex. Adjusting the carb (tuning), cleaning the carb, carb rebuild kit.
    I am assuming this is all from not being able to get the saw started.
  2. Nov 19, 2019 at 11:36 AM
    Smar969905
    Zach
    Deer Park, WA
    What size? According to Optima website, yellowtops for my truck are about $265-275 each, and I'd need 2
  3. Nov 19, 2019 at 11:39 AM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    when we used to move big crawler cranes on barges, we would just weld the treads to the deck!
    bobsuruncle[QUOTED] likes this.
  4. Nov 19, 2019 at 11:42 AM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Was looking at the wrong receipt, was about to host a GB
    bobsuruncle likes this.
  5. Nov 19, 2019 at 12:18 PM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    18 LX570 on 35s, 06 Tundra DC beater
    I watched this dumb fuck get high centered when he tried to drive through the grass to a frontage road off Airport way. Instead of shaving 30 seconds off his commute, he got left there until the cops showed up. I rolled my window down so he could see me laughing my ass off at him.
  6. Nov 19, 2019 at 1:12 PM
    Goran
    Goran Well-Known Member
    Jacob
    WA
    2023 Tundra Pro
    That flex though...
    cosmicfires likes this.
  7. Nov 19, 2019 at 2:50 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Which part get plugged into the wall socket? the chain? I'll let you do that...:der:
    And not sure where air filter is and all that stuff. This is a newish thing for me...
    PDF online helps somewhat...
    Like learning heart surgery on YouTube...
  8. Nov 19, 2019 at 3:01 PM
    Goran
    Jacob
    WA
    2023 Tundra Pro
    go after the big 3 first.
    Spark, Compression, Fuel.
    If you need help i'm pretty handy with small engines, i live in MLT .
  9. Nov 19, 2019 at 4:00 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    I hope you have a spark plug?
    PNW/TRD Steve likes this.
  10. Nov 19, 2019 at 5:45 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    I missed what make and model you have but generally speaking the following applies
    How long has it been sitting?
    The airfilter will be right above your grip on the throttle. Pull the air filter and make sure it’s clean. I’d swap out the plug just so you know you’re GTG and while doing so check for spark, lay the spark plug on the cylinder head and slowly pull the starter cord you should be able to see it sparking (you can do at the painful way and just hold on to the spark plug while using the pull start, won’t cost anything bust maybe some brain cells and swear words). If it has been sitting for quite some time, you’re going to want to dump out all the fuel and pull your carburetor and clean your it. Mess with the least amount of turney screws on the carb itself to prevent the need for a carb tune.
  11. Nov 20, 2019 at 11:16 AM
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    It is a Stihl 011 AVT and I got it handed down from a guy that didn't want to bother even working on it.
    I planned on getting a spark plug, some chainsaw fuel and clean it up.
  12. Nov 20, 2019 at 12:04 PM
    Filip38507
    Filip38507 Well-Known Member
    Filip
    Lynnwood Washington
    2019 Tacoma TRD Offroad
    Which trails is everyone planning to run this weekend?
  13. Nov 20, 2019 at 1:43 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    The garage
  14. Nov 20, 2019 at 2:28 PM
    PacNW_Taco
    PacNW_Taco Get lost.
    Colby
    Tacoma, WA
    2016 Black DCSB OR
    Peachy Peach air fesheners
    Bread line.
    *shakes ammo can* spare change?
  15. Nov 20, 2019 at 4:42 PM
    twalchlii1
    Tom
    Wa
    2018 GC Trailhawk
    my surgeon says the difference between mechanics and surgeons is surgeons fix while it’s still running!
  16. Nov 20, 2019 at 4:59 PM
    JimSnell
    JimSnell Well-Known Member
    Jim
    Puyallup
    2015 White Tacoma TRD Sport DCSB
    He hasn't met any real mechanics then. That's why boats have two motors.
    ST77, JDAM, bobsuruncle and 1 other person like this.
  17. Nov 20, 2019 at 5:33 PM
    twalchlii1
    Tom
    Wa
    2018 GC Trailhawk
    not sure what that means but we did used to do Oil changes with the engine running. Had auto feed and evac system! Would suck out the oil and add it at the same time! Did a lower bearing Change while running once. Never again. Even with cyl disconnected was terrifying to climb in under the piston.
    Edit
    Talking Wartsila giant 2 stroke bunker fuel engines that weigh about 120 tons. They have a door in the bottom of the cylinder so you can climb inside
    Also very smelly in there.
    cosmicfires and bobsuruncle like this.
  18. Nov 20, 2019 at 7:21 PM
    PacNW_Taco
    Colby
    Tacoma, WA
    2016 Black DCSB OR
    How does that work without evacing some of the new oil? Or is that just part of the process?
  19. Nov 20, 2019 at 8:09 PM
    twalchlii1
    Tom
    Wa
    2018 GC Trailhawk
    full change was usually about 120% of total capacity. At 100 hr intervals even 80% would be ok. Plus a 2 stroke on #2 bunker is dirty as shit anyway.
  20. Nov 20, 2019 at 8:19 PM
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    The newer camless engines are so much cleaner inside, even with HFO. Scav boxes still get filthy, but that's what cadets are for.
    twalchlii1[QUOTED] likes this.
