NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Mar 28, 2020 at 3:11 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    officially....to attach an oil filter/other type of filters to the end of the barrel so it catches all your cleaning solvent as you clean your firearm from the breech end.
    Unofficially....just read the legal warnings on the item page and youll see the true purpose
  2. Mar 28, 2020 at 3:18 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    my stomach is flat. the L is silent.
  3. Mar 28, 2020 at 3:20 PM
    twalchlii1
    Tom
    Wa
    2018 GC Trailhawk
    sploosh,
  4. Mar 28, 2020 at 4:40 PM
    Apollo14
    Apollo14 EEF Brand Ambassador
    Jonathan
    Vail, CO
    2018 Cement Taco TRDOR DCSB
  5. Mar 28, 2020 at 4:43 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    You should see my stockpile.... Ok it's a junkpile.
    rlx02 and SilverYeti[QUOTED] like this.
  6. Mar 28, 2020 at 4:45 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    :gossip:
    You could say it turns BANG BANG into pew pew...
    ready6delta likes this.
  7. Mar 28, 2020 at 4:48 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    The resident TW trans expert says water intrusion.
  8. Mar 28, 2020 at 5:04 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    very likely. water+heat+oil looks like chocolate milk. If youre fine with company and need help lemme know.
  9. Mar 28, 2020 at 5:13 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    The wife just went to work and I've got the lil man to keep from tearing the house apart for a few hrs till he goes to bed, but if you want to come down tomorrow I'll text you my address.
  10. Mar 28, 2020 at 5:21 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    i dont have a dial type torque wrench but my digital Snap-on torque wrench shows current torque being applied. Do you think that’d work to set pinion preload?
  11. Mar 28, 2020 at 5:56 PM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Maybe I’ve never used one. Put it on a nut and see if it reads a very light pressure
  12. Mar 28, 2020 at 6:12 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    I like where this conversation is going:anonymous:
    Usethe2nd[QUOTED] likes this.
  13. Mar 28, 2020 at 8:06 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    it does, however the minimum reading it gives me is 60 in-lbs.
    spec is 20-24 in-lbs :annoyed:
  14. Mar 28, 2020 at 9:43 PM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Just order one from Amazon or something. I know it’s not snap on but it’ll get the job done.
    bobsuruncle and SilverYeti like this.
  15. Mar 28, 2020 at 11:31 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    That's like 2ft-lbs. Just have your kid give it his best shot, that oughtta be about right. Or I can bring cooper up and he can do it. :notsure:
    *Edit* I just remembered a trick my buddy did when he did his install years and years ago. It all makes sense to me now. Use a fish scale.
  16. Mar 29, 2020 at 12:04 AM
    Apollo14
    Jonathan
    Vail, CO
    Who has put in an HID conversion kit? Which one did you use?
    I've been researching for 4 hours now and my eyeballs are burning...
  17. Mar 29, 2020 at 12:07 AM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    You talking 35w vs 55w? AC vs DC? China or....... China? They're all pretty much made in china. Unless you buy OEM shit.
  18. Mar 29, 2020 at 12:15 AM
    Apollo14
    Jonathan
    Vail, CO
    I was thinking a 35w 4300k system. But was wondering if the Phillips 4300k was worth the extra $150 that most are charging. Also found a site that said 2013+ "American" cars need a PWM modulator. But according to a thread on TW, Tacos don't need them. So does that mean "American" means US auto manufacturers or US automotive market? It gets really confusing when the offer the PWM anti-flicker module but then offer an additional optional PWM module. If I do need one which one?
    :annoyed:
    $149.99 for barebones 4300k system vs $274.42 for Phillips 4300k system (both sans PWM modules):
    https://www.xenondepot.com/H11-HID-Kit-Xtreme-HID-XT-H11?quantity=1
  19. Mar 29, 2020 at 12:21 AM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    You shouldn't need the anti-flicker if you're running an add-a-circuit since the ballasts draw power directly from the battery and are triggered by factory plug wired to the headlight switch. I'm assuming the anti-flicker module is needed since most modern vehicles can tell you which bulb is out on the dash HUD since the ECU detects a variance in voltage draw. My buddy had that issue with his newer megacab Dodge.
  20. Mar 29, 2020 at 12:24 AM
    Apollo14
    Jonathan
    Vail, CO
    I think I was thinking the same thing. Just to verify though, you're saying I shouldn't need any PWM switch, correct?
