NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Mar 20, 2020 at 6:20 PM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    I have no experience with soft vests but I took a look at these. You get your level IIIa+ and can attach all the pouches you want.
    https://safelifedefense.com/product/tactical-enhanced-multi-threat-vest-level-iiia/
    I have a couple carriers with level IV(heavy) and level III+(much lighter) plates. My next carrier might be a Spiritus.
    Chest rig isn't a bad idea. Light and fast.
    I'm just a John Wick LARPer though.
    ready6delta and Yetimetchkangmi like this.
  2. Mar 20, 2020 at 7:24 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Buy ADS :D
  3. Mar 20, 2020 at 8:33 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Too easy crye precision jpc
    ready6delta likes this.
  4. Mar 20, 2020 at 8:34 PM
    AANorthwest
    AANorthwest Well-Known Member
    Washington
    2012 DCLB 4x4 TRD sport
    I heard about that. must have been on a job I was on maybe or I knew someone that knew him. Crazy sad!!
  5. Mar 20, 2020 at 8:46 PM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    I have BP-51s on my Tacoma and yes the fronts have been warrantied twice. Once for seized lower bearings and soon after both of them started leaking at the shafts. I'll never buy or recommend them again.
    What type of off-roading do you do? I ask because I have a GX as well and opted for a less advanced setup using Dobinsons springs and twin tube shocks. I've only taken it on two sections of the wabdr and it performed well for that type of off-roading. I don't think I will spend my money on such expensive setups anymore. If anything I may upgrade to the Dobinsons IMS shocks that feature larger diameter shocks with the fronts being threaded for height adjustment. They also have the MRR (remote reservior) and MRA (remote reservoir + adjustable dampening) if you fancy those.
  6. Mar 20, 2020 at 8:54 PM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    18 LX570 on 35s, 06 Tundra DC beater
    My buddy just got the MRA so ill wait for him to install them and then see if I like them. Its still my daily, so I might go back to foam cells. I didnt mind them.
    yeos[QUOTED] likes this.
  7. Mar 20, 2020 at 9:11 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    I found out who ever wired my house, labeled the main breaker panel incorrectly. By quite a bit. While replacing a bad outlet that I assumed was off based upon it's location and the label on the breaker I switched off, my beard stood on end for a second and I may have pee'd myself. :anonymous:
    After that I went and bought one of the Klein tester kits and went through the whole house breaker by breaker and found a handful that weren't of the run one would associate them to based on the labels in the panel. I've corrected the labeling to include the randoms...
    I've worked on 3 phase 480 when we had our old crushing plant, completely tearing conveyors down moving location and rewiring but thankfully I've been lucky enough and probably mostly through training like LOTO to still be alive. A few of the conveyors rotated in reverse rather than forward, but a quick switch of the leg wires fixed that. That's definitely no joke compared to residential 110.
  8. Mar 20, 2020 at 9:22 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    440V aint no joke, nor is 220V.
    We allegedly used to use a megger (hand held resistance tester, hand cranked for 500v and push button circuit) on the rickey recruits (E-1s),
    I would hold both leads and my bud would crank it but not press the button.
    Recruit would do it but button might have accidentally got pressed; opps.
    Nobody peed themselves... at least that they would admit to...
    bobsuruncle[QUOTED] likes this.
  9. Mar 20, 2020 at 11:26 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    He was out in ellensburg but grew up in the edmonds area.
  10. Mar 21, 2020 at 6:25 AM
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    Must've been the same guy that did the panel in my house. It seems like whoever labeled it was sent out there with a sheet of labels and just stuck them on there in the order they pulled them off the sheet. Went to do some work on my furnace and after the one labeled for it didn't shut it off I found the refrigerator breaker did the trick. One of these days I just need to say good bye to my clocks for a bit and just go around the house flipping breakers and relabel everything because nothing matches other than the couple I have already fixed.
    Doing aircraft electrical makes for some fun experiences with getting zapped and lots of stories where things could've easily been way worse than they were. 115VAC feels real funny at 400hz compared to 60hz too. When I worked on the 787 we had some HVDC systems that ran large motors using +/-270VDC for a potential of 540VDC.
  11. Mar 21, 2020 at 11:51 AM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Do you know of anything similar that comes in black?
    Also where can i go to test fit one?
  12. Mar 21, 2020 at 11:55 AM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Same here but if the economy tanks, people might get desperate. I want to have the best chances possible. It really makes me want a canopy camper or Khaya from Alucab. If got bad enough i could leave for 2-3 weeks and let stuff settle down
  13. Mar 21, 2020 at 12:09 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i thought about a rtt for myself too. trouble is this problem wont go away in weeks. then if it evovolves like influenza it could be an annual thing.
  14. Mar 21, 2020 at 12:24 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    ive lived outta my RTT, it works for shorter periods of time, I’d like something a bit more wall tent like
  15. Mar 21, 2020 at 12:49 PM
    ninernation
    ninernation Well-Known Member
    WA
    TRDOR
    OME, ALUCAB, RCI
    You're looking for a plate carrier. Everyone makes them. People have even been wearing them in the CrossFit games, 5.11 brand. Same shit but they load them with weight plates instead of ballistic plates.
    Doubt you'll find many places to try them on now but after this passes there's tactical tailor outside of jblm
    https://www.tacticaltailor.com/fightlightplatecarrier.aspx
    I haven't tried that specific carrier but as I said earlier TT was making nylon gear for dudes in the gwot while most other companies werent yet around. They've kind of failed to innovate since then but they can make a plate carrier with molle just fine. first spear strandhogg is my go to with soft armor and plates in the cummerbund but it's $$$
  16. Mar 21, 2020 at 1:00 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i really get it. im curious about the reason for bed bar height for this hobby. i have a saddle jobox but would want the lowest, high quality mounting system.
  17. Mar 21, 2020 at 1:17 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I have a bed rack that a friend made me that makes a rtt sit lower than the cab. Bought to put it up for sale
  18. Mar 21, 2020 at 1:41 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    i build my bed racks so my tent sits just below my snorkel (highest point). Ideally I’d like it higher for easier access to the bed but I’d rather not pop a hole in my tent cover or tent itself
  19. Mar 21, 2020 at 1:50 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    im ,ok im not in the market yet but thats what id be interested in.
  20. Mar 21, 2020 at 5:46 PM
    JDAM
    J
    Worshington
    12 DCSB TRD OR
    Rattlesnake lake is like like a packed spring break beach. We don't want yous up here lol
    rlx02, bobsuruncle, dilbert and 7 others like this.
