NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Apr 9, 2020 at 8:29 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Yeah, I need to finish the projects I currently have going before I start anything else.
  2. Apr 9, 2020 at 8:31 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Probably it just needs to not leak air or deform
    bobsuruncle[QUOTED] likes this.
  3. Apr 9, 2020 at 8:31 PM
    JimSnell
    JimSnell Well-Known Member
    Jim
    Puyallup
    2015 White Tacoma TRD Sport DCSB
    I've got a cutting board we could sacrifice.
    bobsuruncle likes this.
  4. Apr 9, 2020 at 8:36 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Lol, we could butcher up a Mountain Hatch cutting board and still come out cheaper than the XTP spacers
    TimberTiger and bobsuruncle like this.
  5. Apr 9, 2020 at 8:54 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    I start bidding at 1 corona with lime and 5 squares of tp
    PNW/TRD Steve likes this.
  6. Apr 9, 2020 at 9:18 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Just need a big enough printer...though you could split it in two really. Even the "standard" PLA filament should work. I'd still do the brass sleeves so the clamping pressure is applied to them and not directly on the plastic though.
    bobsuruncle[QUOTED] and TireFire like this.
  7. Apr 9, 2020 at 10:46 PM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    I've been eating way too much junk food and whiskey for 5 squares to be adequate.
  8. Apr 10, 2020 at 11:46 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    N95 mask and some rubber...gloves will go um... farther
    twalchlii1[QUOTED] likes this.
  9. Apr 10, 2020 at 12:17 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i have a set of chromoly cam gears. the were cut to stock specs instead of the 3* change. a machinist could alter these. i spent money, 20$ and youre on your way.
  10. Apr 10, 2020 at 1:43 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    I do need a reason to ditch the CRAPPYtune and get on board with HpT. You make it too easy with the obdII module already.
  11. Apr 10, 2020 at 3:26 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    and i will share.
  12. Apr 10, 2020 at 5:51 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    This must be the worst OP article I've ever read about the Tacoma, and then I got sucked into read the next worst OP article I've ever read, about the GX470.
    https://www.motorbiscuit.com/the-worst-used-toyota-tacoma-years-you-need-to-avoid/
    https://www.motorbiscuit.com/the-most-common-lexus-gx-470-problems-owners-deal-with/
    There goes 5min of my life I'll never get back.
    Tl;Dr the worst years for Tacoma are 2016, 2017, and 2009. o_O:rofl:
    The 3rd gen because of the transmission and CPS, and the 2009 specifically because of radio headunit issues and reported driveability problems.
    The gx470: 2006 with the introduction of SAI, and 2003.
    "There may be more complaints for the 2006 model year of the Lexus GX 470, but CarComplaints.com says 2003 may be the worst year for problems. Based on the number of occurrences, the average mileage at which the issues present, and the costs of repairs, the reports of clunking sounds make 2003 the worst.
    Occurring around 77,000 miles and costing $4,000 to fix, this suspension and driveshaft problem is significant for those who encounter it. The RepairPal.com gurus have reports of 85 GX 470 owners with this problem."
    Omfg 85 reports of a clunky driveshaft!!?? How could Lexus allow such a high number of owners to experience that?? I'm never buying a gx now! :facepalm::bananadead:
  13. Apr 10, 2020 at 6:26 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    when you’re forced to find problems you’ll find them no matter how small or insignificant
  14. Apr 10, 2020 at 8:31 PM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    18 LX570 on 35s, 06 Tundra DC beater
    Interestingly, the 2005 was the first year with SAI and the driveshaft clunk is from the ds weeping grease. Its solved by greasing the driveshaft every time you change the oil. Since its probably on a rack already, it takes an extra 5 minutes. Oddly, it doesnt mention the warping brake rotors common to the 470 and the 4th gen 4runner or the dash that cracked frequently enough for a recall. TL;DR thanks for wasting 5 minutes of my life too.
  15. Apr 10, 2020 at 8:35 PM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    So i was pulling a stump yesterday in 4lo and got a fairly loud popping noise from the front end during hard pulls. Both CVs are most likely shot, but to be clear it sounded like something slipping since it was a bunch of pops in a row when the wheels werent turning at all. THOTs?
  16. Apr 10, 2020 at 8:52 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    You have atrac and all that gizmotry? It wasn't that was it? Or were you jerking that snatch strap pretty good?
    Or your CVs really are shot and stripped out in there. I'm having flashbacks to that white 460 I came up on at tinkham Rd all fucked off with a broken front arb and both CV axles broken. :bananadead:
    Yetimetchkangmi likes this.
  17. Apr 10, 2020 at 9:15 PM
    JimSnell
    Jim
    Puyallup
    Sounds kinda like my truck when the abs or tractor is activated hard.
  18. Apr 10, 2020 at 9:17 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    That explains why you go anywhere stock. You've got a damn tractor. :rofl:
  19. Apr 10, 2020 at 9:34 PM
    JimSnell
    Jim
    Puyallup
    Difference between a pickup and a tractor? Fields.
  20. Apr 10, 2020 at 9:52 PM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    Nah that sounds like ABS. This was LOUD, sharp metallic pops like something was slipping or breaking, but it drives fine. Full time AWD too so its pushing the CVs even on pavement. I was pulling a tree stump in 4lo with the center diff locked in reverse. The noise happened at around 3k on grass but no wheel slip. Front wheels were slightly to the left but it hasnt done it since. no clunk or anything when i turn that would indicate bad CV joints. I have a torn boot and one is leaking grease around the inboard band.
