NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Apr 23, 2020 at 5:36 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Mine don't sag :notsure:
    Yours look flatter than factory Toyota leafs o_O
  2. Apr 23, 2020 at 5:39 PM
    FirstTimeTaco2020
    FirstTimeTaco2020 I came here for the chemlight batteries
    Cameron
    2016 TRDOR
    I’m about to give the wife and ultimatum. I am moving to Washington with or without you :rofl:
  3. Apr 23, 2020 at 5:46 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    36 month warranty...wonder if it’s been that long and if i should make a stink of it?
  4. Apr 23, 2020 at 5:52 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    :boink::crapstorm::poking:
    cosmicfires likes this.
  5. Apr 23, 2020 at 5:53 PM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    normal
    edit: just looked at mine and I have a bit of an arch still. Not sure if it's your camera or angle but your's looks like a bit of a S shape that I don't have. A little ripple effect. I've had mine on for 65k miles or so.
  6. Apr 23, 2020 at 5:56 PM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    It would only buy you some time. I’m pondering airbags or deavers or ......
  7. Apr 23, 2020 at 5:59 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    times all i meed While i get money together for rear shocks. Rumor is a second stimulus check is a possibility
  8. Apr 23, 2020 at 6:00 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    In for the shock relocate
    Usethe2nd[QUOTED] likes this.
  9. Apr 23, 2020 at 6:03 PM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Still rumors but yes. My friend in the great white north is getting $2k a month for 6 months or something like that. Cheeto won’t be out done by a Fracking Canadian will he?
  10. Apr 23, 2020 at 6:06 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    and leaf spring
    Dirk Diggler[QUOTED] likes this.
  11. Apr 23, 2020 at 6:12 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    You had me at plasma cutter
    ready6delta and Juforrest like this.
  12. Apr 23, 2020 at 6:14 PM
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    I am in tacoma.
    Benson X[QUOTED][OP] likes this.
  13. Apr 23, 2020 at 6:15 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Hey anyone got a good reccomendation on how the hell i can extract a real messed up screw ? I have a screw extractor set and it isn't doing shit. Drilled out the center and put rubber cement in it with an allen key and gonna let it dry. If that doesn't work in gonna try and drill it out without completely messing it up
  14. Apr 23, 2020 at 6:43 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    where are you and what diameter bolt? @bobsuruncle can vouch for my extractor sets :rofl:
  15. Apr 23, 2020 at 6:44 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Haha I think I can figure this out I just don't wanna drill it out if I dont need to. It's for my bike sitting in my garage and it is only a 5mm bolt :facepalm: just in a really pain in the ass spot. Rubber cement is sitting now gonna take a crack at it in about an hour
    Edit: I also would not like to admit how long I've been messing with it
  16. Apr 23, 2020 at 6:46 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Sometimes you can get them backed out with a little slot head screwdriver or cut a slot in it or beat one in with a chisel and make it a slot head.
  17. Apr 23, 2020 at 6:49 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Oh I already did that. Pounded with a large chisel put the screw driver in did not budge. Just kept slipping. Tried a dremel same thing. Heat wd40 BFH nothing. Tried the extractor set in between all this and isn't gripping. Tried 1 size up (6mm and sae version) and tap in nothing. Then i drilled deeper loaded rubber cement in and left a 6mm allen key inside and here I am.
  18. Apr 23, 2020 at 6:50 PM
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    If your gonna drill it use a left hand drill bit sometimes they will bite and back them out.
  19. Apr 23, 2020 at 6:50 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    I know the pain, im a mechanic for a living, hence the more than one extractor set i own.
    I have a set that’ll locate and drill out the exact center then back the bolt out
  20. Apr 23, 2020 at 6:51 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Ooooo I gotta see if I even have a left handed drill bit good call
    cosmicfires and bobsuruncle like this.
